Debian Wheezy 64 bits kernel 3.2.0-4-amd64
Bonsoir à tous,
J’aimerais faire fonctionner Tubemaster++ sur ma Debian Wheezy.
Avant passage vers Jessie sur mon autre Debian, Tubemaster++ fonctionnait, et je ne me souviens plus comment j’ai fait.
A priori, le problème vient de libpcap0.8
Je joins le Install_HOWTO, puis l’erreur dont je ne me sors pas, et enfin le log généré par l’erreur :
[quote][ TubeMaster++ Installation Instructions ]
=----- (1) -> System Requirements -----
[+] Java SE Runtime Environment (JRE) : java.sun.com/javase/downloads/index.jsp
[+] Java SE Development Kit (JDK) : java.sun.com/javase/downloads/index.jsp
[+] LibPcap (Installed by default) : sourceforge.net/projects/libpcap/
[+] JPcap Library : netresearch.ics.uci.edu/kfujii/j … nload.html
** You must always be sure that “libjpcap.so” is in “/usr/lib” directory. If not, move it.
[+] FFMpeg with FFPlay :
** Debian, Ubuntu :
- FFMpeg & FFPlay : Run Command “apt-get install ffmpeg”
- FFMpeg Libraries : Run Command “apt-get install libavcodec-unstripped-52”
** RedHat, Fedora :
- Install RPMFusion Software Provider : rpmfusion.org/Configuration
- FFMpeg & FFPlay : Run Command “yum install ffmpeg”
** Mandrake :
- It appears that running “urpmi ffmpeg” command works but ffmpeg doesn’t have all needed libraries.
So you must be sure that FFMpeg is installed with “libxvid” and “libmp3lame”.
=----- (2) -> Once all System Requirements are installed go to TubeMaster++ folder.
=----- (3) -> Run tm++.jar (You must be ROOT !).
=----- (4) -> If you have any questions, suggestions, or if you find some bugs, please contact me at : admin[at]tubemaster.net[/quote]
[code]$ sudo java-oracle -jar tm++.jar
Place your finger on the fingerprint reader
TubeMaster++ detected operating system : Linux
TubeMaster++ Core Started
-= TubeMaster++ Started on null =-
-= TubeMaster++ Started on Linux netfilter log (NFLOG) interface =-
-= TubeMaster++ Started on Pseudo-device that captures on all interfaces =-
- Conversion Thread Running*
-= TubeMaster++ Stopped on Linux netfilter log (NFLOG) interface (Rcv=0|Drp=0)=-
A fatal error has been detected by the Java Runtime Environment:
SIGSEGV (0xb) at pc=0x00007fbd25c7cab0, pid=32101, tid=140450358286080
JRE version: Java™ SE Runtime Environment (7.0_45-b18) (build 1.7.0_45-b18)
Java VM: Java HotSpot™ 64-Bit Server VM (24.45-b08 mixed mode linux-amd64 compressed oops)
Problematic frame:
C [libpcap.so.0.8+0xdab0] pcap_stats+0x0
Failed to write core dump. Core dumps have been disabled. To enable core dumping, try “ulimit -c unlimited” before starting Java again
An error report file with more information is saved as:
/opt/TubeMaster++/hs_err_pid32101.log
If you would like to submit a bug report, please visit:
http://bugreport.sun.com/bugreport/crash.jsp
The crash happened outside the Java Virtual Machine in native code.
See problematic frame for where to report the bug.
