Mon système: Linux Debian 11.7
mysql Ver 15.1 Distrib 10.5.19-MariaDB
Serveur Apache/2.4.56
J’ai une erreur subite durant l’utilisation de GLPI sur mon serveur:
Un lien vers le serveur SQL n’a pas pu être établi. Veuillez vérifier votre configuration.
Le serveur Mysql est inaccessible. Vérifiez votre configuration.
J’ai constaté l’erreur ci-dessous sur Mariadb:
systemctl status mysql.service
● mariadb.service - MariaDB 10.5.19 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2023-09-26 11:56:42 CEST; 1h 9min ago
Docs: man:mariadbd(8)
https://mariadb.com/kb/en/library/systemd/
Main PID: 532 (code=exited, status=1/FAILURE)
Status: "MariaDB server is down"
CPU: 211ms
sept. 26 11:56:41 debian11ocs mariadbd[532]: 2023-09-26 11:56:41 0 [Note] InnoDB: Starting shutdown...
sept. 26 11:56:42 debian11ocs mariadbd[532]: 2023-09-26 11:56:42 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
sept. 26 11:56:42 debian11ocs mariadbd[532]: 2023-09-26 11:56:42 0 [ERROR] Plugin 'InnoDB' init function returned error.
sept. 26 11:56:42 debian11ocs mariadbd[532]: 2023-09-26 11:56:42 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
sept. 26 11:56:42 debian11ocs mariadbd[532]: 2023-09-26 11:56:42 0 [Note] Plugin 'FEEDBACK' is disabled.
sept. 26 11:56:42 debian11ocs mariadbd[532]: 2023-09-26 11:56:42 0 [ERROR] Unknown/unsupported storage engine: InnoDB
sept. 26 11:56:42 debian11ocs mariadbd[532]: 2023-09-26 11:56:42 0 [ERROR] Aborting
sept. 26 11:56:42 debian11ocs systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
sept. 26 11:56:42 debian11ocs systemd[1]: mariadb.service: Failed with result 'exit-code'.
sept. 26 11:56:42 debian11ocs systemd[1]: Failed to start MariaDB 10.5.19 database server.
En voulant démarrer Mariadb, j’ai le message ci-dessous:
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/run/mysqld/mysqld.so
Je suppose que le système n’a plus assez de place pour lancer les processus…
Ci-dessous les volumes utilisés:
df -h
Sys. de fichiers Taille Utilisé Dispo Uti% Monté sur
udev 3,9G 0 3,9G 0% /dev
tmpfs 788M 764K 787M 1% /run
/dev/sda1 23G 5,5G 17G 26% /
tmpfs 3,9G 0 3,9G 0% /dev/shm
tmpfs 5,0M 0 5,0M 0% /run/lock
/dev/sda7 1,8G 52K 1,7G 1% /tmp
/dev/sda5 9,1G 8,6G 3,3M 100% /var
/dev/sda8 423G 80K 401G 1% /home
tmpfs 788M 0 788M 0% /run/user/1000
Si c’est le cas, que faut-il supprimer pour récupérer de l’espace libre… Sans KC le système…
si autre chose, merci de m’indiquer ou chercher…
Merci d’avance
