Help! je n'ai plus de son avec mplayer [résolu]
j’ai installé avidemux et kino sur ma debian sarge
et depuis je n’ai plus de son lorsque j’utilise mplayer
Merci beaucoup de m’aider; svp
voici les messages d’erreur
mplayer toto.mp3
MPlayer 1.0pre8-3.3.5 © 2000-2006 MPlayer Team
CPU: mobile AMD Athlon™ XP 1600+ (Family: 6, Model: 8, Stepping: 1)
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
Compiled with runtime CPU detection.
Failed to open /dev/rtc: Permission denied (it should be readable by the user.)
Opening joystick device /dev/input/js0
Can’t open joystick device /dev/input/js0: Permission denied
Can’t init input joystick
Setting up LIRC support…
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support.
You will not be able to use your remote control.
Playing toto.mp3.
Audio file file format detected.
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 44100 Hz, 2 ch, s16le, 128.0 kbit/9.07% (ratio: 16000->176400)
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
alsa-init: using device default
alsa-lib: confmisc.c:550:(snd_determine_driver) could not open control for card 0
alsa-lib: conf.c:3461:(_snd_config_evaluate) function snd_func_card_driver retur ned error: No such file or directory
alsa-lib: confmisc.c:387:(snd_func_concat) error evaluating strings
alsa-lib: conf.c:3461:(_snd_config_evaluate) function snd_func_concat returned e rror: No such file or directory
alsa-lib: confmisc.c:945:(snd_func_refer) error evaluating name
alsa-lib: conf.c:3461:(_snd_config_evaluate) function snd_func_refer returned er ror: No such file or directory
alsa-lib: conf.c:3930:(snd_config_expand) Evaluate error: No such file or direct ory
alsa-lib: pcm.c:2068:(snd_pcm_open_noupdate) Unknown PCM default
alsa-init: playback open error: No such file or directory
Could not open/initialize audio device -> no sound.
Audio: no sound
Video: no video
Oui, ben à coup sur tu essayes de lire un mp3 télécharché chez un windaubien :smiling_imp:
je viens de faire l’expérience :
Auto-destruction des traces d'existence de fichiers partagés ... Opération effectuée en raison de lois à la con ..... Opération terminée ....
Où on voit que la modification de /proc/sys/dev/rtc/max-user-freq pour remplacer la valeur 64 (que je vais remettre) par 1024 n’a rien changé…
Où on voit que c’est pas esd le fauteur de trouble …
Où on voit que le nom de fichier doit être donné avec le caractère d’échappement devant les espaces …
Quoique, chez toi, il se peut que ce soit un autre probleme, mais pas de droits je pense pas, ptête un killallesd, vu le Sound: no sound ?
Tu as du son quand tu le lance en graphique ?
ps: lis vite, je vais pas le laisser longtemps ce post héhé :smiling_imp:
non pas de son quand je lance en graphique
:confused:
re-,
ben dis nous comment tu as configuré dans prérérence de mplayer (ou options) le plugin de sortie audio ? (killall esd ça veut pas non plus ?).
me dis pas que tu as pas lancé un alsaconf et un alsamixer dans la foulée :open_mouth:
[quote]alsa-init: using device default[/quote] comparé à [quote]alsa-init: 1 soundcard found, using: default[/quote] ya comme une différence ;…
alsaconf permet de retourver la carte son … encore faut -il que dans mplayer, tu envoies le son vers elle …
merci pour les réponses
En virant mplayer avec apt-get remove et en virant le dossier dans /etc et dans /home/moi
et réinstallant mplayer, il y a eu un retour à la norme
:wink:
