X.Org X Server 1.7.6
Release Date: 2010-03-17
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.32-4-amd64 x86_64 Debian
Current Operating System: Linux pinguinoportable 2.6.32-trunk-amd64 #1 SMP Sun Jan 10 22:40:40 UTC 2010 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-trunk-amd64 root=UUID=9599348e-50d7-4dbe-b97b-72f1aae3bec9 ro quiet
Build Date: 05 April 2010 02:21:15PM
xorg-server 2:1.7.6-2 (Timo Aaltonen tjaalton@ubuntu.com)
Current version of pixman: 0.16.4
Before reporting problems, check wiki.x.org
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Wed Apr 14 12:20:18 2010
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Layout0”
() |–>Screen “Screen0” (0)
() | |–>Monitor “Monitor0”
() | |–>Device “Device0”
() |–>Screen “Screen1” (1)
() | |–>Monitor “Monitor1”
() | |–>Device “Device1”
() |–>Input Device “Keyboard0”
() |–>Input Device “Mouse0”
() Option “Xinerama” “1”
(==) Automatically adding devices
(==) Automatically enabling devices
(**) Xinerama: enabled
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
(WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
(WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
(WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
(==) ModulePath set to “/usr/lib/xorg/modules”
(WW) AllowEmptyInput is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
(WW) Disabling Keyboard0
(WW) Disabling Mouse0
(II) Loader magic: 0x7c59c0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(++) using VT number 7
(–) PCI:*(0:1:0:0) 10de:0a34:1043:1ae2 nVidia Corporation GT216 [GeForce GT 240M] rev 162, Mem @ 0xfc000000/16777216, 0xd0000000/268435456, 0xce000000/33554432, I/O @ 0x0000cc00/128, BIOS @ 0x???/524288
(II) Open ACPI successful (/var/run/acpid.socket)
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.7.6, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module 195.36.15 Fri Mar 12 01:17:05 PST 2010
(II) Loading extension GLX
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.7.6, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “dri2”
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.6, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: “nvidia”
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: X.Org Video Driver
(II) NVIDIA dlloader X Driver 195.36.15 Fri Mar 12 00:38:50 PST 2010
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01@00:00:0
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module “wfb”
(II) LoadModule: “wfb”
(II) Loading /usr/lib/xorg/modules/libwfb.so
(II) Module wfb: vendor="X.Org Foundation"
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”
(II) Module “ramdac” already built-in
() NVIDIA(0): Depth 24, (–) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
() NVIDIA(0): Option “TwinView” “0”
() NVIDIA(0): Option “MetaModes” “DFP: 1600x900_60 +0+0”
() Apr 14 12:20:19 NVIDIA(0): Enabling RENDER acceleration
(II) Apr 14 12:20:19 NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
(II) Apr 14 12:20:19 NVIDIA(0): enabled.
(II) Apr 14 12:20:20 NVIDIA(0): NVIDIA GPU GeForce GT 240M (GT216) at PCI:1:0:0 (GPU-0)
(–) Apr 14 12:20:20 NVIDIA(0): Memory: 1048576 kBytes
(–) Apr 14 12:20:20 NVIDIA(0): VideoBIOS: 70.16.24.00.05
(II) Apr 14 12:20:20 NVIDIA(0): Detected PCI Express Link width: 16X
(–) Apr 14 12:20:20 NVIDIA(0): Interlaced video modes are supported on this GPU
(–) Apr 14 12:20:20 NVIDIA(0): Connected display device(s) on GeForce GT 240M at PCI:1:0:0:
(–) Apr 14 12:20:20 NVIDIA(0): LGD (DFP-0)
(–) Apr 14 12:20:20 NVIDIA(0): LGD (DFP-0): 330.0 MHz maximum pixel clock
(–) Apr 14 12:20:20 NVIDIA(0): LGD (DFP-0): Internal Dual Link LVDS
(II) Apr 14 12:20:20 NVIDIA(0): Display Device found referenced in MetaMode: DFP-0
(II) Apr 14 12:20:20 NVIDIA(0): Assigned Display Device: DFP-0
(II) Apr 14 12:20:20 NVIDIA(0): Validated modes:
(II) Apr 14 12:20:20 NVIDIA(0): “DFP:1600x900_60+0+0”
(II) Apr 14 12:20:20 NVIDIA(0): Virtual screen size determined to be 1600 x 900
(–) Apr 14 12:20:21 NVIDIA(0): DPI set to (106, 108); computed from “UseEdidDpi” X config
(–) Apr 14 12:20:21 NVIDIA(0): option
(==) Apr 14 12:20:21 NVIDIA(0): Enabling 32-bit ARGB GLX visuals.
