Je découvre depuis le début janvier Debian 8 Jessie. Après avoir installé un PC/serveur en Raid1 pour faire un NAS je me heurte depuis trois jours à l’installation de minidlna. Les divers doc en FR et GB que j’ai trouvées sur internet sont alléchante de simplicité mais rien n’y fait je n’arrive pas à démarrer minidlna. je suis une burne sans doute !
historique :
Installation via Synaptic du package minidlna.
Installation de Webmin.
Lancement via la console de minidlna :
Fichier de config :
[quote] GNU nano 2.2.6 Fichier : /etc/minidlna.conf Modifié
port for HTTP (descriptions, SOAP, media transfer) traffic
port=49200
network interfaces to serve, comma delimited
network_interface=eth0
specify the user account name or uid to run as
set this to the directory you want scanned.
media_dir=P,/home/roque/Images
media_dir=V,/home/roque/Vidéos
media_dir=A,/home/roque/Musique/flac
set this to merge all media_dir base contents into the root container
note: the default is no
merge_media_dirs=no
set this if you want to customize the name that shows up on your clients
friendly_name=Serveur DLNA
set this if you would like to specify the directory where you want MiniDLNA to store its database and album art cac$
db_dir=/var/cache/minidlna
set this if you would like to specify the directory where you want MiniDLNA to store its log file
log_dir=/var/log/minidlna
set this to change the verbosity of the information that is logged
each section can use a different level: off, fatal, error, warn, info, or debug
log_level=general,artwork,database,inotify,scanner,metadata,http,ssdp,tivo=debug.
this should be a list of file names to check for when searching for album art
note: names should be delimited with a forward slash ("/")
album_art_names=Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg/AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg/Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg
set this to no to disable inotify monitoring to automatically discover new files
note: the default is yes
inotify=yes
set this to yes to enable support for streaming .jpg and .mp3 files to a TiVo supporting HMO
enable_tivo=no
set this to strictly adhere to DLNA standards.
* This will allow server-side downscaling of very large JPEG images,
which may hurt JPEG serving performance on (at least) Sony DLNA products.
strict_dlna=no
default presentation url is http address on port 80
presentation_url=http://media.wpl.ym:8200/
notify interval in seconds. default is 895 seconds.
notify_interval=5
serial and model number the daemon will report to clients
in its XML description
serial=12345678
model_number=1
specify the path to the MiniSSDPd socket
minissdpdsocket=/var/run/minissdpd.sock
use different container as root of the tree
possible values:
+ “.” - use standard container (this is the default)
+ “B” - “Browse Directory”
+ “M” - “Music”
+ “V” - “Video”
+ “P” - “Pictures”
+ Or, you can specify the ObjectID of your desired root container (eg. 1$F for Music/Playlists)
if you specify “B” and client device is audio-only then “Music/Folders” will be used as root
root_container=.
maximum number of simultaneous connections
note: many clients open several simultaneous connections while streaming
max_connections=10[/quote]
Pas de log dans le répertoire /var/log/minidlna créé par mes soins.
Mais j’ai ce log de mbadm :
[quote]minidlna.service - MiniDLNA is a DLNA/UPnP-AV server software
Loaded: loaded (/lib/systemd/system/minidlna.service; enabled)
Active: failed (Result: exit-code) since sam. 2016-01-30 17:07:25 CET; 13s ago
Process: 6014 ExecStart=/usr/sbin/minidlnad -S (code=exited, status=255)
Process: 6011 ExecStartPre=/bin/chown $USER /var/run/minidlna (code=exited, status=0/SUCCESS)
Process: 6008 ExecStartPre=/bin/mkdir -p /var/run/minidlna (code=exited, status=0/SUCCESS)
Main PID: 6014 (code=exited, status=255)
janv. 30 17:07:25 bureau minidlnad[6014]: minidlna.c:1026: warn: Starting ReadyDLNA version 1.1.4.
janv. 30 17:07:25 bureau minidlnad[6014]: minidlna.c:294: fatal: ERROR: Failed to open sqlite database! Exiting…
janv. 30 17:07:25 bureau systemd[1]: minidlna.service: main process exited, code=exited, status=255/n/a
janv. 30 17:07:25 bureau systemd[1]: Unit minidlna.service entered failed state.[/quote]
Mon sentiment de bleuzaille sur le sujet est qu’il pourrait s’agir d’un problème de droit pour accéder aux processus, mais je ne vois pas où ni comment en sortir.
Il y aurait-il une bonne âme pour me sortir de ce pétrin ? D’avance un grand merci.
