Saluts,
Je vais au but …
################### Logwatch 7.3.6 (05/19/07) ####################
Processing Initiated: Mon Aug 15 21:03:50 2011
--------------------- Cron Begin ------------------------
Errors when running cron:
grandchild #10062 failed with exit status 1: 1 Time(s)
grandchild #10173 failed with exit status 1: 1 Time(s)
grandchild #11000 failed with exit status 1: 2 Time(s)
grandchild #11086 failed with exit status 62: 1 Time(s)
grandchild #11096 failed with exit status 127: 2 Time(s)
grandchild #11192 failed with exit status 1: 1 Time(s)
grandchild #11232 failed with exit status 1: 2 Time(s)
grandchild #11273 failed with exit status 127: 1 Time(s)
grandchild #11535 failed with exit status 1: 1 Time(s)
grandchild #12524 failed with exit status 1: 2 Time(s)
grandchild #12620 failed with exit status 127: 2 Time(s)
grandchild #12720 failed with exit status 62: 1 Time(s)
grandchild #12897 failed with exit status 1: 1 Time(s)
grandchild #13034 failed with exit status 127: 1 Time(s)
grandchild #14046 failed with exit status 1: 2 Time(s)
grandchild #14053 failed with exit status 1: 1 Time(s)
grandchild #14142 failed with exit status 127: 2 Time(s)
grandchild #15340 failed with exit status 1: 1 Time(s)
grandchild #15568 failed with exit status 1: 2 Time(s)
grandchild #15664 failed with exit status 127: 2 Time(s)
grandchild #15675 failed with exit status 62: 1 Time(s)
grandchild #15775 failed with exit status 1: 1 Time(s)
grandchild #15800 failed with exit status 1: 2 Time(s)
grandchild #17092 failed with exit status 1: 2 Time(s)
grandchild #17188 failed with exit status 127: 2 Time(s)
grandchild #18577 failed with exit status 127: 1 Time(s)
grandchild #19055 failed with exit status 1: 2 Time(s)
grandchild #1953 failed with exit status 1: 1 Time(s)
grandchild #20491 failed with exit status 1: 1 Time(s)
grandchild #2051 failed with exit status 127: 1 Time(s)
grandchild #20598 failed with exit status 1: 1 Time(s)
grandchild #20762 failed with exit status 1: 1 Time(s)
grandchild #22094 failed with exit status 1: 1 Time(s)
grandchild #22201 failed with exit status 1: 1 Time(s)
grandchild #24695 failed with exit status 1: 1 Time(s)
grandchild #24778 failed with exit status 127: 1 Time(s)
grandchild #24890 failed with exit status 1: 1 Time(s)
grandchild #24962 failed with exit status 1: 1 Time(s)
grandchild #25121 failed with exit status 1: 1 Time(s)
grandchild #26570 failed with exit status 1: 1 Time(s)
grandchild #28816 failed with exit status 1: 1 Time(s)
grandchild #28969 failed with exit status 127: 1 Time(s)
grandchild #31579 failed with exit status 1: 1 Time(s)
grandchild #31692 failed with exit status 127: 1 Time(s)
grandchild #3555 failed with exit status 1: 1 Time(s)
grandchild #4862 failed with exit status 1: 1 Time(s)
grandchild #4957 failed with exit status 1: 1 Time(s)
grandchild #6528 failed with exit status 127: 2 Time(s)
grandchild #6563 failed with exit status 1: 1 Time(s)
grandchild #6664 failed with exit status 1: 2 Time(s)
grandchild #6695 failed with exit status 1: 1 Time(s)
grandchild #7956 failed with exit status 1: 2 Time(s)
grandchild #8052 failed with exit status 127: 2 Time(s)
grandchild #8342 failed with exit status 1: 1 Time(s)
grandchild #8456 failed with exit status 1: 1 Time(s)
grandchild #8627 failed with exit status 1: 1 Time(s)
grandchild #9478 failed with exit status 1: 2 Time(s)
grandchild #9574 failed with exit status 127: 2 Time(s)
grandchild #9681 failed with exit status 127: 1 Time(s)
grandchild #9682 failed with exit status 127: 1 Time(s)
**Unmatched Entries**
ERROR (Syntax error, this crontab file will be ignored)
---------------------- Cron End -------------------------
/var/log !!!
[quote]ug 15 21:00:01 Debian-pc-1 sSMTP[16542]: Creating SSL connection to host
Aug 15 21:00:01 Debian-pc-1 sSMTP[16542]: SSL connection using RSA_ARCFOUR_SHA1
Aug 15 21:00:01 Debian-pc-1 /USR/SBIN/CRON[16516]: (CRON) error (grandchild #16517 failed with exit status 1)
Aug 15 21:00:01 Debian-pc-1 sSMTP[16542]: Creating SSL connection to host
Aug 15 21:00:04 Debian-pc-1 sSMTP[16542]: Sent mail for root@ (221 2.0.0 closing connection l7sm3836015wed.17) uid=0 username=root outbytes=698
Bon jusque là ! Pas de souci !
J’ai bien compris qu’il s’agit de cron, faudrait vraiment … … le temps.
Je passes en revues les tâches, (annuel … journalière), j’ai crûs comprendre qu’il s’agit de syntaxe (?) …
Mais bon, la syntaxe et moi …
Je ne sais plus ou chercher ! (?)
Une petite piste … (?)
