dmesg affiche les erreurs suivantes. Je n’ai aucune idée de l’impact actuel ou à venir, voire d’une solution.
Est-ce une question matérielle ? (l’ordi a bien 10 ans d’usage quotidien, certainement beaucoup plus de 50000 heures de vol…)
[ 1.526455] Run /init as init process
[ 1.580060] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5
[ 1.580085] ACPI: Power Button [PWRB]
[ 1.580154] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input6
[ 1.580166] ACPI: Sleep Button [SLPB]
[ 1.580231] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input7
[ 1.580240] ACPI: Lid Switch [LID0]
[ 1.580304] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input8
[ 1.580314] ACPI: Power Button [PWRF]
[ 1.598713] cryptd: max_cpu_qlen set to 1000
[ 1.601746] r8169 0000:03:00.1: can't disable ASPM; OS doesn't have ASPM control
[ 1.602485] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20180810/utaddress-213)
[ 1.602492] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 1.602495] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20180810/utaddress-213)
[ 1.602499] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 1.602501] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20180810/utaddress-213)
[ 1.602504] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20180810/utaddress-213)
[ 1.602508] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 1.602509] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20180810/utaddress-213)
[ 1.602512] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20180810/utaddress-213)
[ 1.602516] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 1.602517] lpc_ich: Resource conflict(s) found affecting gpio_ich