$ whereis libpcap
libpcap: /usr/lib/libpcap.so /usr/lib/libpcap.a /usr/local/lib/libpcap.so /usr/local/lib/libpcap.a
$ locate libpcap
/opt/libpcap-1.3.0
/opt/libpcap-1.3.0/CHANGES
/opt/libpcap-1.3.0/CREDITS
/opt/libpcap-1.3.0/ChmodBPF
/opt/libpcap-1.3.0/INSTALL.txt
/opt/libpcap-1.3.0/LICENSE
/opt/libpcap-1.3.0/Makefile
/opt/libpcap-1.3.0/Makefile.in
/opt/libpcap-1.3.0/README
/opt/libpcap-1.3.0/README.Win32
/opt/libpcap-1.3.0/README.aix
/opt/libpcap-1.3.0/README.dag
/opt/libpcap-1.3.0/README.hpux
/opt/libpcap-1.3.0/README.linux
/opt/libpcap-1.3.0/README.macosx
/opt/libpcap-1.3.0/README.septel
/opt/libpcap-1.3.0/README.sita
/opt/libpcap-1.3.0/README.tru64
/opt/libpcap-1.3.0/SUNOS4
/opt/libpcap-1.3.0/TODO
/opt/libpcap-1.3.0/VERSION
/opt/libpcap-1.3.0/Win32
/opt/libpcap-1.3.0/aclocal.m4
/opt/libpcap-1.3.0/arcnet.h
/opt/libpcap-1.3.0/atmuni31.h
/opt/libpcap-1.3.0/bpf
/opt/libpcap-1.3.0/bpf_dump.c
/opt/libpcap-1.3.0/bpf_dump.o
/opt/libpcap-1.3.0/bpf_filter.c
/opt/libpcap-1.3.0/bpf_filter.o
/opt/libpcap-1.3.0/bpf_image.c
/opt/libpcap-1.3.0/bpf_image.o
/opt/libpcap-1.3.0/chmod_bpf
/opt/libpcap-1.3.0/config.guess
/opt/libpcap-1.3.0/config.h
/opt/libpcap-1.3.0/config.h.in
/opt/libpcap-1.3.0/config.log
/opt/libpcap-1.3.0/config.status
/opt/libpcap-1.3.0/config.sub
/opt/libpcap-1.3.0/configure
/opt/libpcap-1.3.0/configure.in
/opt/libpcap-1.3.0/dlpisubs.c
/opt/libpcap-1.3.0/dlpisubs.h
/opt/libpcap-1.3.0/etherent.c
/opt/libpcap-1.3.0/etherent.o
/opt/libpcap-1.3.0/ethertype.h
/opt/libpcap-1.3.0/fad-getad.c
/opt/libpcap-1.3.0/fad-getad.o
/opt/libpcap-1.3.0/fad-gifc.c
/opt/libpcap-1.3.0/fad-glifc.c
/opt/libpcap-1.3.0/fad-null.c
/opt/libpcap-1.3.0/fad-sita.c
/opt/libpcap-1.3.0/fad-win32.c
/opt/libpcap-1.3.0/gencode.c
/opt/libpcap-1.3.0/gencode.h
/opt/libpcap-1.3.0/gencode.o
/opt/libpcap-1.3.0/grammar.c
/opt/libpcap-1.3.0/grammar.o
/opt/libpcap-1.3.0/grammar.y
/opt/libpcap-1.3.0/ieee80211.h
/opt/libpcap-1.3.0/inet.c
/opt/libpcap-1.3.0/inet.o
/opt/libpcap-1.3.0/install-sh
/opt/libpcap-1.3.0/lbl
/opt/libpcap-1.3.0/libpcap.a
/opt/libpcap-1.3.0/libpcap.so.1.3.0
/opt/libpcap-1.3.0/llc.h
/opt/libpcap-1.3.0/missing
/opt/libpcap-1.3.0/mkdep
/opt/libpcap-1.3.0/msdos
/opt/libpcap-1.3.0/nametoaddr.c
