Installation et customization usplash [debian etch/sid]
non, ton inittab a l’air correct. Regardes aussi s’il n’y a pas un /etc/default/usplash, et surtout, il faut voir comment /etc/init.d/usplash fait appel à la commande usplash: est ce que par hasard, il ne rajouterait pas un -c, ou le contraire.
Il n’y a pas de /etc/defaults/usplash, mais un /etc/usplash.conf qui indique la résolution de l’écran usplash.
Tiens, je n’arrive pas à faire fonctionner l’hibernation avec usplash, ça bloque au moment de la lecture de l’image. Quelqu’un a-t-il testé ?
Quant au fichier /etc/init.d/usplash , j’avoue ne pas y voir d’option -c. Voici le mien :
[code]#! /bin/sh
BEGIN INIT INFO
Provides: usplash
Required-Start: $all
Required-Stop: $all
Default-Start: 2 3 4 5
Default-Stop: 0 1 6
Short-Description: Stop and start usplash
Description: This script stops and starts the userspace bootsplash screen.
On start it stops the usplash daemon and on stop it starts it.
This is conter-intuitive, but usplash already got started in
initramfs (early userspace).
END INIT INFO
The usplash script makes sure that usplash exits at the end of
the boot sequence and re-run the console-screen.sh script to make
sure that the console fonts are actually set
Written by Miquel van Smoorenburg miquels@cistron.nl.
Modified for Debian
by Ian Murdock imurdock@gnu.ai.mit.edu.
Version: @(#)skeleton 1.9 26-Feb-2001 miquels@cistron.nl
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
DAEMON=/sbin/usplash
NAME=usplash
DESC=“Userspace bootsplash utility”
test -x $DAEMON || exit 0
set -e
usplash_quit() {
# first some sanity checks if we actually have usplash on the system
# check if usplash is runing and if it does, exit it
# then re-run console-screen.sh because it can’t set console-fonts
# properly while the screen is in graphics mode
# also check if we are ended up in console 8. This means that
# no gdm/kdm/xdm was started (otherwise we would be on vt7).
# It happens when e.g. usplash timed out
if type setupcon >/dev/null 2>&1; then
CONSOLE_SCREEN=
elif [ -x /etc/init.d/console-screen.sh ]; then
CONSOLE_SCREEN=/etc/init.d/console-screen.sh
else
CONSOLE_SCREEN=
fi
if type usplash >/dev/null 2>&1 && grep -q splash /proc/cmdline &&
( pidof usplash > /dev/null || [ “$(fgconsole 2>/dev/null)” = “8” ] ); then
# Clear VT 8 of any console messages
clear >/dev/tty8
	# ask usplash to go away
	usplash_write QUIT
	# wait until it is really gone or kill it if it dosn't exit
	i=0
	while pidof usplash > /dev/null; do
		i=$(($i + 1))
		if [ $i -gt 10 ]; then
			kill -9 `pidof usplash`
			break
		fi
		sleep 1
	done
	# reset all our virtual consoles, yay!
	if [ "$CONSOLE_SCREEN" ]; then
		$CONSOLE_SCREEN
	fi
	if [ "$(fgconsole 2>/dev/null)" = "8" ] && [ "$DO_NOT_SWITCH_VT" != "yes" ]; then
	    chvt 1
	fi
fi
case “$1” in
start)
usplash_quit
stop)
# only run with splash boot cmdline
if [ -r /proc/cmdline ] && grep -q splash /proc/cmdline; then
usplash -c &
usplash_write "TEXT Resetting the usplash timeout…"
usplash_write "TIMEOUT 15"
usplash_write "SUCCESS ok"
fi
N=/etc/init.d/$NAME
# echo “Usage: $N {start|stop|restart|reload|force-reload}” >&2
echo “Usage: $N {start|stop}” >&2
exit 1
esac
exit 0[/code]
ben tu vois bien que le stop fait un usplash -c ?
essayes en le supprimant.
Oups, je devais être fatigué hier soir ! Donc j’ai commenté la ligne en question, et ça marche nickel, y compris l’hibernation ! Merci beaucoup…
