Installer Apache + MySql + PHP pour Debian (LAMP)
Installation de Apache + MySql + PHP pour Debian
basé sur le tutorial de ac-creteil.fr/reseaux/system … ebian.html
mais en utilisant les versions les plus recentes des programmes mentionnés (Apache 2, PHP 5, …) et en faisant des vérifications à chaque étape.
:arrow_right: Apache
installation:
apt-get install apache2
vérification:
-> debian/
:arrow_right: PHP
installation:
apt-get install php5
vérification:
créer le fichier /var/www/foo/foo.php (avec privileges root) en y insérant le code suivant:
[quote]<?
phpinfo();
?>[/quote]
-> debian/foo/foo.php
:arrow_right: MySQL
installation:
apt-get install mysql-server
  • suivre les instructions du fichier /usr/share/doc/mysql-server-5.0/README.Debian.gz:
quote
  • WHAT TO DO AFTER INSTALLATION:
    The MySQL manual describes certain steps to do at this stage in a separate
    chapter. They are not necessary as the Debian packages does them
    automatically.
The only thing that is left over for the admin is
  • setting the passwords
  • creating new users and databases
  • read the rest of this text
  • PASSWORDS:
    It is strongly recommended to set a password for the mysql root user (which
    is NOT the same as the « normal » root user) with the command:
    /usr/bin/mysqladmin -u root password ‹ enter-your-good-new-password-here ›
    If you already had a password set add " -p " before « -u » to the line above.
If you are tired to type the password in every time or want to automate your
scripts you can store it in the file $HOME/.my.cnf. It should be chmod 0600
(-rw------- username username .my.cnf) to ensure that nobody else can read
it. Every other configuration parameter can be stored there, too. You will
find an example below and more information in the MySQL manual in
/usr/share/doc/mysql-doc or mysql.com.
ATTENTION: It is necessary, that a .my.cnf from root always contains a « user »
line wherever there is a « password » line, else, the Debian maintenance
scripts, that use /etc/mysql/debian.cnf, will use the username
« debian-sys-maint » but the password that is in root’s .my.cnf. Also note,
that every change you make in the /root/.my.cnf will affect the mysql cron
script, too.
    # an example of $HOME/.my.cnf
[client]
user		= your-mysql-username
password	= enter-your-good-new-password-here
(…)[/quote]
créer le mot de passe pour l’administrateur de MySQL
/usr/bin/mysqladmin -u root password 'enter-your-good-new-password-here'
créer le fichier /root/.my.cnf (avec privileges root) et y insérer:
[quote][client]
user = root
password = enter-your-good-new-password-here[/quote]
protéger le fichier des regards exterieurs …
chmod 0600 /root/.my.cnf
vérification:
lancer mysql dans une console (avec privileges root -> su) et tester:
[code]# mysql
Welcome to the MySQL monitor. Commands end with ; or \g.
Your MySQL connection id is 44 to server version: 5.0.22-Debian_3-log
Type ‹ help; › or ‹ \h › for help. Type ‹ \c › to clear the buffer.
mysql> show databases;
| Database |
| information_schema |
| mysql |
2 rows in set (0.00 sec)
mysql> use mysql;
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
mysql> select host, user from user;
| host | user |
| debian | root |
| localhost | debian-sys-maint |
| localhost | root |
3 rows in set (0.01 sec)
mysql> quit
Bye[/code]
:arrow_right: PHP/MySQL
installation:
apt-get install php5-mysql
vérification:
créer le fichier /var/www/foo/foo2.php (avec privileges root) en y insérant le code suivant:
[quote]<?php
// Url de votre base de donnée. Généralement, c’est locahost.
