Je tente en vain d’installer PyQt pour Python 3 sur Debian 6.
L’installation se complique (actuellement) au niveau de la commande make pour sip.
Voici un extrait du message d’erreur que j’obtiens dans le terminal
[quote]siplib.c: In function ‘sip_api_convert_from_sequence_index’:
siplib.c:5279: error: ‘PyExc_IndexError’ undeclared (first use in this function)
siplib.c: At top level:
siplib.c:5291: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘’ token
siplib.c:5317: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘’ token
siplib.c:10457: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘’ token
siplib.c:10468: error: expected ‘)’ before ‘’ token
siplib.c:10496: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘’ token
siplib.c:10506: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘’ token
siplib.c:10534: error: expected ‘)’ before ‘’ token
siplib.c:10557: error: expected ‘)’ before ‘’ token
siplib.c:10582: error: expected ‘)’ before ‘’ token
siplib.c:10816: error: expected ‘)’ before ‘’ token
siplib.c:10827: error: expected ‘)’ before ‘’ token
siplib.c: In function ‘raiseNoWChar’:
siplib.c:10840: error: ‘PyExc_SystemError’ undeclared (first use in this function)
siplib.c:10849: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘’ token
siplib.c:10882: error: expected ‘)’ before ‘*’ token
make[1]: *** [siplib.o] Erreur 1
make[1]: quittant le répertoire « /home/charlie/Téléchargements/sip-4.12.3/siplib »
make: *** [all] Erreur 2
Si quelqu’un a une petite idée, ça m’intéresse grandement.
D’avance merci.
