[etch/sid]Donnez vos cycles CPU pour une bonne cause
Vous connaissez seti@home ?
Ben ca se généralise aux rotations de molecules ou à la lutte contre la malaria:
boinc.berkeley.edu/
et en plus, c’est en paquets debian pour l’install ![code]emeraude:~$ aptitude search boinc
i A boinc-client - core client for the BOINC distributed computing infrastructure
p boinc-dev - development files to build applications for BOINC projects
i boinc-manager - GUI to control and monitor the BOINC core client
i kboincspy - monitoring utility for the BOINC client
p kboincspy-dev - development files for KBoincSpy plugins
emeraude:~$ apt-cache policy boinc-client
boinc-client:
Installé : 5.2.15-3
Candidat : 5.2.15-3
Table de version :
5.4.3-1 0
987 http://ftp2.fr.debian.org sid/main Packages
*** 5.2.15-3 0
998 http://ftp2.fr.debian.org etch/main Packages
100 /var/lib/dpkg/status
emeraude:~$ aptitude show boinc-client
Paquet : boinc-client
Nouveau: oui
État: installé
Automatiquement installé: oui
Version : 5.2.15-3
Priorité : optionnel
Section : net
Responsable : Debian BOINC Maintainers pkg-boinc-devel@lists.alioth.debian.org
Taille décompressée : 646k
Dépend: libc6 (>= 2.3.5-1), libcomerr2 (>= 1.33-3), libcurl3 (>= 7.15.2-2), libgcc1 (>= 1:4.0.2), libidn11 (>= 0.5.18), libkrb53 (>= 1.4.2), libssl0.9.8
(>= 0.9.8a-1), libstdc++6 (>= 4.0.2-4), zlib1g (>= 1:1.2.1), adduser, lsb-base (>= 3.0-6)
Suggère: boinc-manager | kboincspy
Description : BOINC core client
This package contains the BOINC core client program, that is required to participate in any project that uses BOINC.
The Berkeley Open Infrastructure for Network Computing (BOINC) is a software platform for distributed computing. A central server distributes work units
and collects results via this client. When attaching a local machine to a project, this client will also dynamically download the projects application’s
program to be then wrapped by the BOINC core client.
Homepage: http://boinc.berkeley.edu[/code]
Tiens, bonne idée, moi qui en avait marre de chercher les E.T. je vais m’engager pour autre chose … :stuck_out_tongue:
Quelqu’un a compris comment ca fonctionne?
Je me suis attaché un projet en utilisant le run_manager.
Mais pour l’utilisation courante, que faut-il executer? Si je lance le run_client, j’ai bien un process gweather-applet, mais aucune activité processeur. Par contre, si je lance run_manager, ca tourne…
A quoi sert le run_client dans ce cas?
Perso je laisse tourner SETI depuis un bon moment…
Il est vrai Jabba que chercher les ET est lassant, mais bon…
Mais il est aussi vrai MattOTop, que permettre de faire avancer la recherche des rotations de molecules ou à la lutte contre la malaria ai une bonne raison de mettre nos CPU à leur dispo.
Je vais tester cela.
PoL
Salut jabba … où étais-tu lol ? tu en as capturé ? :wink:
Oui ça me plait bien, tout est dans la doc, ou bien faut un peu se creuser pour se dévouer ? non, je dis ça comme ça … mais partant voui .
