$ hp-check -r
HP Linux Imaging and Printing System (ver. 3.12.6)
Dependency/Version Check Utility ver. 15
Copyright © 2001-14 Hewlett-Packard Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Note: hp-check can be run in three modes:
- Compile-time check mode (-c or --compile): Use this mode before compiling the HPLIP supplied tarball (.tar.gz or .run) to determine if
the proper dependencies are installed to successfully compile HPLIP.
- Run-time check mode (-r or --run): Use this mode to determine if a distro supplied package (.deb, .rpm, etc) or an already built HPLIP
supplied tarball has the proper dependencies installed to successfully run.
- Both compile- and run-time check mode (-b or --both) (Default): This mode will check both of the above cases (both compile- and run-time
dependencies).
Check types:
a. EXTERNALDEP - External Dependencies
b. GENERALDEP - General Dependencies (required both at compile and run time)
c. COMPILEDEP - Compile time Dependencies
d. [All are run-time checks]
PYEXT SCANCONF QUEUES PERMISSION
Status Types:
OK
MISSING - Missing Dependency or Permission or Plug-in
INCOMPAT - Incompatible dependency-version or Plugin-version
Saving output in log file: /home/intervenant100/hp-check.log
Initializing. Please wait…
warning: debian-7.11 version is not supported. Using debian-6.0.5 versions dependencies to verify and install…
Kernel: 3.2.0-4-powerpc-smp #1 SMP Debian 3.2.78-1 GNU/Linux
Host: tapez-votre-commande-shell
Proc: 3.2.0-4-powerpc-smp #1 SMP Debian 3.2.78-1 GNU/Linux
Distribution: debian 7.11
HPLIP-Version: HPLIP 3.12.6
HPLIP-Home: /usr/share/hplip
warning: HPLIP-Installation: Auto installation is not supported for debian distro 7.11 version
Current contents of ‘/etc/hp/hplip.conf’ file:
hplip.conf. Generated from hplip.conf.in by configure.
[hplip]
version=3.12.6
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hplip/HP
ppdbase=/usr/share/ppd/hplip
doc=/usr/share/doc/hplip-doc/HTML
icon=no
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv
Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
libusb01-build=no
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
foomatic-drv-install=yes
foomatic-ppd-install=yes
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.12.6
restricted-build=no
ui-toolkit=qt4
qt3=no
qt4=yes
policy-kit=yes
hpijs-only-build=no
lite-build=no
udev-acl-rules=yes
udev_sysfs_rules=no
hpcups-only-build=no
hpijs-only-build=no
Current contents of ‘/var/lib/hp/hplip.state’ file:
Plugins are not installed. Could not access file: Aucun fichier ou dossier de ce type
Current contents of ‘~/.hplip/hplip.conf’ file:
[last_used]
device_uri = hp:/usb/Officejet_J4500_series?serial=CN96HC905J052T
printer_name = Officejet_J4500_fax
working_dir = .