() NVIDIA(1): Depth 24, (–) framebuffer bpp 32
(==) NVIDIA(1): RGB weight 888
(==) NVIDIA(1): Default visual is TrueColor
(==) NVIDIA(1): Using gamma correction (1.0, 1.0, 1.0)
() NVIDIA(1): Option “TwinView” “0”
() NVIDIA(1): Option “MetaModes” “CRT: nvidia-auto-select +0+0”
() NVIDIA(1): Option “TwinViewXineramaInfoOrder” “CRT-0”
() Apr 14 12:20:21 NVIDIA(1): Enabling RENDER acceleration
(II) Apr 14 12:20:21 NVIDIA(1): NVIDIA GPU GeForce GT 240M (GT216) at PCI:1:0:0 (GPU-0)
(–) Apr 14 12:20:21 NVIDIA(1): Memory: 1048576 kBytes
(–) Apr 14 12:20:21 NVIDIA(1): VideoBIOS: 70.16.24.00.05
(II) Apr 14 12:20:21 NVIDIA(1): Detected PCI Express Link width: 16X
(–) Apr 14 12:20:21 NVIDIA(1): Interlaced video modes are supported on this GPU
(–) Apr 14 12:20:21 NVIDIA(1): Connected display device(s) on GeForce GT 240M at PCI:1:0:0:
(–) Apr 14 12:20:21 NVIDIA(1): LGD (DFP-0)
(–) Apr 14 12:20:21 NVIDIA(1): LGD (DFP-0): 330.0 MHz maximum pixel clock
(–) Apr 14 12:20:21 NVIDIA(1): LGD (DFP-0): Internal Dual Link LVDS
(EE) Apr 14 12:20:21 NVIDIA(1): Unable to find available Display Devices for screen 1.
(EE) Apr 14 12:20:21 NVIDIA(1): No display devices found for this X screen.
(II) UnloadModule: “nvidia”
(II) UnloadModule: “wfb”
(II) UnloadModule: “fb”
(–) Depth 24 pixmap format is 32 bpp
(II) Apr 14 12:20:21 NVIDIA: Using 768.00 MB of virtual memory for indirect framebuffer
(II) Apr 14 12:20:21 NVIDIA: access.
(II) Apr 14 12:20:21 NVIDIA(0): Initialized GPU GART.
(II) Apr 14 12:20:21 NVIDIA(0): ACPI display change hotkey events enabled: the X server is new
(II) Apr 14 12:20:21 NVIDIA(0): enough to receive ACPI hotkey events.
(II) Apr 14 12:20:21 NVIDIA(0): ACPI brightness change hotkey events enabled.
(II) Apr 14 12:20:21 NVIDIA(0): Setting mode “DFP:1600x900_60+0+0”
(II) Loading extension NV-GLX
(II) Apr 14 12:20:22 NVIDIA(0): Initialized OpenGL Acceleration
(==) NVIDIA(0): Disabling shared memory pixmaps
(II) Apr 14 12:20:22 NVIDIA(0): Initialized X Rendering Acceleration
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
() NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
SELinux: Disabled on system, not enabling in X server
(II) Initializing extension GLX
(II) config/udev: Adding input device Power Button (/dev/input/event4)
(II) LoadModule: “evdev”
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.5, module version = 2.3.2
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 7.0
() Power Button: always reports core events
() Power Button: Device: “/dev/input/event4”
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD)
() Option “xkb_rules” “evdev”
() Option “xkb_model” “pc105”
() Option “xkb_layout” “fr”
() Option “xkb_variant” “latin9”
(II) config/udev: Adding input device Video Bus (/dev/input/event5)
() Video Bus: always reports core events
() Video Bus: Device: “/dev/input/event5”
(II) Video Bus: Found keys
(II) Video Bus: Configuring as keyboard
(II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD)
(II) config/udev: Adding input device Lid Switch (/dev/input/event3)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device Sleep Button (/dev/input/event2)
() Sleep Button: always reports core events
() Sleep Button: Device: “/dev/input/event2”
(II) Sleep Button: Found keys
(II) Sleep Button: Configuring as keyboard
(II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD)
(II) config/udev: Adding input device CNF7129 (/dev/input/event9)
() CNF7129: always reports core events
() CNF7129: Device: “/dev/input/event9”
(II) CNF7129: Found keys
(II) CNF7129: Configuring as keyboard
(II) XINPUT: Adding extended input device “CNF7129” (type: KEYBOARD)
(II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event10)
(II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event1)
() AT Translated Set 2 keyboard: always reports core events
() AT Translated Set 2 keyboard: Device: “/dev/input/event1”
(II) AT Translated Set 2 keyboard: Found keys
(II) AT Translated Set 2 keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD)
(II) config/udev: Adding input device ImPS/2 Logitech Wheel Mouse (/dev/input/event8)
() ImPS/2 Logitech Wheel Mouse: always reports core events
() ImPS/2 Logitech Wheel Mouse: Device: “/dev/input/event8”
(II) ImPS/2 Logitech Wheel Mouse: Found 3 mouse buttons
(II) ImPS/2 Logitech Wheel Mouse: Found scroll wheel(s)
(II) ImPS/2 Logitech Wheel Mouse: Found relative axes
(II) ImPS/2 Logitech Wheel Mouse: Found x and y relative axes
(II) ImPS/2 Logitech Wheel Mouse: Configuring as mouse
() ImPS/2 Logitech Wheel Mouse: YAxisMapping: buttons 4 and 5
() ImPS/2 Logitech Wheel Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device “ImPS/2 Logitech Wheel Mouse” (type: MOUSE)
(II) ImPS/2 Logitech Wheel Mouse: initialized for relative axes.
