Failed to start raise network interfaces
Tags: #<Tag:0x00007f46acb0aaa0>
Bonjour, depuis le debut de mon instalation de debian 11 , lors du POST , au moment du boot , j’ ai un message qui apparait en rouge : failed to start raise network interfaces :
iznobe@iznobe-PC:~$ sudo systemctl status networking.service
● networking.service - Raise network interfaces
     Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Sun 2021-11-14 08:48:34 CET; 2min 14s ago
       Docs: man:interfaces(5)
    Process: 728 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
   Main PID: 728 (code=exited, status=1/FAILURE)
        CPU: 90ms
nov. 14 08:48:34 iznobe-PC dhclient[798]: than a configuration issue please read the section on submitting
nov. 14 08:48:34 iznobe-PC dhclient[798]: bugs on either our web page at www.isc.org or in the README file
nov. 14 08:48:34 iznobe-PC dhclient[798]: before submitting a bug.  These pages explain the proper
nov. 14 08:48:34 iznobe-PC dhclient[798]: process and the information we find helpful for debugging.
nov. 14 08:48:34 iznobe-PC dhclient[798]: exiting.
nov. 14 08:48:34 iznobe-PC ifup[728]: ifup: failed to bring up eth0
nov. 14 08:48:34 iznobe-PC systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
nov. 14 08:48:34 iznobe-PC systemd[1]: networking.service: Failed with result 'exit-code'.
nov. 14 08:48:34 iznobe-PC systemd[1]: Failed to start Raise network interfaces.
Je ne comprends pas vraiment ce que cela veut dire , ni comment resoudre le soucis
La conexion semble pourtant bien fonctionnée :
iznobe@iznobe-PC:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
    inet6 ::1/128 scope host
2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 2c:f0:5d:29:20:f2 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.2/24 brd 192.168.1.255 scope global noprefixroute enp2s0
    inet6 2a02:8440:5316:f527:14de:396a:e324:2/128 scope global dynamic noprefixroute
       valid_lft 6536sec preferred_lft 2936sec
    inet6 fd14:de39:6ae3:2400:29b2:5662:d2ab:db59/64 scope global dynamic noprefixroute
       valid_lft 6930sec preferred_lft 3330sec
    inet6 2a02:8440:5316:f527:d9f3:c13e:e546:dbcb/64 scope global dynamic noprefixroute
    inet6 fe80::753a:d514:5c3b:8685/64 scope link noprefixroute
iznobe@iznobe-PC:~$
qu ’ en pensez vous ?
Vérifie s’il y a un fichier /etc/network/interfaces.d/setup qui contient une définition de l’interface eth0 (inexistante). Si c’est le cas, il suffit de le supprimer. Comment l’installation a-t-elle été faite ? Avec l’installateur classique lancé depuis le menu de démarrage de l’image ISO ou avec l’installateur alternatif Calamares lancé depuis une session live ? Quel environnement de bureau a été installé ?
Bonjour PascalHambourg
l ’ environnement Graphique est cinnamon .
l ’ installation a été effectuée a partir d ’ une cle USB a partir de la session live .
iznobe@iznobe-PC:~$ cat /etc/network/interfaces.d/setup
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
iznobe@iznobe-PC:~$
je supprime donc le fichier completement avec la commande : sudo rm /etc/network/interfaces.d/setup ou bien j ’ edite le fichier pour commenter les 2 dernieres lignes et enlever les references eth0 dans ce fichier ?
Ça confirme ma suspicion que ce bug est introduit par l’installateur Calamares. Je n’ai jamais utilisé cet installateur, et je n’ai jamais eu ce bug. Le pire, c’est qu’il suffirait de remplacer « auto » par « allow-hotplug » pour supprimer l’erreur.
Tu peux supprimer le fichier entier. La définition de l’interface de loopback est déjà présente dans le fichier /etc/network/interfaces.
ok , merci pour les infos , je fais ca desuite , bon dimanche a toi !
