J’avais vu sur le forum oui un strace tonprogramme, mais je savais pas quoi mettre à tonprogramme
strace apt-get install wine:
Epsilon012:/home/admin# strace apt-get install wine
execve("/usr/bin/apt-get", ["apt-get", "install", "wine"], [/* 28 vars */]) = 0
uname({sys="Linux", node="Epsilon012", ...}) = 0
brk(0) = 0x522000
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b23f68f3000
access("/etc/ld.so.preload", R_OK) = 0
open("/etc/ld.so.preload", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0600, st_size=0, ...}) = 0
close(3) = 0
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=45783, ...}) = 0
mmap(NULL, 45783, PROT_READ, MAP_PRIVATE, 3, 0) = 0x2b23f68f5000
close(3) = 0
open("/usr/lib/libapt-pkg-libc6.3-6.so.3.11", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340\n\2"..., 640) = 640
fstat(3, {st_mode=S_IFREG|0644, st_size=770328, ...}) = 0
mmap(NULL, 1818128, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b23f69f4000
mprotect(0x2b23f6aad000, 1060368, PROT_NONE) = 0
mmap(0x2b23f6bac000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb8000) = 0x2b23f6bac000
close(3) = 0
open("/usr/lib/libstdc++.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000\345\4"..., 640) = 640fstat(3, {st_mode=S_IFREG|0644, st_size=977600, ...}) = 0
mmap(NULL, 2100992, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b23f6bb0000
mprotect(0x2b23f6c96000, 1158912, PROT_NONE) = 0
mmap(0x2b23f6d96000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe6000) = 0x2b23f6d96000
mmap(0x2b23f6d9f000, 73472, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b23f6d9f000
close(3) = 0
open("/lib/libm.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320=\0\0"..., 640) = 640fstat(3, {st_mode=S_IFREG|0644, st_size=548016, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b23f6db1000
mmap(NULL, 1593800, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b23f6db2000
mprotect(0x2b23f6e37000, 1049032, PROT_NONE) = 0
mmap(0x2b23f6f36000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x84000) = 0x2b23f6f36000
close(3) = 0
open("/lib/libgcc_s.so.1", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\37\0"..., 640) = 640fstat(3, {st_mode=S_IFREG|0644, st_size=52176, ...}) = 0
mmap(NULL, 1099528, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b23f6f38000
mprotect(0x2b23f6f45000, 1046280, PROT_NONE) = 0
mmap(0x2b23f7044000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x2b23f7044000
close(3) = 0
open("/lib/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\305"..., 640) = 640
lseek(3, 624, SEEK_SET) = 624
read(3, "\4\0\0\0\20\0\0\0\1\0\0\0GNU\0\0\0\0\0\2\0\0\0\6\0\0\0"..., 32) = 32
fstat(3, {st_mode=S_IFREG|0755, st_size=1295640, ...}) = 0
mmap(NULL, 2354344, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b23f7045000
mprotect(0x2b23f7169000, 1158312, PROT_NONE) = 0
mmap(0x2b23f7268000, 98304, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x123000) = 0x2b23f7268000
mmap(0x2b23f7280000, 15528, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b23f7280000
close(3) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b23f7284000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b23f7285000
mprotect(0x2b23f7268000, 86016, PROT_READ) = 0
mprotect(0x2b23f6d96000, 24576, PROT_READ) = 0
arch_prctl(ARCH_SET_FS, 0x2b23f72850d0) = 0
munmap(0x2b23f68f5000, 45783) = 0
brk(0) = 0x522000
brk(0x543000) = 0x543000
open("/dev/null", O_WRONLY|O_CREAT|O_TRUNC, 0666) = 3
open("/usr/lib/locale/locale-archive", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0644, st_size=1672096, ...}) = 0
mmap(NULL, 1672096, PROT_READ, MAP_PRIVATE, 4, 0) = 0x2b23f7286000
close(4) = 0
stat("/var/lib/apt/.", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat("/etc/apt/apt.conf.d/", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/etc/apt/apt.conf.d/", O_RDONLY|O_NONBLOCK|O_DIRECTORY) = 4
fstat(4, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
fcntl(4, F_SETFD, FD_CLOEXEC) = 0
getdents64(4, /* 3 entries */, 4096) = 80
stat("/etc/apt/apt.conf.d/70debconf", {st_mode=S_IFREG|0644, st_size=182, ...}) = 0
getdents64(4, /* 0 entries */, 4096) = 0
close(4) = 0
