Dans ces logs, aucune entrée par rapport à cet évenement.
smartctl -s on -a /dev/sda6
smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.19.0-3-amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Intel 540 Series SSDs
Device Model: INTEL SSDSC2KW240H6
Serial Number: CVLT736000HE240CGN
LU WWN Device Id: 5 5cd2e4 14e8f3ab3
Firmware Version: LSF036C
User Capacity: 240 056 327 680 bytes [240 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 (minor revision not indicated)
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Feb 19 08:59:01 2019 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF ENABLE/DISABLE COMMANDS SECTION ===
SMART Enabled.
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x53) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 15) minutes.
SCT capabilities: (0x0039) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 6
9 Power_On_Hours_and_Msec 0x0032 100 100 000 Old_age Always - 1086h+00m+00.000s
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1212
170 Available_Reservd_Space 0x0033 099 099 010 Pre-fail Always - 0
171 Program_Fail_Count 0x0032 100 100 010 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 010 Old_age Always - 0
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 78
183 SATA_Downshift_Count 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0033 100 100 090 Pre-fail Always - 0
187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 98
190 Airflow_Temperature_Cel 0x0032 044 059 000 Old_age Always - 44 (Min/Max 23/59)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 78
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
225 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 47971
226 Workld_Media_Wear_Indic 0x0032 100 100 000 Old_age Always - 0
227 Workld_Host_Reads_Perc 0x0032 100 100 000 Old_age Always - 0
228 Workload_Minutes 0x0032 100 100 000 Old_age Always - 0
232 Available_Reservd_Space 0x0033 099 099 010 Pre-fail Always - 0
233 Media_Wearout_Indicator 0x0032 099 099 000 Old_age Always - 0
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 47971
242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 36721
249 NAND_Writes_1GiB 0x0032 100 100 000 Old_age Always - 950
252 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 7
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 70403103932424 70403103932424 Not_testing
2 70403103932424 70403103932424 Not_testing
3 70403103932424 70403103932424 Not_testing
4 70403103932424 70403103932424 Not_testing
5 70403103932424 70403103932424 Not_testing
Selective self-test flags (0x4008):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
OK je garde cette option en tête
Et pour la géométrie des secteurs touchés : impresssionnnant, je n’avais pas fait attention à cela !
En tout cas merci beaucoup pour votre aide et conseils
smartctl -a /dev/sda
Local Time is: Tue Feb 19 09:03:46 2019 CET
was never started.
been run.
command.
power-saving mode.
No Errors Logged
Je vais essayer de relancer ce qui a fait planté la machine hier, voir ce quil en est.
En tout cas, agréable journée à tous
