bonjour jais essayer d’installer le pilote ati le .run télécharger sur le site ati l’installation se passe sans souci mais au reboot écran noir je ne voi pas d’ou viens ce problème pouvez vous m’aider a trouver une solution pour ce souci ?
merci.
voici le log de l’installation
[code]Unloading radeon module…
Unloading drm module…
[Message] Kernel Module : Trying to install a precompiled kernel module.
[Message] Kernel Module : Precompiled kernel module version mismatched.
[Message] Kernel Module : Found kernel module build environment, generating kernel module now.
AMD kernel module generator version 2.1
doing Makefile based build for kernel 2.6.x and higher
rm -rf *.c *.h *.o .ko .GCC .?? *.symvers
make -C /lib/modules/2.6.32-trunk-amd64/build SUBDIRS=/lib/modules/fglrx/build_mod/2.6.x modules
make[1]: entrant dans le répertoire « /usr/src/linux-headers-2.6.32-trunk-amd64 »
CC [M] /lib/modules/fglrx/build_mod/2.6.x/firegl_public.o
In file included from /lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:443:
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h: In function ‘FGLDRM__vma_info’:
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:497: warning: format ‘%08lx’ expects type ‘long unsigned int’, but argument 5 has type ‘phys_addr_t’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c: In function ‘KCL_SetPageCache_Array’:
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1316: warning: passing argument 1 of ‘KCL_ConvertPageToKernelAddress’ makes pointer from integer without a cast
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.h:325: note: expected ‘void *’ but argument is of type ‘long unsigned int’
CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_acpi.o
CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_agp.o
CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_debug.o
CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.o
CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_io.o
CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_pci.o
CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_str.o
CC [M] /lib/modules/fglrx/build_mod/2.6.x/kcl_wait.o
LD [M] /lib/modules/fglrx/build_mod/2.6.x/fglrx.o
Building modules, stage 2.
MODPOST 1 modules
CC /lib/modules/fglrx/build_mod/2.6.x/fglrx.mod.o
LD [M] /lib/modules/fglrx/build_mod/2.6.x/fglrx.ko
make[1]: quittant le répertoire « /usr/src/linux-headers-2.6.32-trunk-amd64 »
build succeeded with return value 0
duplicating results into driver repository…
done…
You must change your working directory to /lib/modules/fglrx
and then call ./make_install.sh in order to install the built module.
- recreating module dependency list
- trying a sample load of the kernel modules
done.[/code]
