Gsetting get ne donne pas les valeurs de la configuration dconf
Tags: #<Tag:0x00007f46b2d52e60> #<Tag:0x00007f46b2d52d98> #<Tag:0x00007f46b2d52ca8>
j’ai un script qui modifie la configuration gdm dans dconf.
/etc/dconf/db/gdm
/etc/dconf/db/gdm.d
/etc/dconf/db/gdm.d/00-login-screen
/etc/dconf/db/gdm.d/01-banner-message
/etc/dconf/profile/gdm
le profile:
# cat /etc/dconf/profile/gdm
user-db:user
system-db:gdm
file-db:/usr/share/gdm/greeter-dconf-defaults
Les keyfiles:
# cat /etc/dconf/db/gdm.d/00-login-screen
[org/gnome/login-screen]
disable-user-list=true
# cat /etc/dconf/db/gdm.d/01-banner-message
banner-message-enable=true
banner-message-text='This system is for the use of authorized users only.\n\nAll connections are monitored and recorded.\n\nAnyone using this system expressly consents to such monitoring\nand is advised that if such monitoring reveals possible\nevidence of criminal activity, system personnel may provide the\nevidence from such monitoring to law enforcement officials.\n\n ! Disconnect IMMEDIATELY if you are not an authorized user. ! \n\nAll requests can be sent to admin@enedwaith.org'
Tout est fonctionnel, j’ai bien la conf qui fonctionne dans GDM (la bannière s’affiche et la liste des user n’apparaît pas).