$Serveur_db=« localhost »;
// Votre login pour votre base de donnée
$User_db=« root »;
// Votre mot de passe pour la base de donnée
$Passe_db=« enter-your-good-new-password-here »;
// Nom de votre base de donnée
$Base_name=« mysql »;
// Connection à MySQL
$Connect_db=mysql_connect($Serveur_db,$User_db,$Passe_db);
// Sélection de la base de donnée
mysql_select_db($Base_name,$Connect_db);
// Séléction de la table
$requete=mysql_query(« select host, user from user »);
while($j=mysql_fetch_array($requete)) // Boucle avec la fonction while()
// On sort les informations de la table et on les affiche
print ‹ • ‹ .$j[host]. › - ‹ .$j[user]. ›
print ‹
Il y a ‹ .mysql_numrows($requete). › utilisateur(s)! ›;
?> [/quote]
-> debian/foo/foo2.php
:arrow_right: phpMyAdmin
installation:
apt-get install phpmyadmin
vérification:
-> debian/phpmyadmin/
:arrow_right: mais aussi
redémarrer le server apache:
# /etc/init.d/apache2 restart
redémarrer le server mysql:
# /etc/init.d/mysql restart
v’là 8)
Pour l’installation de apache il serais peut etre bon de recommandé la sécurisation ?
Un bon tuto pour ca: coagul.org/article.php3?id_article=351
oui, allez y!
c’est ma toute première install LAMP (big noob inside) donc je découvre, toutes remarques et autres infos sont volontier acceptées :smiley:
bonjour,
je suis sous debian sid… il me semble qu’il manque quelques infos. Par exemple, pour lancer mysql et vérifier les users, la commande est mysql -u root -p… À indiquer. Avant de lancer foo2.php, il faut aussi rebooter apache2 il me semble…
n’hésite pas à contribuer à ton tour …
tu peux meme refaire complétement le how-to si ça te dit!
(je l’ai fais au feeling après install sans avoir pris de note, je trouve que c’est déjà pas mal …)
Putain Ghostintheshell, quand je pense qu’il y a des types qui écrivent des bouquins de 250 pages sur le sujet… à 50€ le livre (ça fait cher la page), et toi là paf tu nous balances ça en GNU ! Grand fou ! (C’est juste pour la rime)
Bon j’essaierais d’ajouter quelques éléments de config apache2 quand je referais une install chez moi… J’ai pas suffisament de mémoire et de neurones, là tout de suite maintenant !
merci pour la signature :slightly_smiling:
De rien, mais moi je suis moins GNU que toi… alors je réclame mes droits d’auteurs :smiling_imp:
c’est triste.
c’est triste.[/quote]Non, lucratif :smiling_imp:
c’est triste.[/quote]Non, lucratif :smiling_imp:[/quote]
c’est bien ce que je dis :smiling_imp:
ps/ ou peut-on trouver tes ouvrages? je suis curieux :slightly_smiling:
giminik.developpez.com/articles/apache/debian/
[quote=“ghostintheshell”]
ps/ ou peut-on trouver tes ouvrages? je suis curieux :slightly_smiling:[/quote]
amazon.fr/gp/product/2746028 … e&n=301061
eyrolles.com/Informatique/Li … l-lamp.php
En trainant à paris cet aprèm’ j’ai regardé le prix des bouquins sur lamp… 30 ~ 35 € :smiley:
okay!! vu que tu insistes tant, je vais vous fournir mon compte paypal!
:wink:
Je profite de la découverte d’un tutos pour completer celui ci et de faire remonter ce post un peu :wink:
olange.developpez.com/articles/d … eur-dedie/
Il m’a l’air assez sympa à voir et assez complet :wink:
C’est cool tous ces tutos merci les gars pour vos recherches et tout et tout… :smiley:
Mais je me demande pourquoi les gens ne vont pas les mettre sur le site Debian-fr.org.
Ca pourrait etre sympa en plus d’avoir un forum pour les tips au cas par cas, de completer un site centralisé, façon communauté ubutu, non?
Excusez moi je m’emporte je devrais pas ecrire ca ici, je vais ouvrir un autre post…
http://forum.debian-fr.org/viewtopic.php?t=6589&highlight=
Merçi, grace a ca j’ai réussi a utiliser PHP , bravo :slightly_smiling:
Juste une remarque, une fois apache installé quand je clique sur ton lien FF me redirige automatiquement vers http://www.debian.org/
Pour ne pas créer de problème, ce ne serait pas plus simple d’indiquer http://127.0.0.1/ pour la vérification ?
Sinon super le tuto
Je sais que c’est chiant les remontages de topic mais je tiens a remercier le créateur :slightly_smiling:
