Installation facile de ispconfig
voila une installation simplifié pour installé apache,postfix,phpmyadmin,ispconfig,
wget http://www.e-rave.nl/wp-content/uploads/2011/12/ispc3sysinstall.sh chmod +x ispc3sysinstall.sh ./ispc3sysinstall.sh
et voila simple rapide et efficace
Ptet mais nous, on aimebien pouvoir lire les scripts avant de les installer.
Tu peux le placer ici stp.
Le voilà (aucune mention de licence ?):
Le script est pour Squeeze, pas sur que ça fonctionne sur une Wheezy (je m’en vais tester de ce pas…)
[code]#!/bin/bash
ispc3sysinstall.sh
ISPConfig 3 system installer
Script: ispc3sysinstall.sh
Version: 1.0
Author: Mark Stunnenberg mark@e-rave.nl
Description: This script will install all the packages needed to install
ISPConfig 3 on your server.
Global variables
CFG_HOSTNAME_FQDN=hostname -f;
WT_BACKTITLE=“ISPConfig 3 System Installer”
Function: PreInstallCheck
Do some pre-install checks
PreInstallCheck() {
echo -n "Checking internet connection…"
ping -q -c 3 www.ispconfig.org > /dev/null 2>&1
if [ ! “$?” -eq 0 ]; then
echo "ERROR: Couldn’t reach www.ispconfig.org, please check your internet connection!"
exit 1;
fi
echo “OK!”
Function: AskQuestions
Ask for all needed user input
AskQuestions() {
while [ “x$CFG_MYSQL_ROOT_PWD” == “x” ]
do
CFG_MYSQL_ROOT_PWD=$(whiptail --title “MySQL” --backtitle “$WT_BACKTITLE” --inputbox “Please specify a root password” --nocancel 10 50 3>&1 1>&2 2>&3)
done
while [ “x$CFG_MTA” == “x” ]
do
CFG_MTA=$(whiptail --title “Mail Server” --backtitle “$WT_BACKTITLE” --nocancel --radiolist “Select mailserver type” 10 50 2 “courier” “(default)” ON “dovecot” “” OFF 3>&1 1>&2 2>&3)
done
if (whiptail --title “Quota” --backtitle “$WT_BACKTITLE” --yesno “Setup user quota?” 10 50) then
CFG_QUOTA=y
else
CFG_QUOTA=n
fi
if (whiptail --title “Jailkit” --backtitle “$WT_BACKTITLE” --yesno “Would you like to install Jailkit?” 10 50) then
CFG_JKIT=y
else
CFG_JKIT=n
fi
while [ “x$CFG_WEBMAIL” == “x” ]
do
CFG_WEBMAIL=$(whiptail --title “Webmail client” --backtitle “$WT_BACKTITLE” --nocancel --radiolist “Select your webmail client” 10 50 2 “roundcube” “(default)” ON “squirrelmail” “” OFF 3>&1 1>&2 2>&3)
done
Function: InstallBasics
Install basic packages
InstallBasics() {
echo -n "Updating apt and upgrading currently installed packages…"
apt-get -qq update
apt-get -qqy upgrade
echo “done!”
echo -n "Installing basic packages…"
apt-get -y install ssh openssh-server vim-nox ntp ntpdate debconf-utils binutils sudo > /dev/null 2>&1
echo “dash dash/sh boolean false” | debconf-set-selections
dpkg-reconfigure -f noninteractive dash > /dev/null 2>&1
echo “done!”
Function: Install Postfix
Install and configure postfix
InstallPostfix() {
echo -n "Installing postfix…"
echo “postfix postfix/main_mailer_type select Internet Site” | debconf-set-selections
echo “postfix postfix/mailname string $CFG_HOSTNAME_FQDN” | debconf-set-selections
apt-get -y install postfix postfix-mysql postfix-doc getmail4 > /dev/null 2>&1
echo “done!”
Function: InstallMysql
Install and configure mysql
InstallMysql() {
echo -n "Installing mysql…"
echo “mysql-server-5.1 mysql-server/root_password password $CFG_MYSQL_ROOT_PWD” | debconf-set-selections
echo “mysql-server-5.1 mysql-server/root_password_again password $CFG_MYSQL_ROOT_PWD” | debconf-set-selections
apt-get -y install mysql-client mysql-server > /dev/null 2>&1
sed -i ‘s/bind-address = 127.0.0.1/#bind-address = 127.0.0.1/’ /etc/mysql/my.cnf
service mysql restart > /dev/null
echo “done!”
Function: InstallMTA
Install chosen MTA. Courier or Dovecot
InstallMTA() {
case $CFG_MTA in
"courier")
echo -n “Installing courier…”;
echo “courier-base courier-base/webadmin-configmode boolean false” | debconf-set-selections
echo “courier-ssl courier-ssl/certnotice note” | debconf-set-selections
apt-get -y install courier-authdaemon courier-authlib-mysql courier-pop courier-pop-ssl courier-imap courier-imap-ssl libsasl2-2 libsasl2-modules libsasl2-modules-sql sasl2-bin libpam-mysql courier-maildrop > /dev/null 2>&1
sed -i ‘s/START=no/START=yes/’ /etc/default/saslauthd
cd /etc/courier
rm -f /etc/courier/imapd.pem
rm -f /etc/courier/pop3d.pem
rm -f /usr/lib/courier/imapd.pem
rm -f /usr/lib/courier/pop3d.pem
sed -i “s/CN=localhost/CN=${CFG_HOSTNAME_FQDN}/” /etc/courier/imapd.cnf
sed -i “s/CN=localhost/CN=${CFG_HOSTNAME_FQDN}/” /etc/courier/pop3d.cnf
mkimapdcert > /dev/null 2>&1
mkpop3dcert > /dev/null 2>&1
ln -s /usr/lib/courier/imapd.pem /etc/courier/imapd.pem
ln -s /usr/lib/courier/pop3d.pem /etc/courier/pop3d.pem
service courier-imap-ssl restart > /dev/null
service courier-pop-ssl restart > /dev/null
service courier-authdaemon restart > /dev/null
service saslauthd restart > /dev/null
echo “done!”
“dovecot”)
echo -n “Installing dovecot…”;
apt-get -qqy install dovecot-imapd dovecot-pop3d 2>&1
echo “done!”
esac
Function: InstallAntiVirus
Install Amavisd, Spamassassin, ClamAV
InstallAntiVirus() {
echo -n "Installing anti-virus utilities…"
apt-get -y install amavisd-new spamassassin clamav clamav-daemon zoo unzip bzip2 arj nomarch lzop cabextract apt-listchanges libnet-ldap-perl libauthen-sasl-perl clamav-docs daemon libio-string-perl libio-socket-ssl-perl libnet-ident-perl zip libnet-dns-perl > /dev/null 2>&1
echo “done!”
Function: InstallApachePHP
Install and configure Apache2, php + modules
InstallApachePHP() {
echo "==========================================================================================="
echo "Attention: When asked ‘Configure database for phpmyadmin with dbconfig-common?’ select ‘NO’"
echo "Due to a bug in dbconfig-common, this can’t be automated."
echo "Press ENTER to continue…"
read DUMMY
echo -n "Installing apache…"
echo “phpmyadmin phpmyadmin/reconfigure-webserver multiselect apache2” | debconf-set-selections
- DISABLED DUE TO A BUG IN DBCONFIG - echo “phpmyadmin phpmyadmin/dbconfig-install boolean false” | debconf-set-selections
echo “dbconfig-common dbconfig-common/dbconfig-install boolean false” | debconf-set-selections
apt-get -y install apache2 apache2.2-common apache2-doc apache2-mpm-prefork apache2-utils libexpat1 ssl-cert libapache2-mod-php5 php5 php5-common php5-gd php5-mysql php5-imap php5-cli php5-cgi libapache2-mod-fcgid apache2-suexec php-pear php-auth php5-mcrypt mcrypt php5-imagick imagemagick libapache2-mod-suphp libruby libapache2-mod-ruby > /dev/null 2>&1
apt-get -qqy install phpmyadmin
a2enmod suexec rewrite ssl actions include dav_fs dav auth_digest > /dev/null 2>&1
service apache2 restart > /dev/null 2>&1
echo “done!”
Function: InstallFTP
Install and configure PureFTPd
InstallFTP() {
echo "Installing pureftpd…"
echo “pure-ftpd-common pure-ftpd/virtualchroot boolean true” | debconf-set-selections
apt-get -y install pure-ftpd-common pure-ftpd-mysql > /dev/null 2>&1
sed -i ‘s/ftp/#ftp/’ /etc/inetd.conf
echo 1 > /etc/pure-ftpd/conf/TLS
mkdir -p /etc/ssl/private/
echo "The following questions can be left as default (just press enter), but when"
echo "asked for ‘Common Name’, enter your FQDN hostname ($CFG_HOSTNAME_FQDN)."
read DUMMY
openssl req -x509 -nodes -days 3650 -newkey rsa:2048 -keyout /etc/ssl/private/pure-ftpd.pem -out /etc/ssl/private/pure-ftpd.pem
chmod 600 /etc/ssl/private/pure-ftpd.pem
service openbsd-inetd restart > /dev/null 2>&1
service pure-ftpd-mysql restart > /dev/null 2>&1
echo “done!”
Function: InstallQuota
Install and configure of disk quota
InstallQuota() {
echo -n "Installing and initializing quota (this might take while)…"
apt-get -qqy install quota quotatool > /dev/null 2>&1
if [ cat /etc/fstab | grep ',usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0' | wc -l -eq 0 ]; then
sed -i ‘s/errors=remount-ro/errors=remount-ro,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0/’ /etc/fstab
mount -o remount /
quotacheck -avugm > /dev/null 2>&1
quotaon -avug > /dev/null 2>&1
fi
echo “done!”
Function: InstallBind
Install bind DNS server
InstallBind() {
echo -n “Installing bind…”;
apt-get -y install bind9 dnsutils > /dev/null 2>&1
echo “done!”
Function: InstallWebStats
Install and configure web stats
InstallWebStats() {
echo -n “Installing stats…”;
apt-get -y install vlogger webalizer awstats > /dev/null 2>&1
sed -i ‘s/^/#/’ /etc/cron.d/awstats
echo “done!”
Function: InstallJailkit
Install Jailkit
InstallJailkit() {
echo -n "Installing jailkit…"
apt-get -y install build-essential autoconf automake1.9 libtool flex bison debhelper > /dev/null 2>&1
cd /tmp
wget -q http://olivier.sessink.nl/jailkit/jailkit-2.14.tar.gz
tar xfz jailkit-2.14.tar.gz
cd jailkit-2.14
./debian/rules binary > /dev/null 2>&1
cd …
dpkg -i jailkit_2.14-1_.deb > /dev/null 2>&1
rm -rf jailkit-2.14
echo “done!”
Function: InstallFail2ban
Install and configure fail2ban
InstallFail2ban() {
echo -n "Installing fail2ban…"
apt-get -y install fail2ban > /dev/null 2>&1
case $CFG_MTA in
"courier")
cat > /etc/fail2ban/jail.local <<EOF
[sasl]
enabled = true
port = smtp
filter = sasl
logpath = /var/log/mail.log
maxretry = 5
[courierpop3]
enabled = true
port = pop3
filter = courierpop3
maxretry = 5
[courierpop3s]
enabled = true
port = pop3s
filter = courierpop3s
maxretry = 5
[courierimap]
enabled = true
port = imap2
filter = courierimap
maxretry = 5
[courierimaps]
enabled = true
port = imaps
filter = courierimaps
maxretry = 5
EOF
cat > /etc/fail2ban/filter.d/courierpop3.conf <<EOF
[Definition]
failregex = pop3d: LOGIN FAILED.ip=[.:]
ignoreregex =
EOF
cat > /etc/fail2ban/filter.d/courierpop3s.conf <<EOF
[Definition]
failregex = pop3d-ssl: LOGIN FAILED.ip=[.:]
ignoreregex =
EOF
cat > /etc/fail2ban/filter.d/courierimap.conf <<EOF
[Definition]
failregex = imapd: LOGIN FAILED.ip=[.:]
ignoreregex =
EOF
cat > /etc/fail2ban/filter.d/courierimaps.conf <<EOF
[Definition]
failregex = imapd-ssl: LOGIN FAILED.ip=[.:]
ignoreregex =
EOF
“dovecot”)
[dovecot-pop3imap]
enabled = true
filter = dovecot-pop3imap
action = iptables-multiport[name=dovecot-pop3imap, port=“pop3,pop3s,imap,imaps”, protocol=tcp]
maxretry = 5
EOF
cat > /etc/fail2ban/filter.d/dovecot-pop3imap.conf <<EOF
[Definition]
failregex = (?: pop3-login|imap-login): .(?:Authentication failure|Aborted login (auth failed|Aborted login (tried to use disabled|Disconnected (auth failed|Aborted login (\d+ authentication attempts).rip=(?P\S),.
ignoreregex =
EOF
esac
cat >> /etc/fail2ban/jail.local <<EOF
[pureftpd]
enabled = true
port = ftp
filter = pureftpd
logpath = /var/log/syslog
maxretry = 3
EOF
cat > /etc/fail2ban/filter.d/pureftpd.conf <<EOF
[Definition]
failregex = .pure-ftpd: (.@) [WARNING] Authentication failed for user.*
ignoreregex =
EOF
service fail2ban restart > /dev/null 2>&1
echo “done!”
Function: InstallWebmail
Install the chosen webmail client. Squirrelmail or Roundcube
InstallWebmail() {
echo -n "Installing webmail client ($CFG_WEBMAIL)…“
case $CFG_WEBMAIL in
"roundcube”)
RANDPWD=date +%N%s | md5sum
echo “roundcube-core roundcube/dbconfig-install boolean true” | debconf-set-selections
echo “roundcube-core roundcube/database-type select mysql” | debconf-set-selections
echo “roundcube-core roundcube/mysql/admin-pass password $CFG_MYSQL_ROOT_PWD” | debconf-set-selections
echo “roundcube-core roundcube/db/dbname string roundcube” | debconf-set-selections
echo “roundcube-core roundcube/mysql/app-pass password $RANDOMPWD” | debconf-set-selections
echo “roundcube-core roundcube/app-password-confirm password $RANDPWD” | debconf-set-selections
apt-get -y install roundcube roundcube-mysql > /dev/null 2>&1
sed -i ‘1iAlias /webmail /var/lib/roundcube’ /etc/roundcube/apache.conf
sed -i “s/$rcmail_config[‘default_host’] = ‘’;/$rcmail_config[‘default_host’] = ‘localhost’;/” /etc/roundcube/main.inc.php
“squirrelmail”)
echo “dictionaries-common dictionaries-common/default-wordlist select american (American English)” | debconf-set-selections
apt-get -y install squirrelmail wamerican > /dev/null 2>&1
ln -s /etc/squirrelmail/apache.conf /etc/apache2/conf.d/squirrelmail
sed -i 1d /etc/squirrelmail/apache.conf
sed -i ‘1iAlias /webmail /usr/share/squirrelmail’ /etc/squirrelmail/apache.conf
  case $CFG_MTA in
	"courier")
	  sed -i 's/$imap_server_type       = "other";/$imap_server_type       = "courier";/' /etc/squirrelmail/config.php
	  sed -i 's/$optional_delimiter     = "detect";/$optional_delimiter     = ".";/' /etc/squirrelmail/config.php
	  sed -i 's/$default_folder_prefix          = "";/$default_folder_prefix          = "INBOX.";/' /etc/squirrelmail/config.php
	  sed -i 's/$trash_folder                   = "INBOX.Trash";/$trash_folder                   = "Trash";/' /etc/squirrelmail/config.php
	  sed -i 's/$sent_folder                    = "INBOX.Sent";/$sent_folder                    = "Sent";/' /etc/squirrelmail/config.php
	  sed -i 's/$draft_folder                   = "INBOX.Drafts";/$draft_folder                   = "Drafts";/' /etc/squirrelmail/config.php
	  sed -i 's/$default_sub_of_inbox           = true;/$default_sub_of_inbox           = false;/' /etc/squirrelmail/config.php
	  sed -i 's/$delete_folder                  = false;/$delete_folder                  = true;/' /etc/squirrelmail/config.php
	"dovecot")
	  sed -i 's/$imap_server_type       = "other";/$imap_server_type       = "dovecot";/' /etc/squirrelmail/config.php
  esac
esac
echo “done!”
Function: InstallISPConfig
Start the ISPConfig3 intallation script
InstallISPConfig() {
echo "Installing ISPConfig3…"
echo "=================================================================================="
echo "As a reminder, the following information is needed for the ISPConfig installation:"
echo "- Full qualified hostname (FQDN) of the server: $CFG_HOSTNAME_FQDN"
echo "- MySQL root password: $CFG_MYSQL_ROOT_PWD"
echo "- Common Name (eg, YOUR name): $CFG_HOSTNAME_FQDN"
echo ""
echo "Press ENTER to start the installation…"
read DUMMY
cd /tmp
wget http://www.ispconfig.org/downloads/ISPConfig-3-stable.tar.gz
tar xfz ISPConfig-3-stable.tar.gz
cd ispconfig3_install/install/
php -q install.php
Main program [ main() ]
Run the installer
echo "========================================="
echo "ISPConfig 3 System installer"
echo
echo "This script will do a nearly unattended intallation of"
echo "all software needed to run ISPConfig 3."