open("/etc/apt/apt.conf.d/70debconf", O_RDONLY) = 4
read(4, "// Pre-configure all packages wi"..., 8191) = 182
read(4, "", 8191) = 0
close(4) = 0
stat("/etc/apt/apt.conf", {st_mode=S_IFREG|0644, st_size=96, ...}) = 0
open("/etc/apt/apt.conf", O_RDONLY) = 4
read(4, "APT::Authentication::TrustCDROM "..., 8191) = 96
close(4) = 0
stat("/var/lib/dpkg/status", {st_mode=S_IFREG|0644, st_size=716053, ...}) = 0
stat("/usr/bin/dpkg", {st_mode=S_IFREG|0755, st_size=352656, ...}) = 0
stat("/etc/debian_version", {st_mode=S_IFREG|0644, st_size=17, ...}) = 0
ioctl(1, SNDCTL_TMR_TIMEBASE or TCGETS, {B38400 opost isig icanon echo ...}) = 0rt_sigaction(SIGPIPE, {SIG_IGN}, {SIG_DFL}, 8) = 0
rt_sigaction(SIGWINCH, {0x405fa0, [WINCH], SA_RESTORER|SA_RESTART, 0x2b23f7074e90}, {SIG_DFL}, 8) = 0
ioctl(1, TIOCGWINSZ, {ws_row=24, ws_col=80, ws_xpixel=0, ws_ypixel=0}) = 0
open("/var/lib/dpkg/lock", O_RDWR|O_CREAT|O_TRUNC, 0640) = 4
fcntl(4, F_SETLK, {type=F_WRLCK, whence=SEEK_SET, start=0, len=0}) = 0
open("/var/lib/dpkg/updates/", O_RDONLY|O_NONBLOCK|O_DIRECTORY) = 5
fstat(5, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
fcntl(5, F_SETFD, FD_CLOEXEC) = 0
getdents64(5, /* 2 entries */, 4096) = 48
getdents64(5, /* 0 entries */, 4096) = 0
close(5) = 0
stat("/etc/apt/sources.list", {st_mode=S_IFREG|0644, st_size=2136, ...}) = 0
open("/etc/apt/sources.list", O_RDONLY) = 5
read(5, "################################"..., 8191) = 2136
read(5, "", 8191) = 0
close(5) = 0
stat("/etc/apt/sources.list.d/", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/etc/apt/sources.list.d/", O_RDONLY|O_NONBLOCK|O_DIRECTORY) = 5
close(5) = 0
stat("/var/lib/apt/lists/ftp.es.debian.org_debian-amd64_debian_dists_sid_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/ftp.crans.org_debian-amd64_debian_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/debian.sil.at_debian-amd64_debian_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/bytekeeper.as28747.net_debian-amd64_debian_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/ftp.belnet.be_debian-amd64_debian_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/mirror.switch.ch_mirror_debian-amd64_debian_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/ftp.cl.debian.org_debian-amd64_debian_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/ftp.de.debian.org_debian-amd64_debian_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/ftp.jp.debian.org_debian-amd64_debian_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/hanzubon.jp_debian-amd64_debian_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/ftp.nl.debian.org_debian-amd64_debian_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/ftp.sk.debian.org_debian-amd64_debian_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/debian.csail.mit.edu_debian-amd64_debian_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/ftp.hr.debian.org_debian-amd64_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/ftp.it.debian.org_debian-amd64_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/ftp.ru.debian.org_debian-amd64_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
stat("/var/lib/apt/lists/debian.gala.net_debian-amd64_dists_sarge_Release.gpg", {st_mode=S_IFREG|0644, st_size=189, ...}) = 0
access("/var/cache/apt/", W_OK) = 0
open("/usr/share/locale/locale.alias", O_RDONLY) = 5
fstat(5, {st_mode=S_IFREG|0644, st_size=2582, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b23f741f000
read(5, "# Locale name alias data base.\n#"..., 4096) = 2582
read(5, "", 4096) = 0
close(5) = 0
munmap(0x2b23f741f000, 4096) = 0
open("/usr/share/locale/fr_FR/LC_MESSAGES/libapt-pkg3.11.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/share/locale/fr/LC_MESSAGES/libapt-pkg3.11.mo", O_RDONLY) = 5
fstat(5, {st_mode=S_IFREG|0644, st_size=25555, ...}) = 0
mmap(NULL, 25555, PROT_READ, MAP_PRIVATE, 5, 0) = 0x2b23f741f000
close(5) = 0
open("/usr/lib/gconv/gconv-modules.cache", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/gconv/gconv-modules", O_RDONLY) = 5
fstat(5, {st_mode=S_IFREG|0644, st_size=45660, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b23f7426000