/opt/libpcap-1.3.0/nametoaddr.o
/opt/libpcap-1.3.0/net
/opt/libpcap-1.3.0/nlpid.h
/opt/libpcap-1.3.0/optimize.c
/opt/libpcap-1.3.0/optimize.o
/opt/libpcap-1.3.0/org.tcpdump.chmod_bpf.plist
/opt/libpcap-1.3.0/packaging
/opt/libpcap-1.3.0/pcap
/opt/libpcap-1.3.0/pcap-bpf.c
/opt/libpcap-1.3.0/pcap-bpf.h
/opt/libpcap-1.3.0/pcap-bt-linux.c
/opt/libpcap-1.3.0/pcap-bt-linux.h
/opt/libpcap-1.3.0/pcap-can-linux.c
/opt/libpcap-1.3.0/pcap-can-linux.h
/opt/libpcap-1.3.0/pcap-can-linux.o
/opt/libpcap-1.3.0/pcap-canusb-linux.c
/opt/libpcap-1.3.0/pcap-canusb-linux.h
/opt/libpcap-1.3.0/pcap-canusb-linux.o
/opt/libpcap-1.3.0/pcap-common.c
/opt/libpcap-1.3.0/pcap-common.h
/opt/libpcap-1.3.0/pcap-common.o
/opt/libpcap-1.3.0/pcap-config
/opt/libpcap-1.3.0/pcap-config.1
/opt/libpcap-1.3.0/pcap-config.in
/opt/libpcap-1.3.0/pcap-dag.c
/opt/libpcap-1.3.0/pcap-dag.h
/opt/libpcap-1.3.0/pcap-dlpi.c
/opt/libpcap-1.3.0/pcap-dos.c
/opt/libpcap-1.3.0/pcap-dos.h
/opt/libpcap-1.3.0/pcap-enet.c
/opt/libpcap-1.3.0/pcap-filter.manmisc
/opt/libpcap-1.3.0/pcap-filter.manmisc.in
/opt/libpcap-1.3.0/pcap-int.h
/opt/libpcap-1.3.0/pcap-libdlpi.c
/opt/libpcap-1.3.0/pcap-linktype.manmisc
/opt/libpcap-1.3.0/pcap-linktype.manmisc.in
/opt/libpcap-1.3.0/pcap-linux.c
/opt/libpcap-1.3.0/pcap-linux.o
/opt/libpcap-1.3.0/pcap-namedb.h
/opt/libpcap-1.3.0/pcap-netfilter-linux.c
/opt/libpcap-1.3.0/pcap-netfilter-linux.h
/opt/libpcap-1.3.0/pcap-netfilter-linux.o
/opt/libpcap-1.3.0/pcap-nit.c
/opt/libpcap-1.3.0/pcap-null.c
/opt/libpcap-1.3.0/pcap-pf.c
/opt/libpcap-1.3.0/pcap-savefile.manfile
/opt/libpcap-1.3.0/pcap-savefile.manfile.in
/opt/libpcap-1.3.0/pcap-septel.c
/opt/libpcap-1.3.0/pcap-septel.h
/opt/libpcap-1.3.0/pcap-sita.c
/opt/libpcap-1.3.0/pcap-sita.h
/opt/libpcap-1.3.0/pcap-sita.html
/opt/libpcap-1.3.0/pcap-snf.c
/opt/libpcap-1.3.0/pcap-snf.h
/opt/libpcap-1.3.0/pcap-snit.c
/opt/libpcap-1.3.0/pcap-snoop.c
/opt/libpcap-1.3.0/pcap-stdinc.h
/opt/libpcap-1.3.0/pcap-tstamp.manmisc
/opt/libpcap-1.3.0/pcap-tstamp.manmisc.in
/opt/libpcap-1.3.0/pcap-usb-linux.c
/opt/libpcap-1.3.0/pcap-usb-linux.h
/opt/libpcap-1.3.0/pcap-usb-linux.o
/opt/libpcap-1.3.0/pcap-win32.c
/opt/libpcap-1.3.0/pcap.3pcap
/opt/libpcap-1.3.0/pcap.3pcap.in
/opt/libpcap-1.3.0/pcap.c