echo "When this script starts running, it’ll keep going all the way"
echo "So before you continue, please make sure the following checklist is ok:"
echo
echo “- This is a clean / standard debian installation”;
echo “- Internet connection is working properly”;
echo
echo "If you’re all set, press ENTER to continue or CTRL-C to cancel…"
read DUMMY
if [ -f /etc/debian_version ]; then
PreInstallCheck
AskQuestions
InstallBasics
InstallPostfix
InstallMysql
InstallMTA
InstallAntiVirus
InstallApachePHP
InstallFTP
if [ $CFG_QUOTA == “y” ]; then
InstallQuota
fi
InstallBind
InstallWebStats
if [ $CFG_JKIT == “y” ]; then
InstallJailkit
fi
InstallFail2ban
InstallWebmail
InstallISPConfig
else
echo "Unsupported linux distribution."
fi
exit 0
Edit: A part un souci avec suphp.conf ça roule sur Wheezy!
[quote=“charles44540”]voila une installation simplifié pour installé apache,postfix,phpmyadmin,ispconfig,
et voila simple rapide et efficace[/quote]
Pour faire plus rapide :
(Comme ça t’installe pas le script ricardo :wink: )
Merci Michel, ce n’est pas dans mes intention d’installer, c’était juste pour expliquer qu’on ne peut pas accepter la proposition d’un script avec aussi peu de renseignements.
Imagine qu’un gars mal intentionné place un script qui bouzille une machine :open_mouth:
Un débutant tombe dessus, se dit “chouette”, ça va m’éviter bien des tracas et … devine la suite.
En tout cas ça m’a permis de le tester et de le vérifier, ça fonctionne au poil.
J’avoue que ne plus ma taper toute la partie préparatoire à l’installation de Ispconfig3 m’arrange bien, je vais même ajouter quelques trucs persos au script, c’est une bonne base de départ pour une installation aux petits oignons.
Il manque aussi dovecot-mysql dans l’installation.
Sans ça impossible d’accéder au Webmail.
Edit: Et dovecot-sieve…
quote="MisterFreez"
(Comme ça t’installe pas le script ricardo :wink: )[/quote]
Tout simplement joli !
Je n’aurais vraiment pas penser à ce genre d’astuces…
Comme quoi, la simplicité a encore de beau jour :stuck_out_tongue:
Je n’avais pas essayé pour voir si ça marche vraiment.
Mais je viens de le faire et oui ça marche.
Si tu veux essayer :
curl "http://barmic.fr/test.sh" | sh - :slightly_smiling:
barmic.fr :
pas certifié :unamused:
[quote=“ricardo”]http://barmic.fr :
pas certifié :unamused: [/quote]
Il va falloir forker. C’est la seule page de mon serveur qui ne l’ai pas (j’ai dut bidouiller la config de mon nginx pour ça). Tout ça pour quoi ? Parce que curl refuse les certificats tout pourri comme le miens (certificat autosigné qui ne correspond pas au nom de domaine).
bonjour
apres avoir fait ton tuto
wget e-rave.nl/wp-content/uploads … install.sh
j ai plus access a mes site j ai
Forbidden
You don’t have permission to access / on this server.
quesque je peux faire
merci de l aide
Ce n’est pas son tuto…
Il faut demander là ou se trouve le script: e-rave.nl/automatic-debian-s … spconfig-3
Il en fait pas un peu beaucoup sans laisser le choix à l’utilisateur ?
[quote=“ggoodluck47”]Salut,
Il en fait pas un peu beaucoup sans laisser le choix à l’utilisateur ?[/quote]
Il installe le nécessaire. IspConfig3 est très complet.
Maintenant rien n’empêche de faire l’installation à la man, mais c’est un peu plus long…
Ça reste pratique pour celui qui sait ce qu’il fait…
Je ne conseillerais pas IspConfig à un débutant, il faut bien comprendre ce qui se passe derrière (ie maîtriser apache2, postfix, dovecot, bind9…) faute de quoi on est incapable de dépanner, réparer, sauvegarder, restaurer…
EDIT: Je viens de re-tester le script, il ne fonctionne pas bien. Il ne télécharge pas tous les softs nécessaires, n’installe pas la dernière version de jailkit… Bref pas tout a fait au point pour Wheezy…