read(5, "# GNU libc iconv configuration.\n"..., 4096) = 4096
read(5, "lias\tJS//\t\t\tJUS_I.B1.002//\nalias"..., 4096) = 4096
read(5, "ule\tINTERNAL\t\tISO-8859-3//\t\tISO8"..., 4096) = 4096
read(5, "lias\tISO-IR-199//\t\tISO-8859-14//"..., 4096) = 4096
read(5, "\t\tto\t\t\tmodule\t\tcost\nalias\tCSEBCD"..., 4096) = 4096
read(5, "ule\t\tcost\nalias\tCP284//\t\t\tIBM284"..., 4096) = 4096
read(5, "lias\tCP864//\t\t\tIBM864//\nalias\t86"..., 4096) = 4096
read(5, "module\tIBM937//\t\tINTERNAL\t\tIBM93"..., 4096) = 4096
read(5, "\tEUC-JP//\nalias\tUJIS//\t\t\tEUC-JP/"..., 4096) = 4096
brk(0x564000) = 0x564000
read(5, "module\t\tcost\nalias\tISO-IR-143//\t"..., 4096) = 4096
read(5, "-BOX//\nmodule\tISO_10367-BOX//\t\tI"..., 4096) = 4096
read(5, "module\tINTERNAL\t\tEUC-JISX0213//\t"..., 4096) = 604
close(5) = 0
munmap(0x2b23f7426000, 4096) = 0
open("/usr/lib/gconv/ISO8859-1.so", O_RDONLY) = 5
read(5, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000\6\0\0"..., 640) = 640fstat(5, {st_mode=S_IFREG|0644, st_size=10136, ...}) = 0
mmap(NULL, 1056824, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 5, 0) = 0x2b23f7426000
mprotect(0x2b23f7428000, 1048632, PROT_NONE) = 0
mmap(0x2b23f7527000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 5, 0x1000) = 0x2b23f7527000
close(5) = 0
open("/usr/lib/gconv/ISO8859-15.so", O_RDONLY) = 5
mmap(NULL, 1056824, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 5, 0) = 0x2b23f7529000
mprotect(0x2b23f752b000, 1048632, PROT_NONE) = 0
mmap(0x2b23f762a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 5, 0x1000) = 0x2b23f762a000
close(5) = 0
fstat(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 1), ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b23f762c000
) = 37e des listes de paquets... 0%aquets.."..., 37
stat("/var/cache/apt/pkgcache.bin", {st_mode=S_IFREG|0644, st_size=1000000, ...}) = 0
open("/var/cache/apt/pkgcache.bin", O_RDONLY) = 5
fstat(5, {st_mode=S_IFREG|0644, st_size=1000000, ...}) = 0
mmap(NULL, 1000000, PROT_READ, MAP_SHARED, 5, 0) = 0x2b23f762d000
munmap(0x2b23f762d000, 1000000) = 0
close(5) = 0
unlink("/var/cache/apt/pkgcache.bin") = 0
lstat("/var/cache/apt/pkgcache.bin", 0x7fffffeaf990) = -1 ENOENT (No such file or directory)
open("/var/cache/apt/pkgcache.bin", O_RDWR|O_CREAT|O_TRUNC, 0666) = 5
fchmod(5, 0644) = 0
fstat(5, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
lseek(5, 999999, SEEK_SET) = 999999
write(5, "\0", 1) = 1
mmap(NULL, 1000000, PROT_READ|PROT_WRITE, MAP_SHARED, 5, 0) = 0x2b23f762d000
stat("/var/cache/apt/srcpkgcache.bin", 0x7fffffeaf840) = -1 ENOENT (No such file or directory)
stat("/var/lib/apt/lists/ftp.es.debian.org_debian-amd64_debian_dists_sid_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=16075436, ...}) = 0
stat("/var/lib/apt/lists/ftp.es.debian.org_debian-amd64_debian_dists_sid_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=171414, ...}) = 0
stat("/var/lib/apt/lists/ftp.es.debian.org_debian-amd64_debian_dists_sid_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=143009, ...}) = 0
stat("/var/lib/apt/lists/ftp.crans.org_debian-amd64_debian_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/ftp.crans.org_debian-amd64_debian_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/ftp.crans.org_debian-amd64_debian_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/debian.sil.at_debian-amd64_debian_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/debian.sil.at_debian-amd64_debian_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/debian.sil.at_debian-amd64_debian_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/bytekeeper.as28747.net_debian-amd64_debian_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/bytekeeper.as28747.net_debian-amd64_debian_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0stat("/var/lib/apt/lists/bytekeeper.as28747.net_debian-amd64_debian_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/ftp.belnet.be_debian-amd64_debian_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/ftp.belnet.be_debian-amd64_debian_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/ftp.belnet.be_debian-amd64_debian_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/mirror.switch.ch_mirror_debian-amd64_debian_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12435796, ...