/opt/libpcap-1.3.0/pcap.h
/opt/libpcap-1.3.0/pcap.o
/opt/libpcap-1.3.0/pcap_activate.3pcap
/opt/libpcap-1.3.0/pcap_breakloop.3pcap
/opt/libpcap-1.3.0/pcap_can_set_rfmon.3pcap
/opt/libpcap-1.3.0/pcap_close.3pcap
/opt/libpcap-1.3.0/pcap_compile.3pcap
/opt/libpcap-1.3.0/pcap_compile.3pcap.in
/opt/libpcap-1.3.0/pcap_create.3pcap
/opt/libpcap-1.3.0/pcap_datalink.3pcap
/opt/libpcap-1.3.0/pcap_datalink.3pcap.in
/opt/libpcap-1.3.0/pcap_datalink_name_to_val.3pcap
/opt/libpcap-1.3.0/pcap_datalink_val_to_name.3pcap
/opt/libpcap-1.3.0/pcap_dump.3pcap
/opt/libpcap-1.3.0/pcap_dump_close.3pcap
/opt/libpcap-1.3.0/pcap_dump_file.3pcap
/opt/libpcap-1.3.0/pcap_dump_flush.3pcap
/opt/libpcap-1.3.0/pcap_dump_ftell.3pcap
/opt/libpcap-1.3.0/pcap_dump_open.3pcap
/opt/libpcap-1.3.0/pcap_dump_open.3pcap.in
/opt/libpcap-1.3.0/pcap_file.3pcap
/opt/libpcap-1.3.0/pcap_fileno.3pcap
/opt/libpcap-1.3.0/pcap_findalldevs.3pcap
/opt/libpcap-1.3.0/pcap_freecode.3pcap
/opt/libpcap-1.3.0/pcap_get_selectable_fd.3pcap
/opt/libpcap-1.3.0/pcap_geterr.3pcap
/opt/libpcap-1.3.0/pcap_inject.3pcap
/opt/libpcap-1.3.0/pcap_is_swapped.3pcap
/opt/libpcap-1.3.0/pcap_lib_version.3pcap
/opt/libpcap-1.3.0/pcap_list_datalinks.3pcap
/opt/libpcap-1.3.0/pcap_list_datalinks.3pcap.in
/opt/libpcap-1.3.0/pcap_list_tstamp_types.3pcap
/opt/libpcap-1.3.0/pcap_list_tstamp_types.3pcap.in
/opt/libpcap-1.3.0/pcap_lookupdev.3pcap
/opt/libpcap-1.3.0/pcap_lookupnet.3pcap
/opt/libpcap-1.3.0/pcap_loop.3pcap
/opt/libpcap-1.3.0/pcap_major_version.3pcap
/opt/libpcap-1.3.0/pcap_next_ex.3pcap
/opt/libpcap-1.3.0/pcap_offline_filter.3pcap
/opt/libpcap-1.3.0/pcap_open_dead.3pcap
/opt/libpcap-1.3.0/pcap_open_dead.3pcap.in
/opt/libpcap-1.3.0/pcap_open_live.3pcap
/opt/libpcap-1.3.0/pcap_open_offline.3pcap
/opt/libpcap-1.3.0/pcap_open_offline.3pcap.in
/opt/libpcap-1.3.0/pcap_set_buffer_size.3pcap
/opt/libpcap-1.3.0/pcap_set_datalink.3pcap
/opt/libpcap-1.3.0/pcap_set_promisc.3pcap
/opt/libpcap-1.3.0/pcap_set_rfmon.3pcap
/opt/libpcap-1.3.0/pcap_set_snaplen.3pcap
/opt/libpcap-1.3.0/pcap_set_timeout.3pcap
/opt/libpcap-1.3.0/pcap_set_tstamp_type.3pcap
/opt/libpcap-1.3.0/pcap_set_tstamp_type.3pcap.in
/opt/libpcap-1.3.0/pcap_setdirection.3pcap
/opt/libpcap-1.3.0/pcap_setfilter.3pcap