(II) config/udev: Adding input device ImPS/2 Logitech Wheel Mouse (/dev/input/mouse1)
(II) config/udev: Adding input device PC Speaker (/dev/input/event6)
(II) config/udev: Adding input device Macintosh mouse button emulation (/dev/input/event0)
() Macintosh mouse button emulation: always reports core events
() Macintosh mouse button emulation: Device: “/dev/input/event0”
(II) Macintosh mouse button emulation: Found 3 mouse buttons
(II) Macintosh mouse button emulation: Found relative axes
(II) Macintosh mouse button emulation: Found x and y relative axes
(II) Macintosh mouse button emulation: Configuring as mouse
() Macintosh mouse button emulation: YAxisMapping: buttons 4 and 5
() Macintosh mouse button emulation: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device “Macintosh mouse button emulation” (type: MOUSE)
(II) Macintosh mouse button emulation: initialized for relative axes.
(II) config/udev: Adding input device Macintosh mouse button emulation (/dev/input/mouse0)
(II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event11)
() ACPI Virtual Keyboard Device: always reports core events
() ACPI Virtual Keyboard Device: Device: “/dev/input/event11”
(II) ACPI Virtual Keyboard Device: Found keys
(II) ACPI Virtual Keyboard Device: Configuring as keyboard
(II) XINPUT: Adding extended input device “ACPI Virtual Keyboard Device” (type: KEYBOARD)
(II) config/udev: Adding input device Asus Laptop extra buttons (/dev/input/event7)
() Asus Laptop extra buttons: always reports core events
() Asus Laptop extra buttons: Device: “/dev/input/event7”
(II) Asus Laptop extra buttons: Found keys
(II) Asus Laptop extra buttons: Configuring as keyboard
(II) XINPUT: Adding extended input device “Asus Laptop extra buttons” (type: KEYBOARD)
(II) Power Button: Close
(II) UnloadModule: “evdev”
(II) Video Bus: Close
(II) Sleep Button: Close
(II) CNF7129: Close
(II) AT Translated Set 2 keyboard: Close
(II) ImPS/2 Logitech Wheel Mouse: Close
(II) Macintosh mouse button emulation: Close
(II) ACPI Virtual Keyboard Device: Close
(II) Asus Laptop extra buttons: Close
(II) UnloadModule: “evdev”[/quote]
kdm.log
[quote]X.Org X Server 1.7.6
Markers: (–) probed, (**) from config file, (==) default setting,
The XKEYBOARD keymap compiler (xkbcomp) reports:
Warning: Type “ONE_LEVEL” has 1 levels, but has 2 symbols
Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
kdmgreet: Fatal IO error: client killed[/quote]
Et voila mon Xorg :
[quote]# nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 1.0 (buildmeister@builder58) Fri Mar 12 02:12:40 PST 2010
nvidia-settings: X configuration file generated by nvidia-settings
nvidia-settings: version 1.0 (buildmeister@builder58) Wed Dec 9 16:35:48 PST 2009
Section "ServerLayout"
Identifier "Layout0"
Screen 0 “Screen0” 0 0
Screen 1 “Screen1” 1600 0
InputDevice “Keyboard0” "CoreKeyboard"
InputDevice “Mouse0” "CorePointer"
Option “Xinerama” "1"
EndSection
Section "Files"
EndSection
Section “InputDevice”
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "LGD"
HorizSync 30.0 - 75.0
VertRefresh 60.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "hp L1530"
HorizSync 30.0 - 63.0
VertRefresh 56.0 - 76.0
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GT 240M"
BusID "PCI:1:0:0"
Screen 0
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BusID "PCI:1:0:0"
Screen 1
EndSection
Section “Screen”
Removed Option “metamodes” “DFP: nvidia-auto-select +0+0”
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "TwinView" "0"
Option "metamodes" "DFP: 1600x900_60 +0+0"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option “TwinView” "0"
Option “TwinViewXineramaInfoOrder” "CRT-0"
Option “metamodes” "CRT: nvidia-auto-select +0+0"
Depth 24
EndSubSection
EndSection