[settings]
systray_visible = 0
systray_messages = 0
[commands]
scan = /usr/bin/simple-scan %SANE_URI%
[refresh]
rate = 30
enable = false
type = 1
[polling]
enable = false
interval = 5
device_list =
[fax]
voice_phone =
email_address =
[upgrade]
notify_upgrade = false
last_upgraded_time = 1472300789.19851
pending_upgrade_time = 0
[installation]
date_time = 28/08/2016 15:17:56
version = 3.12.6
<Required/Optional>
gs Ghostscript REQUIRED 7.05 9.05 OK -
network Network-wget OPTIONAL - 1.13.4 OK -
dbus DBus REQUIRED - 1.6.8 OK -
scanimage Shell-Scanning OPTIONAL 1.0 1.0.22 OK -
policykit Admin-Policy-framework OPTIONAL - 0.105 OK -
xsane SANE-GUI OPTIONAL 0.9 0.998 OK -
cups CUPS REQUIRED 1.1 1.5.3 OK ‘CUPS Scheduler is running’
reportlab Python-PDF-Lib OPTIONAL 2.0 2.5 OK -
libcrypto OpenSSL-Crypto-Lib REQUIRED - 1.0.1 OK -
pil Python-Image-Lib OPTIONAL - 1.1.7 OK -
pyqt4-dbus PyQt4-DBUS REQUIRED 4.0 4.9.3 OK -
libjpeg JPEG-Lib REQUIRED - - OK -
libpthread POSIX-Threads-Lib REQUIRED - 2.13 OK -
python-dbus Python-DBUS REQUIRED 0.80.0 1.1.1 OK -
python-devel Python-SDK REQUIRED 2.2 2.7.3 OK -
pyqt4 Python-Qt4 REQUIRED 4.0 4.9.3 OK -
cups-devel CUPS-SDK REQUIRED - 1.5.3 OK -
sane-devel SANE-SDK REQUIRED - 1.0.22 OK -
libusb USB-Lib REQUIRED - 1.0 OK -
sane Scan-Lib REQUIRED - 1.0.22 OK -
cups-image CUPS-Image-Lib REQUIRED - 1.5.3 OK -
libnetsnmp-devel SNMP-Networking-SDK REQUIRED 5.0.9 5.4.3 OK -
python-xml Python-XML-Lib REQUIRED - 2.1.0 OK -
python-notify Desktop-notifications OPTIONAL - - OK -
cupsext CUPS-Extension REQUIRED - 3.12.6 OK -
pcardext PhotoCard-Extension REQUIRED - 3.12.6 OK -
hpmudext IO-Extension REQUIRED - 3.12.6 OK -
hpaio HPLIP-SANE-Backend REQUIRED - 3.12.6 OK 'hpaio found in /etc/sane.d/dll.conf’
scanext Scan-SANE-Extension REQUIRED - 3.12.6 OK -
DISCOVERED SCANNER DEVICES |
p11-kit: invalid config filename, will be ignored in the future: /etc/pkcs11/modules/gnome-keyring-module
device `hpaio:/usb/Officejet_J4500_series?serial=CN96HC905J052T’ is a Hewlett-Packard Officejet_J4500_series all-in-one
Device URI Model
hp:/usb/Officejet_J4500_series?serial=CN96HC905J052T HP Officejet J4500 series
INSTALLED CUPS PRINTER QUEUES |
p11-kit
Type: Unknown
Device URI: invalid config filename, will be ignored in the future: /etc/pkcs11/modules/gnome-keyring-module
Officejet_J4500
Type: Printer
Device URI: hp:/usb/Officejet_J4500_series?serial=CN96HC905J052T
PPD: /etc/cups/ppd/Officejet_J4500.ppd
PPD Description: HP Officejet j4500 Series, hpcups 3.12.6
printer Officejet_J4500 is idle. enabled since ven. 19 août 2016 16:32:39 CEST: /etc/pkcs11/modules/gnome-keyring-module
Communication status: Good
Officejet_J4500_fax
Type: Fax
Device URI: hpfax:/usb/Officejet_J4500_series?serial=CN96HC905J052T
PPD: /etc/cups/ppd/Officejet_J4500_fax.ppd
PPD Description: HP Fax hpcups
printer Officejet_J4500_fax is idle. enabled since ven. 19 août 2016 16:32:29 CESTtc/pkcs11/modules/gnome-keyring-module
groups user-groups Required - - OK intervenant100 lp cdrom floppy audio dip video plugdev scanner lpadmin bluetooth netdev
USB Officejet_J4500 Required - - OK Node:’/dev/bus/usb/001/004’ Perm:’ root lp --t rw- rw- rw- rw- r–’
Missing Required Dependencies
None
Missing Optional Dependencies
None
Total Errors: 0
Total Warnings: 0
No errors or warnings.
Done.