/opt/libpcap-1.3.0/pcap_setnonblock.3pcap
/opt/libpcap-1.3.0/pcap_snapshot.3pcap
/opt/libpcap-1.3.0/pcap_stats.3pcap
/opt/libpcap-1.3.0/pcap_statustostr.3pcap
/opt/libpcap-1.3.0/pcap_strerror.3pcap
/opt/libpcap-1.3.0/pcap_tstamp_type_name_to_val.3pcap
/opt/libpcap-1.3.0/pcap_tstamp_type_val_to_name.3pcap
/opt/libpcap-1.3.0/ppp.h
/opt/libpcap-1.3.0/runlex.sh
/opt/libpcap-1.3.0/savefile.c
/opt/libpcap-1.3.0/savefile.o
/opt/libpcap-1.3.0/scanner.c
/opt/libpcap-1.3.0/scanner.h
/opt/libpcap-1.3.0/scanner.l
/opt/libpcap-1.3.0/scanner.o
/opt/libpcap-1.3.0/sf-pcap-ng.c
/opt/libpcap-1.3.0/sf-pcap-ng.h
/opt/libpcap-1.3.0/sf-pcap-ng.o
/opt/libpcap-1.3.0/sf-pcap.c
/opt/libpcap-1.3.0/sf-pcap.h
/opt/libpcap-1.3.0/sf-pcap.o
/opt/libpcap-1.3.0/sunatmpos.h
/opt/libpcap-1.3.0/tests
/opt/libpcap-1.3.0/tokdefs.h
/opt/libpcap-1.3.0/version.c
/opt/libpcap-1.3.0/version.h
/opt/libpcap-1.3.0/version.o
/opt/libpcap-1.3.0/ChmodBPF/ChmodBPF
/opt/libpcap-1.3.0/ChmodBPF/StartupParameters.plist
/opt/libpcap-1.3.0/SUNOS4/nit_if.o.sparc
/opt/libpcap-1.3.0/SUNOS4/nit_if.o.sun3
/opt/libpcap-1.3.0/SUNOS4/nit_if.o.sun4c.4.0.3c
/opt/libpcap-1.3.0/Win32/Include
/opt/libpcap-1.3.0/Win32/Prj
/opt/libpcap-1.3.0/Win32/Src
/opt/libpcap-1.3.0/Win32/Include/Gnuc.h
/opt/libpcap-1.3.0/Win32/Include/addrinfo.h
/opt/libpcap-1.3.0/Win32/Include/arpa
/opt/libpcap-1.3.0/Win32/Include/bittypes.h
/opt/libpcap-1.3.0/Win32/Include/cdecl_ext.h
/opt/libpcap-1.3.0/Win32/Include/inetprivate.h
/opt/libpcap-1.3.0/Win32/Include/ip6_misc.h
/opt/libpcap-1.3.0/Win32/Include/net
/opt/libpcap-1.3.0/Win32/Include/sockstorage.h
/opt/libpcap-1.3.0/Win32/Include/arpa/nameser.h
/opt/libpcap-1.3.0/Win32/Include/net/if.h
/opt/libpcap-1.3.0/Win32/Include/net/netdb.h
/opt/libpcap-1.3.0/Win32/Include/net/paths.h
/opt/libpcap-1.3.0/Win32/Prj/libpcap.dsp
/opt/libpcap-1.3.0/Win32/Prj/libpcap.dsw
/opt/libpcap-1.3.0/Win32/Src/ffs.c
/opt/libpcap-1.3.0/Win32/Src/gai_strerror.c
/opt/libpcap-1.3.0/Win32/Src/getaddrinfo.c
/opt/libpcap-1.3.0/Win32/Src/getnetbynm.c
/opt/libpcap-1.3.0/Win32/Src/getnetent.c
/opt/libpcap-1.3.0/Win32/Src/getopt.c
/opt/libpcap-1.3.0/Win32/Src/getservent.c
/opt/libpcap-1.3.0/Win32/Src/inet_aton.c
/opt/libpcap-1.3.0/Win32/Src/inet_net.c
