Ca fait un petit moment que j’essaie d’installer une carte wifi (pcmcia) sur mon portable, mais
rien a faire… j’ai essayé avec les pilotes prism: ca ne donne rien.
Ensuite ndiswrapper, mais j’ai une erreur “Can’t find kernel build files in /lib/modules/version/build;
give the path to kernel build directory with
KBUILD= argument to make”…
Avez-vous une idee afin d’installer cette carte (et donc le wifi)?
uname -r:
2.6.16-2-686
whereiskernel:
kernel: /usr/src/linux-2.6.16.2/kernel
lspci:
00:00.0 Host bridge: Intel Corporation 82440MX Host Bridge (rev 01)
00:00.1 Multimedia audio controller: Intel Corporation 82440MX AC’97 Audio Controller
00:02.0 Communication controller: Agere Systems 56k WinModem (rev 01)
00:04.0 VGA compatible controller: S3 Inc. 86C270-294 Savage/IX-MV (rev 13)
00:07.0 Bridge: Intel Corporation 82440MX ISA Bridge (rev 01)
00:07.1 IDE interface: Intel Corporation 82440MX EIDE Controller
00:07.2 USB Controller: Intel Corporation 82440MX USB Universal Host Controller
00:07.3 Bridge: Intel Corporation 82440MX Power Management Controller
00:09.0 IRDA controller: Toshiba America Info Systems FIR Port Type-DO
00:0b.0 CardBus bridge: Toshiba America Info Systems ToPIC100 PCI to Cardbus Bridge with ZV Support (rev 20)
00:0b.1 CardBus bridge: Toshiba America Info Systems ToPIC100 PCI to Cardbus Bridge with ZV Support (rev 20)
05:00.0 Network controller: Intersil Corporation ISL3890 [Prism GT/Prism Duette]/ISL3886 [Prism Javelin/Prism Xbow] (rev 01)
dmesg (raccourci, mais je peux le mettre en entier):
Linux version 2.6.16-2-686 (Debian 2.6.16-17) (waldi@debian.org) (gcc version 4. 0.4 20060630 (prerelease) (Debian 4.0.3-4)) #1 Sat Jul 15 21:59:21 UTC 2006
device-mapper: 4.5.0-ioctl (2005-10-04) initialised: dm-devel@redhat.com
eth0: resetting device…
eth0: uploading firmware…
prism54: request_firmware() failed for 'isl3890’
eth0: could not upload firmware (‘isl3890’)
eth0: islpci_reset: failure
ACPI: Battery Slot [BAT1] (battery absent)
ACPI: Battery Slot [BAT2] (battery absent)
ACPI: AC Adapter [ADP1] (on-line)
ACPI: Power Button (FF) [PWRF]
ACPI: Lid Switch [LID]
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
Bien sûr, s’il faut d’autres renseignements, pas de probleme!
