Lenteur démarage debian 11
Tout est dans le titre je vous donne les retours des commande que j’ai faites désolé je débute .
systemd-analyze
Startup finished in 8.109s (kernel) + 28.376s (userspace) = 36.486s
graphical.target reached after 27.238s in userspace
systemd-analyze blame
35.958s apt-daily-upgrade.service
11.153s blueman-mechanism.service
 6.200s dev-sda2.device
 5.569s udisks2.service
 4.278s lightdm.service
 4.255s plymouth-quit-wait.service
 4.104s cups.service
 3.155s upower.service
 2.922s hddtemp.service
 2.908s NetworkManager.service
 2.819s ntp.service
 2.803s ModemManager.service
 2.412s accounts-daemon.service
 2.177s polkit.service
 2.107s networking.service
 1.858s avahi-daemon.service
 1.650s wpa_supplicant.service
 1.645s systemd-logind.service
 1.584s rsyslog.service
 1.535s systemd-tmpfiles-clean.service
 1.319s e2scrub_reap.service
 1.126s tlp.service
 1.112s colord.service
lines 1-23
La config de mon pc ci dessous
sudo hwinfo --short
cpu:
                       AMD Turion(tm) II Dual-Core Mobile M520, 800 MHz
keyboard:
  /dev/input/event0    AT Translated Set 2 keyboard
mouse:
  /dev/input/mice      Logitech Wireless Receiver
  /dev/input/mice      SynPS/2 Synaptics TouchPad
joystick:
  /dev/input/event7    ST LIS3LV02DL Accelerometer
monitor:
                       LG Display LP156WH2-TLD2
graphics card:
                       ATI RS880M [Mobility Radeon HD 4225/4250]
sound:
                       ATI RS880 HDMI Audio [Radeon HD 4200 Series]
                       ATI SBx00 Azalia (Intel HDA)
storage:
                       Floppy disk controller
                       ATI SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode]
network:
  wlp9s0b1             Broadcom BCM43224 802.11a/b/g/n
  enp2s0               Marvell 88E8072 PCI-E Gigabit Ethernet Controller
network interface:
  usb0                 USB-Link network interface
  lo                   Loopback network interface
  wlp9s0b1             Ethernet network interface
  enp2s0               Ethernet network interface
disk:
  /dev/sda             TOSHIBA MK3275GS
partition:
  /dev/sda1            Partition
  /dev/sda2            Partition
  /dev/sda3            Partition
cdrom:
  /dev/sr0             PLDS DVD+-RW DS-8ABSH
usb controller:
                       ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller
                       ATI SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
                       ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
                       ATI SB7x0 USB OHCI1 Controller
bios:
                       BIOS
bridge:
                       AMD Family 10h Processor Miscellaneous Control
                       AMD Family 10h Processor Address Map
                       AMD RS780/RS880 PCI to PCI bridge (int gfx)
                       AMD RS780/RS880 PCI to PCI bridge (PCIE port 0)
                       ATI SB7x0/SB8x0/SB9x0 LPC host controller
                       AMD RS780/RS880 PCI to PCI bridge (PCIE port 3)
                       AMD RS880 Host Bridge
                       AMD Family 10h Processor Link Control
                       AMD Family 10h Processor DRAM Controller
                       AMD Family 10h Processor HyperTransport Configuration
                       ATI SBx00 PCI to PCI Bridge
                       AMD RS780/RS880 PCI to PCI bridge (PCIE port 4)
                       AMD RS780/RS880 PCI to PCI bridge (PCIE port 1)
hub:
                       Linux Foundation 1.1 root hub
                       Linux Foundation 2.0 root hub
memory:
                       Main Memory
firewire controller:
                       Ricoh R5C832 PCIe IEEE 1394 Controller
unknown:
                       FPU
                       DMA controller
                       PIC
                       Keyboard controller
  /dev/lp0             Parallel controller
                       PS/2 Controller
                       Ricoh MMC/SD Host Controller
                       Ricoh R5U2xx (R5U230 / R5U231 / R5U241) [Memory Stick Host Controller]
                       ATI SBx00 SMBus Controller
  /dev/ttyS0           16550A
                       Huawei JAT-L41
                       Chicony Electronics HP Webcam [2 MP Macro]
Non, rien n’est dans le titre. Le corps du message ne fournit non plus aucune information sur cette supposée lenteur du démarrage. Les chiffres sur ma machine sont à peine meilleurs, et je ne considère pas que c’est lent. Elle a plus de 10 ans, mais la tienne n’a pas l’air très récente non plus.
Pas mieux que la réponse de PascalHambourg
D’autant que vous avez un HDD qui n’est pas très rapide…
Les seules piste éventuelles qui pourraient etre testés c’est de retarder le lancement des services « apt-daily-upgrade.service » et « blueman-mechanism.service »
  • Soit via les config de systemd (de memoire pour apt-daily-upgrade.service c’est prévu par l’ajout d’une config dans un override.conf ou truc du genre, désolé ne ne pas être plus précis)
Toujours autour du apt-daily-upgrade.service, vérifier les temps d’accès et vitesses de transfert des dépôts que vous utiliser, pour éventuellement y mettre un « plus » rapide…
  • Soit tout simplement les désactiver pour les lancer une fois le boot terminé
Investiguer en ce sens, ce sont des pistes, vous grignoterez quelques secondes
Je me répond à moi même :wink:
Pour le service apt-daily-upgrade.service j’ai retrouvé dans mes notes l’histoire de l’override
qui peut être créé par les commandes suivantes:
sudo systemctl edit apt-daily.timer
Puis dans l’édition y mettre:
[Timer]
OnBootSec=15min
OnUnitActiveSec=1d
AccuracySec=1h
RandomizedDelaySec=30min
Vous modifiez à votre convenance les délais, plus de détails sur les options via un :
man systemd.timer
merci pour vos réponse finalement j’ai tenté ça entre vos réponse
systemctl mask NetworkManager-wait-online.service
Résultat 9 seconde de gagné
startup finished in 8.273s (kernel) + 25.592s (userspace) = 33.865s
graphical.target reached after 24.526s in userspace
Le service apt-daily-upgrade.service n’est pas lancé au démarrage mais par un timer asynchrone, son temps d’exécution ne devrait donc pas influencer le temps de démarrage.
Pourtant ce service n’était même pas mentionné par systemd-analyze blame dans ceux qui prennent plus d’une seconde. Peut-être par systemd-analyze critical-chain(qui me semble plus pertinent) ?
Pourtant je ne compte que 3 secondes d’écart avec le résultat du message initial.
