j’ai tenté de recompiler mon noyau dans les mêmes conditions et le problème est identique, plus de place disponible (7G.o occupé par la compilation).
J’ai installé clamav, j’ai réalisé un scan, l’antivirus n’a rien trouvé. Par contre j’ai fait un rkhunter (pour les rootkit) et il m’a décelé deux warning :
[quote] VcKit Rootkit [ Not found ]
Volc Rootkit [ Not found ]
Xzibit Rootkit [ Not found ]
X-Org SunOS Rootkit [ Not found ]
zaRwT.KiT Rootkit [ Not found ]
ZK Rootkit [ Not found ]
Performing additional rootkit checks
Suckit Rookit additional checks [ OK ]
Checking for possible rootkit files and directories [ None found ]
Checking for possible rootkit strings [ Warning ]
Performing malware checks
Checking running processes for suspicious files [ None found ]
Checking for login backdoors [ None found ]
Checking for suspicious directories [ None found ]
Checking for sniffer log files [ None found ]
Performing Linux specific checks
Checking loaded kernel modules [ OK ]
Checking kernel module names [ OK ]
[Press to continue]
Performing filesystem checks
Checking /dev for suspicious file types [ None found ]
Checking for hidden files and directories [ Warning ]
System checks summary
File properties checks…
Files checked: 132
Suspect files: 0
Rootkit checks…
Rootkits checked : 242
Possible rootkits: 2
Rootkit names : Xzibit Rootkit, Xzibit Rootkit
Applications checks…
All checks skipped
The system checks took: 2 minutes and 2 seconds
All results have been written to the log file (/var/log/rkhunter.log)
One or more warnings have been found while checking the system.
Please check the log file (/var/log/rkhunter.log)
que puis-je faire d’autre? que dois-je faire ??
