voilà depuis que j’ai ma machine amd64, je suis jamais arriver installer la carte reseaux integrer à la carte mère.
j’ai installer le driver sk98lin.4, mail j’ai une erreur dés que ke l’installe.
[code]Create tmp dir (/tmp/Sk98IdpijHBmieiWgRBQQqJdb) [ OK ]
Check user id (0) [ OK ]
Check kernel version (2.6.8-11-amd64-generic) [ OK ]
Check kernel symbol file (/proc/kallsyms) [ OK ]
Check kernel type working
Check kernel type (SP) [ OK ]
Check architecture (found) [ OK ]
Set architecture (x86_64) [ OK ]
Check compiler (/usr/bin/gcc) [ OK ]
Check mcmodel flags (64bit) [ OK ]
Check module support (/sbin/insmod) [ OK ]
Check make (/usr/bin/make) [ OK ]
Check archive file (sk98lin) [ OK ]
Check kernel gcc version (3.4.4) (Kernel:3.4.4 != gcc:3.3.5) [ failed ]
There is a version mismatch between the compiler that was used
to build the current running kernel and the compiler which you
intend to compile the kernel module with. In most of the cases,
this is no problem, but there are cases in which this compiler-
mismatch leads to unexpected system crashes
If you know what you are doing and want to override this
check, you can do so by setting IGNORE_CC_MISMATCH system
variable:
Example: export IGNORE_CC_MISMATCH=1
Installation of sk98lin driver module failed.
Delete temp directories (done) [/code]
