bonjour,
j’ai des plantages de ma machine Debian12 à jour (gel complet) , depuis me semble-t-il les derniers noyaux
j’ai les linux-firmware non-free installés
le pilote nouveau sort des erreurs
Linux 6.1.0-26-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.112-1 (2024-09-30) x86_64 GNU/Linux
nouveau 0000:01:00.0: vgaarb: deactivate vga console
[ 1.453668] nouveau 0000:01:00.0: NVIDIA GF119 (0d9090a1)
[ 1.595158] nouveau 0000:01:00.0: bios: version 75.19.56.00.09
[ 1.596151] nouveau 0000:01:00.0: fb: 1024 MiB DDR3
[ 1.666203] nouveau 0000:01:00.0: DRM: VRAM: 1024 MiB
[ 1.666205] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[ 1.666208] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[ 1.666210] nouveau 0000:01:00.0: DRM: DCB version 4.0
[ 1.666211] nouveau 0000:01:00.0: DRM: DCB outp 00: 02000300 00000000
[ 1.666213] nouveau 0000:01:00.0: DRM: DCB outp 01: 02011362 00020010
[ 1.666215] nouveau 0000:01:00.0: DRM: DCB conn 00: 00000000
[ 1.666216] nouveau 0000:01:00.0: DRM: DCB conn 01: 00002161
[ 1.667506] nouveau 0000:01:00.0: DRM: MM: using COPY0 for buffer copies
[ 1.837662] nouveau 0000:01:00.0: DRM: allocated 1920x1080 fb: 0x60000, bo (ptrval)
[ 1.838439] fbcon: nouveaudrmfb (fb0) is primary device
[ 2.145552] nouveau 0000:01:00.0: [drm] fb0: nouveaudrmfb frame buffer device
[ 2.158759] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
[ 175.630247] nouveau 0000:01:00.0: firmware: failed to load nouveau/nvd9_fuc084 (-2)
[ 175.630261] nouveau 0000:01:00.0: firmware: failed to load nouveau/nvd9_fuc084 (-2)
[ 175.630264] nouveau 0000:01:00.0: Direct firmware load for nouveau/nvd9_fuc084 failed with error -2
[ 175.630273] nouveau 0000:01:00.0: firmware: failed to load nouveau/nvd9_fuc084d (-2)
[ 175.630279] nouveau 0000:01:00.0: firmware: failed to load nouveau/nvd9_fuc084d (-2)
[ 175.630281] nouveau 0000:01:00.0: Direct firmware load for nouveau/nvd9_fuc084d failed with error -2
[ 175.630283] nouveau 0000:01:00.0: msvld: unable to load firmware data
[ 175.630284] nouveau 0000:01:00.0: msvld: init failed, -19
C’est à dire? quels paquets sont installés?
bonjour,
xserver-xorg-video-nouveau
libdrm-nouveau2
libdrm-nouveau2:i386
firmware-amd-graphics
firmware-linux-free
firmware-linux-nonfree
firmware-linux-misc-nonfree
trouvé cela sur forum Ubuntu
Petit espoir pour les (nombreux) utilisateurs ayant des soucis avec leur carte graphique Nvidia depuis la migration vers 24.04:
J’ai pu discuter avec le mainteneur du PPA sur le forum officiel Nvidia. Il a lui-même abandonné après un grand nombre de tentatives infructueuses.
Il m’indique toutefois qu’un développeur indépendant tente de repakager le ppa du pilote 340/390 sur Debian. Je mets le lien ci-dessous.Il est bien noté "Pour tests et reconstruction, Ne Pas utiliser! "
À suivre donc… Mais en attendant, il apparaît que les bureaux Gnome et Cinnamon soient particulièrement vulnérables à des bugs graphiques avec le pilote « nouveau » (cela dépend des cartes vidéo, certaines fonctionnant sans problème). Le bureau Xfce parvient beaucoup mieux à cadrer la résolution d’affichage ainsi que la mise en page des logiciels tiers…*
On parle ici de Debian, donc on oublie totalement les PPA Ubuntu!!
Il faut installer nvidia-detect
puis le lancer. Celui -ci indique quel pilote installer (principalement nvidia-detect
donc il te faut faire:
apt install nvidia-detect
Ensuite
nvidia-detect
et quel est son résultat?
Lors d’une mise à jour du kernel, il est souvent nécessaire de relancer l’installation du pilote NVIDIA, parfois avec la même version s’il n’a pas évolué.
Ubuntu est basé sur Debian…
nvidia-detect
Detected NVIDIA GPUs:
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF119 [GeForce GT 620 OEM] [10de:1049] (rev a1)
Checking card: NVIDIA Corporation GF119 [GeForce GT 620 OEM] (rev a1)
Your card is only supported by the 390 legacy drivers series, which is only available up to bullseye.
Mon Pc c Debian GNU/Linux 12 (bookworm), donc obligé de rester avec « nouveau »
Et non l’inverse.
Peu importe les PPA ubuntu sur une Debian c’est juste bon à faire de la Frankendebian.
Pas obligatoirement, j’ai un serveur qui utilise ce pilote et j’ai utilisé le pilote de la SID car le 390 Legacy est dans la SID.
Pour cela, il te faut ajouter les dépots SID nécessaire en créant un sources list:
sudo vim /etc/apt/sources.list.d/sid_for_nvidia.list
deb http://deb.debian.org/debian/ sid main contrib non-free
Ensuite tu installes:
apt update
apt install nvidia-legacy-390xx-driver
ensuite tu commente la ligne dans /etc/apt/sources.list.d/sid_for_nvidia.list
# deb http://deb.debian.org/debian/ sid main contrib non-free
et tu fait un update pour rester propre:
apt update
C’est l’équivalant de ce qui est donné dans Installation NVIDIA (non free) avec le Legacy 340
