[quote=“sabrinouche”][quote=“BorisTheButcher”]Non non, ricardo te propose de démarrer avec un cd bootable knoppix (il faut probablement que tu le grave)
Pas de reinstalle pour le moment, loin de nous cette idée! [/quote]
euh… j’ai pas ça sous la main.
j’ai fait un update et qq trucs ont echoué alors il dit kil reprend les anciens fichiers.
j’avais deja relancé l’install de gnome avant que vous me repondiez alors j’ai rebooté et on va voir ce que ça donne mais je suis sceptique [/quote]
Bon bein même souci apres reinstall de gnome : les fichiers de log disent (entre autre) ceci :
Aug 29 15:41:36 localhost kernel: PIIX4: not 100%% native mode: will probe irqs later
Aug 29 15:41:36 localhost kernel: ide0: BM-DMA at 0xfcd0-0xfcd7, BIOS settings: hda:pio, hdb:pio
Aug 29 15:41:36 localhost kernel: hdb: attached ide-scsi driver.
Aug 29 15:41:36 localhost kernel: scsi2 : SCSI host adapter emulation for IDE ATAPI devices
Aug 29 15:41:36 localhost kernel: Vendor: IOMEGA Model: ZIP 100 Rev: 12.A
Aug 29 15:41:36 localhost kernel: Type: Direct-Access ANSI SCSI revision: 00
Aug 29 15:41:36 localhost kernel: Attached scsi removable disk sdc at scsi2, channel 0, id 0, lun 0
Aug 29 15:41:36 localhost kernel: sdc: Unit Not Ready, sense:
Aug 29 15:41:36 localhost kernel: Current 00:00: sense key Not Ready
Aug 29 15:41:36 localhost kernel: Additional sense indicates Medium not present
Aug 29 15:41:36 localhost kernel: sdc : READ CAPACITY failed.
Aug 29 15:41:36 localhost kernel: sdc : status = 0, message = 00, host = 0, driver = 28
Aug 29 15:41:36 localhost kernel: Current sd00:00: sense key Not Ready
Aug 29 15:41:36 localhost kernel: sdc : block size assumed to be 512 bytes, disk size 1GB.
Aug 29 15:41:36 localhost kernel: /dev/scsi/host2/bus0/target0/lun0: I/O error: dev 08:20, sector 0
Aug 29 15:41:36 localhost kernel: I/O error: dev 08:20, sector 0
Aug 29 15:41:36 localhost kernel: unable to read partition table
Aug 29 15:41:36 localhost kernel: usb.c: registered new driver usbdevfs
Aug 29 15:41:36 localhost kernel: usb.c: registered new driver hub
Aug 29 15:41:36 localhost kernel: usb-uhci.c: $Revision: 1.275 $ time 09:50:48 Aug 17 2005
Aug 29 15:41:36 localhost kernel: usb-uhci.c: High bandwidth mode enabled
Aug 29 15:41:36 localhost kernel: usb-uhci.c: USB UHCI at I/O 0xfce0, IRQ 19
Aug 29 15:41:36 localhost kernel: usb-uhci.c: Detected 2 ports
Aug 29 15:41:36 localhost kernel: usb.c: new USB bus registered, assigned bus number 1
Aug 29 15:41:36 localhost kernel: hub.c: USB hub found
Aug 29 15:41:36 localhost kernel: hub.c: 2 ports detected
Aug 29 15:41:36 localhost kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
Aug 29 15:41:36 localhost kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Aug 29 15:41:36 localhost kernel: uhci.c: USB Universal Host Controller Interface driver v1.1
Aug 29 15:41:36 localhost kernel: eth1: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug 29 15:41:38 localhost kernel: Universal TUN/TAP device driver 1.5 ©1999-2002 Maxim Krasnyansky
Aug 29 15:41:40 localhost kernel: parport0: PC-style at 0x378 (0x778) [PCSPP,TRISTATE,EPP]
Aug 29 15:41:40 localhost kernel: parport0: irq 7 detected
Aug 29 15:41:41 localhost kernel: lp0: using parport0 (polling).
Aug 29 15:41:52 localhost kernel: apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16)
Aug 29 15:42:13 localhost gconfd (root-1333): démarrage (version 2.8.1), pid 1333 utilisateur «| root| »
Aug 29 15:42:13 localhost gconfd (root-1333): Adresse «| xml:readonly:/etc/gconf/gconf.xml.mandatory| » résolue vers une source de configuration en lecture seule à la position 0
Aug 29 15:42:13 localhost gconfd (root-1333): Adresse «| xml:readwrite:/root/.gconf| » résolue vers une source de configuration accessible en écriture à la position 1
Aug 29 15:42:13 localhost gconfd (root-1333): Adresse «| xml:readonly:/etc/gconf/gconf.xml.defaults| » résolue vers une source de configuration en lecture seule à la position 2
