[quote=“Mimoza”]peut tu me montrer la réponse aux la commande suivante :
iptables -L
netstat -taupe
[/quote][code]root@x4-955:/home/frederic# iptables -L
Chain INPUT (policy DROP)
target prot opt source destination
ufw-before-logging-input all – anywhere anywhere
ufw-before-input all – anywhere anywhere
ufw-after-input all – anywhere anywhere
ufw-after-logging-input all – anywhere anywhere
ufw-reject-input all – anywhere anywhere
ufw-track-input all – anywhere anywhere
Chain FORWARD (policy DROP)
ufw-before-logging-forward all – anywhere anywhere
ufw-before-forward all – anywhere anywhere
ufw-after-forward all – anywhere anywhere
ufw-after-logging-forward all – anywhere anywhere
ufw-reject-forward all – anywhere anywhere
Chain OUTPUT (policy ACCEPT)
ufw-before-logging-output all – anywhere anywhere
ufw-before-output all – anywhere anywhere
ufw-after-output all – anywhere anywhere
ufw-after-logging-output all – anywhere anywhere
ufw-reject-output all – anywhere anywhere
ufw-track-output all – anywhere anywhere
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
ufw-skip-to-policy-input udp – anywhere anywhere udp dpt:netbios-ns
ufw-skip-to-policy-input udp – anywhere anywhere udp dpt:netbios-dgm
ufw-skip-to-policy-input tcp – anywhere anywhere tcp dpt:netbios-ssn
ufw-skip-to-policy-input tcp – anywhere anywhere tcp dpt:microsoft-ds
ufw-skip-to-policy-input udp – anywhere anywhere udp dpt:bootps
ufw-skip-to-policy-input udp – anywhere anywhere udp dpt:bootpc
ufw-skip-to-policy-input all – anywhere anywhere ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
LOG all – anywhere anywhere limit: avg 3/min burst 10 LOG level warning prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
Chain ufw-after-logging-output (1 references)
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
ufw-user-forward all – anywhere anywhere
Chain ufw-before-input (1 references)
ACCEPT all – anywhere anywhere
ACCEPT all – anywhere anywhere state RELATED,ESTABLISHED
ufw-logging-deny all – anywhere anywhere state INVALID
DROP all – anywhere anywhere state INVALID
ACCEPT icmp – anywhere anywhere icmp destination-unreachable
ACCEPT icmp – anywhere anywhere icmp source-quench
ACCEPT icmp – anywhere anywhere icmp time-exceeded
ACCEPT icmp – anywhere anywhere icmp parameter-problem
ACCEPT icmp – anywhere anywhere icmp echo-request
ACCEPT udp – anywhere anywhere udp spt:bootps dpt:bootpc
ufw-not-local all – anywhere anywhere
ACCEPT udp – anywhere 224.0.0.251 udp dpt:mdns
ACCEPT udp – anywhere 239.255.255.250 udp dpt:1900
ufw-user-input all – anywhere anywhere
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-output (1 references)
ufw-user-output all – anywhere anywhere
Chain ufw-logging-allow (0 references)
LOG all – anywhere anywhere limit: avg 3/min burst 10 LOG level warning prefix "[UFW ALLOW] "
Chain ufw-logging-deny (2 references)
RETURN all – anywhere anywhere state INVALID limit: avg 3/min burst 10
Chain ufw-not-local (1 references)
RETURN all – anywhere anywhere ADDRTYPE match dst-type LOCAL
RETURN all – anywhere anywhere ADDRTYPE match dst-type MULTICAST
RETURN all – anywhere anywhere ADDRTYPE match dst-type BROADCAST
ufw-logging-deny all – anywhere anywhere limit: avg 3/min burst 10
Chain ufw-reject-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-skip-to-policy-input (7 references)
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
ACCEPT tcp – anywhere anywhere state NEW
ACCEPT udp – anywhere anywhere state NEW
Chain ufw-user-forward (1 references)
Chain ufw-user-input (1 references)
ACCEPT tcp – anywhere anywhere tcp dpt:9091
ACCEPT udp – anywhere anywhere udp dpt:9091
ACCEPT tcp – anywhere anywhere multiport dports 20500:20599
ACCEPT udp – anywhere anywhere multiport dports 20500:20599
ACCEPT udp – anywhere anywhere udp dpt:1900
ACCEPT tcp – anywhere anywhere tcp dpt:49152
ACCEPT udp – anywhere anywhere udp dpt:49152
ACCEPT tcp – anywhere anywhere tcp dpt:ntp
ACCEPT udp – anywhere anywhere udp dpt:ntp
Chain ufw-user-limit (0 references)
LOG all – anywhere anywhere limit: avg 3/min burst 5 LOG level warning prefix "[UFW LIMIT BLOCK] "
REJECT all – anywhere anywhere reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-output (1 references)
root@x4-955:/home/frederic#[/code]
root@x4-955:/home/frederic# netstat -taupe
Connexions Internet actives (serveurs et établies)
Proto Recv-Q Send-Q Adresse locale Adresse distante Etat User Inode PID/Program name
tcp 0 0 *:53421 *:* LISTEN statd 6785 2004/rpc.statd
tcp 0 0 *:sunrpc *:* LISTEN root 6705 1941/rpcbind
tcp 0 0 localhost:ipp *:* LISTEN root 19541 3039/cupsd
tcp 0 7 x4-955.home:54034 pop.gmx.com:pop3 LAST_ACK root 0 -
tcp 0 0 x4-955.home:36420 wi-in-f138.1e100.:https ESTABLISHED frederic 67498 3829/iceweasel
tcp 0 0 x4-955.home:49342 wi-in-f190.1e100.:https ESTABLISHED frederic 67495 3829/iceweasel
tcp6 0 0 [::]:sunrpc [::]:* LISTEN root 6712 1941/rpcbind
tcp6 0 0 localhost:ipp [::]:* LISTEN root 19540 3039/cupsd
tcp6 0 0 [::]:50112 [::]:* LISTEN statd 6788 2004/rpc.statd
udp 0 0 *:56765 *:* avahi 7023 2908/avahi-daemon:
udp 0 0 *:bootpc *:* root 8216 3102/dhclient
udp 0 0 *:sunrpc *:* root 6701 1941/rpcbind
udp 0 0 *:ipp *:* root 19544 3039/cupsd
udp 0 0 *:53939 *:* root 9219 3102/dhclient
udp 0 0 *:842 *:* root 6704 1941/rpcbind
udp 0 0 localhost:908 *:* root 3913 2004/rpc.statd
udp 0 0 *:mdns *:* avahi 7021 2908/avahi-daemon:
udp 0 0 *:58760 *:* statd 3917 2004/rpc.statd
udp 0 0 *:1900 *:* root 7152 3097/minissdpd
udp6 0 0 [::]:sunrpc [::]:* root 6708 1941/rpcbind
udp6 0 0 [::]:20607 [::]:* root 9220 3102/dhclient
udp6 0 0 [::]:32904 [::]:* statd 3920 2004/rpc.statd
udp6 0 0 [::]:842 [::]:* root 6711 1941/rpcbind
udp6 0 0 [::]:mdns [::]:* avahi 7022 2908/avahi-daemon:
udp6 0 0 [::]:42711 [::]:* avahi 7024 2908/avahi-daemon:
[quote]
Sinon j’ai trouvé cette page qui a une commande un peu plus précise pour les logs Evolution
CAMEL_VERBOSE_DEBUG=1 evolution-mail
[/quote]Commande inconnue !
Ce devait correspondre aux versions antérieures d’Evolution (Fev 2003 !).
