Si c’est un ipod touch, il y a ifuse qui permet de le monter comme un système de fichier:
[quote]iFuse is a FUSE filesystem driver which uses libiphone to connect to iPhone
and iPod Touch devices without needing to “jailbreak” them. iFuse uses the
native Apple AFC protocol over a normal USB cable in order to access the
device’s media files.
Although iFuse is now in a working state it is still under heavy
development and should be considered experimental.[/quote]
Sinon apt-cache search ipod crache pas mal de solutions, à tester ou se renseigner… sur ce forum par exemple
gnupod-tools - command-line tools for the iPod family of portable music players
gtkpod - manage songs and playlists on an Apple iPod
ifuse - FUSE module for iPhone and iPod Touch devices
ipod - tool for retrieving informations from iPods
podsleuth - Tool to discover detailed information about Apple iPods
hipo - Outil de gestion du iPod
tripgtkpod-aac - manage songs and playlists on an Apple iPod
tripod - iPod photo uploader
