[code]console@mailgw:~$ aptitude show netfilter-extensions-source
Package: netfilter-extensions-source
New: yes
State: not installed
Version: 20070520+debian-1
Priority: extra
Section: net
Maintainer: Robert S. Edmonds edmonds@debian.org
Uncompressed Size: 49.2k
Depends: module-assistant, debhelper (>= 5), make, bzip2
Description: source for netfilter kernel modules derived from patch-o-matic-ng
This package provides the source code for the netfilter-extensions kernel modules. Kernel source or headers are required
to compile these modules.
The following netfilter extensions derived from netfilter.org’s patch-o-matic-ng repository are included:
IPV4OPTSSTRIP
ROUTE (IPv4 only)
TARPIT
ipv4options
set
u32
The modules in this package should be usable with the unmodified Linux kernel and iptables packages included in Debian;
they do not require extracted Linux kernel and iptables source trees as part of the build process.
Note that these modules are not included in the upstream Linux kernel because they may be buggy or experimental and should
be used with caution.
[/code]Je n’ai pas encore testé, mais pour ceux qui cherchaient le patch pour faire du -m route, le voilà.
Et à priori, il s’installe tout seul avec