}) = 0stat("/var/lib/apt/lists/mirror.switch.ch_mirror_debian-amd64_debian_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/mirror.switch.ch_mirror_debian-amd64_debian_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/ftp.cl.debian.org_debian-amd64_debian_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/ftp.cl.debian.org_debian-amd64_debian_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/ftp.cl.debian.org_debian-amd64_debian_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/ftp.de.debian.org_debian-amd64_debian_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/ftp.de.debian.org_debian-amd64_debian_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/ftp.de.debian.org_debian-amd64_debian_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/ftp.jp.debian.org_debian-amd64_debian_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/ftp.jp.debian.org_debian-amd64_debian_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/ftp.jp.debian.org_debian-amd64_debian_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/hanzubon.jp_debian-amd64_debian_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/hanzubon.jp_debian-amd64_debian_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/hanzubon.jp_debian-amd64_debian_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/ftp.nl.debian.org_debian-amd64_debian_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/ftp.nl.debian.org_debian-amd64_debian_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/ftp.nl.debian.org_debian-amd64_debian_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/ftp.sk.debian.org_debian-amd64_debian_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/ftp.sk.debian.org_debian-amd64_debian_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/ftp.sk.debian.org_debian-amd64_debian_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/debian.csail.mit.edu_debian-amd64_debian_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/debian.csail.mit.edu_debian-amd64_debian_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/debian.csail.mit.edu_debian-amd64_debian_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/ftp.hr.debian.org_debian-amd64_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/ftp.hr.debian.org_debian-amd64_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/ftp.hr.debian.org_debian-amd64_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/ftp.it.debian.org_debian-amd64_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/ftp.it.debian.org_debian-amd64_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/ftp.it.debian.org_debian-amd64_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/ftp.ru.debian.org_debian-amd64_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/ftp.ru.debian.org_debian-amd64_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/ftp.ru.debian.org_debian-amd64_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
stat("/var/lib/apt/lists/debian.gala.net_debian-amd64_dists_sarge_main_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=12437658, ...}) = 0
stat("/var/lib/apt/lists/debian.gala.net_debian-amd64_dists_sarge_contrib_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=160192, ...}) = 0
stat("/var/lib/apt/lists/debian.gala.net_debian-amd64_dists_sarge_non-free_binary-amd64_Packages", {st_mode=S_IFREG|0644, st_size=147571, ...}) = 0
msync(0x2b23f762d000, 8656, MS_SYNC) = 0
open("/var/lib/apt/lists/ftp.es.debian.org_debian-amd64_debian_dists_sid_main_binary-amd64_Packages", O_RDONLY) = 6
fcntl(6, F_SETFD, FD_CLOEXEC) = 0
fstat(6, {st_mode=S_IFREG|0644, st_size=16075436, ...}) = 0
mmap(NULL, 16075436, PROT_READ, MAP_SHARED, 6, 0) = 0x2b23f7722000
--- SIGSEGV (Segmentation fault) @ 0 (0) ---
+++ killed by SIGSEGV +++
Process 4486 detached
20 derniere ligne de /tmp/erreur:
msync(0x2b45468a1000, 8656, MS_SYNC) = 0
mmap(NULL, 16075436, PROT_READ, MAP_SHARED, 6, 0) = 0x2b4546996000
write(1, "\rLecture des listes de paquets.."..., 37) = 37
Process 4355 detached
