Impossible de se connecter au serveur ftp Gadmin Proftpd [Abondonné]
Tags: #<Tag:0x00007fb41aa4afa8>
Bonjour , depuis hier je n’arrive plus a me connecter au serveur ftp, Je recois cette erreur avec FileZilla ( en local sur vps debian 8 proftpd 4.2 )
Status: Connection established, waiting for welcome message…
Response: 220 My FTP Server
Command: USER user1
Response: 331 Password required for user1
Command: PASS ******
Response: 530-Unable to set anonymous privileges.
Response: 530 Login incorrect.
Error: Critical error: Could not connect to server
Ma config proftpd :
ServerType standalone
DefaultServer on
Umask 022
ServerName "0.0.0.0"
ServerIdent on "My FTP Server"
ServerAdmin email@example.org
IdentLookups off
UseReverseDNS off
Port 21
PassivePorts 49152 65534
#MasqueradeAddress None
TimesGMT off
MaxInstances 30
MaxLoginAttempts 3
TimeoutLogin 300
TimeoutNoTransfer 120
TimeoutIdle 120
DisplayLogin welcome.msg
DisplayChdir .message
User nobody
Group nobody
DirFakeUser off nobody
DirFakeGroup off nobody
DefaultTransferMode binary
AllowForeignAddress off
AllowRetrieveRestart on
AllowStoreRestart on
DeleteAbortedStores off
TransferRate RETR 220
TransferRate STOR 250
TransferRate STOU 250
TransferRate APPE 250
SystemLog /var/log/secure
RequireValidShell off
TLSEngine off
TLSRequired off
TLSVerifyClient off
TLSProtocol SSLv23
TLSLog /var/log/proftpd_tls.log
TLSRSACertificateFile /etc/gadmin-proftpd/certs/cert.pem
TLSRSACertificateKeyFile /etc/gadmin-proftpd/certs/key.pem
TLSCACertificateFile /etc/gadmin-proftpd/certs/cacert.pem
TLSRenegotiate required off
TLSOptions AllowClientRenegotiation
Ratios off
SaveRatios off
RatioFile "/restricted/proftpd_ratios"
RatioTempFile "/restricted/proftpd_ratios_temp"
CwdRatioMsg "Please upload first!"
FileRatioErrMsg "FileRatio limit exceeded, upload something first…"
ByteRatioErrMsg "ByteRatio limit exceeded, upload something first…"
LeechRatioMsg "Your ratio is unlimited."
AllowUser test
DenyALL
<Anonymous /root/srv/t/crashdumps>
User test
Group testg
AnonRequirePassword on
MaxClients 10 "The server is full, hosting %m users"
DisplayChdir .msg
Allow from All
Deny from all
AllowOverwrite off
AllowAll
DenyAll
Je pense avoir recus cette erreur apres avoir configurer des “virtual host” en suivant ce tuto si c’est ca la cause .
Merci de m’aider car j’ai vraiment besoin du serveur ftp pour transferer des fichiers.
Finalement j’ai abondonné gadmin proftpd pour utiliser sftp & ssh qui est par defaut present . en plus mnt je suis securisé :smiley:
il existe mysecureshell si tu veux des options complémentaires…
D’accord merci je vais voir. Bonsoir :slight_smile:
voilà qui est sage.
