Impossible d'installer le pilote ati
Bonjour depuis la mis a jours du kernel en 2.6.32 qui c’est produit hier sur debian testing je n’arrive plus a installer le pilote ati de ma carte graphique jai tout d’abord essaye avec le .run du site d’amd voici le log :
[Message] Kernel Module : Trying to install a precompiled kernel module. [Message] Kernel Module : Precompiled kernel module version mismatched. [Message] Kernel Module : Found kernel module build environment, generating kernel module now. AMD kernel module generator version 2.1 doing Makefile based build for kernel 2.6.x and higher rm -rf *.c *.h *.o *.ko *.GCC* .??* *.symvers make -C /lib/modules/2.6.32-trunk-amd64/build SUBDIRS=/lib/modules/fglrx/build_mod/2.6.x modules make[1]: entrant dans le répertoire « /usr/src/linux-headers-2.6.32-trunk-amd64 » CC [M] /lib/modules/fglrx/build_mod/2.6.x/firegl_public.o In file included from /lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:443: /lib/modules/fglrx/build_mod/2.6.x/drm_proc.h: In function ‘FGLDRM__vma_info’: /lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:497: warning: format ‘%08lx’ expects type ‘long unsigned int’, but argument 5 has type ‘phys_addr_t’ CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_acpi.o CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_agp.o CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_debug.o CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.o CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_io.o /lib/modules/fglrx/build_mod/2.6.x/kcl_io.c: In function ‘KCL_IO_FASYNC_Terminate’: /lib/modules/fglrx/build_mod/2.6.x/kcl_io.c:122: error: ‘SIGIO’ undeclared (first use in this function) /lib/modules/fglrx/build_mod/2.6.x/kcl_io.c:122: error: (Each undeclared identifier is reported only once /lib/modules/fglrx/build_mod/2.6.x/kcl_io.c:122: error: for each function it appears in.) make[4]: *** [/lib/modules/fglrx/build_mod/2.6.x/kcl_io.o] Erreur 1 make[3]: *** [_module_/lib/modules/fglrx/build_mod/2.6.x] Erreur 2 make[2]: *** [sub-make] Erreur 2 make[1]: *** [all] Erreur 2 make[1]: quittant le répertoire « /usr/src/linux-headers-2.6.32-trunk-amd64 » make: *** [kmod_build] Erreur 2 build failed with return value 2 [Error] Kernel Module : Failed to compile kernel module - please consult readme.
puis avec les packet fourni sur debian :
[code]debian:/home/ls2003/Téléchargements# aptitude install fglrx-control fglrx-driver module-assistant
Lecture de l’information d’état étendu… Fait
Initialisation de l’état des paquets… Fait
Lecture des descriptions de tâches… Fait
dkms{a} fglrx-atieventsd{a} fglrx-control fglrx-driver fglrx-glx{a} fglrx-glx-ia32{a}
fglrx-modules-dkms{a} ia32-libs{a} lib32asound2{a} lib32gcc1{a} lib32ncurses5{a} lib32stdc++6{a}
lib32z1{a} libaudio2{a} libmysqlclient16{a} libqt4-dbus{a} libqt4-designer{a} libqt4-network{a}
libqt4-qt3support{a} libqt4-script{a} libqt4-sql{a} libqt4-sql-mysql{a} libqt4-xml{a} libqtcore4{a}
libqtgui4{a} mysql-common{a} qt4-qtconfig{a}
0 paquets mis à jour, 27 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 74,3Mo d’archives. Après dépaquetage, 210Mo seront utilisés.
Les paquets suivants ont des dépendances non satisfaites :
xserver-xorg-core: Est en conflit avec: xserver-xorg-video-5 qui est un paquet virtuel
 Conserver les paquets suivants dans leur version actuelle :
  1. fglrx-control [Non installé]
  2. fglrx-driver [Non installé]
  3. fglrx-glx [Non installé]
  4. fglrx-glx-ia32 [Non installé]
    Laisser les dépendances suivantes non satisfaites :
  5. fglrx-atieventsd recommande fglrx-driver (= 1:9-12-1)
    Tier: Actions sûres, Supprimer des paquets (10000)
Accepter cette solution ? [Y/n/q/?]
pouvais vous m’aider svp merci …
Il m’est arrivé la même chose et la seule solution que j’ai trouvé c’est …
…de booter sur le noyau 2.6.30.2 :confused: ( en attendant que le trunk soit dé-tronqué)
:smt006
probleme deja resolu par l’equipe debian en une journée la je dit chapeau.
il faut commencer par installer l’entêtes du noyau
puis pour installer le pilote il suffit de faire sur le terminal administrateur :
puis
et enfin rebooter
Merci du tuyau
J’essayerai ça
:smt006
bonjour
J’ai voulu suivre les indication données plus haut mais je rencontre un soucis:
Jusque la tout va bien je n’ai aucun soucis.
Mais avec la commande suivante:
j’obtiens
[code]Tofu:/home/disciple# aptitude install fglrx-control fglrx-driver module-assistant
dkms{a} fakeroot{a} fglrx-atieventsd{a} fglrx-control fglrx-driver
fglrx-glx{a} fglrx-modules-dkms{a} libaudio2{a} libmysqlclient16{a}
libqt4-dbus{a} libqt4-designer{a} libqt4-network{a} libqt4-qt3support{a}
libqtcore4{a} libqtgui4{a} mysql-common{a} qt4-qtconfig{a}
0 paquets mis à jour, 21 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 36,3Mo d’archives. Après dépaquetage, 101Mo seront utilisés.
  4. fglrx-atieventsd recommande fglrx-driver (= 1:9-12-1)
Accepter cette solution ? [Y/n/q/?][/code]
et que doit on faire entre l’installation des paquet et le aticonfig --initial
Merci d’avance
