Erreurs à corriger ou non nécessaire?
bonjour ,
système : debian 11 / Xfce
a priori tout fonctionne correctement et je ne me suis donc jamais préoccupé des messages d’erreur ci-dessous . Cependant autant avoir un avis compétent pour savoir si je ne fais pas moi-même une erreur :
mm@ldlc:~$ sudo dmesg -l err
[sudo] Mot de passe de mm :
[    8.366115] iwlwifi 0000:02:00.0: firmware: failed to load iwl-debug-yoyo.bin (-2)
[    8.366161] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[    9.182165] r8169 0000:01:00.1: firmware: failed to load rtl_nic/rtl8411-2.fw (-2)
[    9.184227] r8169 0000:01:00.1: Unable to load firmware rtl_nic/rtl8411-2.fw (-2)
[ 1331.214167] r8169 0000:01:00.1: firmware: failed to load rtl_nic/rtl8411-2.fw (-2)
[ 1331.214180] r8169 0000:01:00.1: Unable to load firmware rtl_nic/rtl8411-2.fw (-2)
[29944.536879] r8169 0000:01:00.1: firmware: failed to load rtl_nic/rtl8411-2.fw (-2)
[29944.536894] r8169 0000:01:00.1: Unable to load firmware rtl_nic/rtl8411-2.fw (-2)
[37740.991111] r8169 0000:01:00.1: firmware: failed to load rtl_nic/rtl8411-2.fw (-2)
[37740.991124] r8169 0000:01:00.1: Unable to load firmware rtl_nic/rtl8411-2.fw (-2)
[56922.525631] r8169 0000:01:00.1: firmware: failed to load rtl_nic/rtl8411-2.fw (-2)
[56922.525645] r8169 0000:01:00.1: Unable to load firmware rtl_nic/rtl8411-2.fw (-2)
[74565.256747] r8169 0000:01:00.1: firmware: failed to load rtl_nic/rtl8411-2.fw (-2)
[74565.256759] r8169 0000:01:00.1: Unable to load firmware rtl_nic/rtl8411-2.fw (-2)
[77898.903677] r8169 0000:01:00.1: firmware: failed to load rtl_nic/rtl8411-2.fw (-2)
[77898.903943] r8169 0000:01:00.1: Unable to load firmware rtl_nic/rtl8411-2.fw (-2)
[103702.596958] r8169 0000:01:00.1: firmware: failed to load rtl_nic/rtl8411-2.fw (-2)
[103702.596971] r8169 0000:01:00.1: Unable to load firmware rtl_nic/rtl8411-2.fw (-2)
mm@ldlc:~$ sudo lspci -nn | grep Real
01:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTL8411B PCI Express Card Reader [10ec:5287] (rev 01)
01:00.1 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 12)
Installer le paquet firmware-realtek pour faire taire ces erreurs ?
A+
ok voilà qui est fait et tout ce qui concerne realtek a disparu . J’aurais dû faire ça dès le début mais comme tout fonctionnait correctement j’avais complètement oublié cette affaire et s’il n’y avait pas eu le post de @iznobe sur des erreurs signalées par dmesg je ne m’en serais probablement jamais préoccupé . Reste à savoir si je vais constater une différence de comportement de Debian 11 … pas évident quand tout fonctionne sans ce paquet .
merci pour la réponse
Edit 1 :
This package contains the binary firmware for Realtek Ethernet, wifi and
Bluetooth adapters supported by various drivers.
Mon réseau n’a jamais bégayé depuis l’installation de Debian 11 , je ne verrai donc probablement pas de différence .