/opt/libpcap-1.3.0/Win32/Src/inet_pton.c
/opt/libpcap-1.3.0/bpf/net
/opt/libpcap-1.3.0/bpf/net/bpf_filter.c
/opt/libpcap-1.3.0/lbl/os-aix4.h
/opt/libpcap-1.3.0/lbl/os-hpux11.h
/opt/libpcap-1.3.0/lbl/os-osf4.h
/opt/libpcap-1.3.0/lbl/os-osf5.h
/opt/libpcap-1.3.0/lbl/os-solaris2.h
/opt/libpcap-1.3.0/lbl/os-sunos4.h
/opt/libpcap-1.3.0/lbl/os-ultrix4.h
/opt/libpcap-1.3.0/missing/snprintf.c
/opt/libpcap-1.3.0/msdos/bin2c.c
/opt/libpcap-1.3.0/msdos/common.dj
/opt/libpcap-1.3.0/msdos/makefile
/opt/libpcap-1.3.0/msdos/makefile.dj
/opt/libpcap-1.3.0/msdos/makefile.wc
/opt/libpcap-1.3.0/msdos/ndis2.c
/opt/libpcap-1.3.0/msdos/ndis2.h
/opt/libpcap-1.3.0/msdos/ndis_0.asm
/opt/libpcap-1.3.0/msdos/pkt_rx0.asm
/opt/libpcap-1.3.0/msdos/pkt_rx1.s
/opt/libpcap-1.3.0/msdos/pktdrvr.c
/opt/libpcap-1.3.0/msdos/pktdrvr.h
/opt/libpcap-1.3.0/msdos/readme.dos
/opt/libpcap-1.3.0/packaging/pcap.spec.in
/opt/libpcap-1.3.0/pcap/bluetooth.h
/opt/libpcap-1.3.0/pcap/bpf.h
/opt/libpcap-1.3.0/pcap/ipnet.h
/opt/libpcap-1.3.0/pcap/namedb.h
/opt/libpcap-1.3.0/pcap/pcap.h
/opt/libpcap-1.3.0/pcap/sll.h
/opt/libpcap-1.3.0/pcap/usb.h
/opt/libpcap-1.3.0/pcap/vlan.h
/opt/libpcap-1.3.0/tests/filtertest.c
/opt/libpcap-1.3.0/tests/findalldevstest.c
/opt/libpcap-1.3.0/tests/nonblocktest.c
/opt/libpcap-1.3.0/tests/opentest.c
/opt/libpcap-1.3.0/tests/reactivatetest.c
/opt/libpcap-1.3.0/tests/selpolltest.c
/usr/lib/libpcap.a
/usr/lib/libpcap.so
/usr/lib/libpcap.so.1
/usr/lib/libpcap.so.1.3.0
/usr/lib/x86_64-linux-gnu/libpcap.so.0.8
/usr/lib/x86_64-linux-gnu/libpcap.so.1.3.0
/usr/local/lib/libpcap.so.1
/usr/local/lib/libpcap.so.1.3.0
/usr/share/doc/libpcap0.8
/usr/share/doc/libpcap0.8/CREDITS.gz
/usr/share/doc/libpcap0.8/README.Debian
/usr/share/doc/libpcap0.8/README.gz
/usr/share/doc/libpcap0.8/changelog.Debian.gz
/usr/share/doc/libpcap0.8/changelog.gz
/usr/share/doc/libpcap0.8/copyright
/var/lib/dpkg/info/libpcap0.8:amd64.list
/var/lib/dpkg/info/libpcap0.8:amd64.md5sums
/var/lib/dpkg/info/libpcap0.8:amd64.postinst
/var/lib/dpkg/info/libpcap0.8:amd64.postrm
/var/lib/dpkg/info/libpcap0.8:amd64.shlibs
/var/lib/dpkg/info/libpcap0.8:amd64.symbols
En vous remerciant d’avance pour votre patience
hs_err_pid32101.log (83.7 KB)
