Lighttpd et cgi
je suis un newbie sous linux j’ai franchis le pas grace à mon serveur (KUROBOX) auquel j’ai mis une image débian (powerpc),
mon probleme est que l’interface de gestion de la box est en cgi donc dans le repertoire var/www/cgi-bin/ mais j’ai regardé ma config pour lighttpd et je n’arrive pas a comprendre ce qui empeche la prise en charge des cgi.
voici mon /etc/lighttpd/lighttpd.conf
[code]# Debian lighttpd configuration file
############ Options you really have to take care of ####################
modules to load
mod_access, mod_accesslog and mod_alias are loaded by default
all other module should only be loaded if neccesary
- saves some time
- saves memory
server.modules = (
“mod_access”,
“mod_alias”,
“mod_fastcgi”,
“mod_cgi”,
“mod_accesslog”,
“mod_rewrite”,
“mod_redirect”,
“mod_status”,
“mod_evhost”,
“mod_compress”,
“mod_usertrack”,
“mod_rrdtool”,
“mod_webdav”,
“mod_expire”,
“mod_flv_streaming”,
“mod_evasive”
a static document-root, for virtual-hosting take look at the
server.virtual-* options
server.document-root = “/var/www/”
where to send error-messages to
server.errorlog = “/var/log/lighttpd/error.log”
files to check for if …/ is requested
index-file.names = ( “index.php”, “index.html”,
“index.htm”, “default.htm” )
Use the “Content-Type” extended attribute to obtain mime type if possible
mimetype.use-xattr = “enable”
accesslog module
accesslog.filename = “/var/log/lighttpd/access.log”
deny access the file-extensions
~ is for backupfiles from vi, emacs, joe, …
.inc is often used for code includes which should in general not be part
of the document-root
url.access-deny = ( “~”, “.inc” )
######### Options that are good to be but not neccesary to be changed #######
bind to port (default: 80)
server.port = 80
bind to localhost only (default: all interfaces)
server.bind = “localhost”
error-handler for status 404
#server.error-handler-404 = “/error-handler.html”
#server.error-handler-404 = “/error-handler.php”
to help the rc.scripts
server.pid-file = “/var/run/lighttpd.pid”
Format: .html
-> …/status-404.html for ‘File not found’
#server.errorfile-prefix = “/var/www/”
virtual directory listings
dir-listing.encoding = "utf-8"
server.dir-listing = “enable”
send unhandled HTTP-header headers to error-log
#debug.dump-unknown-headers = “enable”
only root can use these options
chroot() to directory (default: no chroot() )
#server.chroot = “/”
change uid to (default: don’t care)
#server.username = “www-data”
evhost.path-pattern = “/home/storage/dev/www/%3/htdocs/”
expire module
expire.url = ( “/buggy/” => “access 2 hours”, “/asdhas/” => “access plus 1 seconds 2 minutes”)
rrdtool
rrdtool.binary = “/usr/bin/rrdtool”
rrdtool.db-name = “/var/www/lighttpd.rrd”
handle Debian Policy Manual, Section 11.5. urls
and by default allow them only from localhost
#$HTTP[“remoteip”] =~ “127.0.0.1” {
alias.url += (
“/doc/” => “/usr/share/doc/”,
“/images/” => “/usr/share/images/”
$HTTP[“url”] =~ “^/doc/|^/images/” {
dir-listing.activate = “enable”
variable usage:
variable name without “.” is auto prefixed by “var.” and becomes “var.bar”
#bar = 1
#var.mystring = “foo”
integer add
#bar += 1
string concat, with integer cast as string, result: “www.foo1.com
#server.name = “www.” + mystring + var.bar + “.com”
array merge
#index-file.names = (foo + “.php”) + index-file.names
#index-file.names += (foo + “.php”)
external configuration files
mimetype mapping
include_shell “/usr/share/lighttpd/create-mime.assign.pl”
load enabled configuration files,
read /etc/lighttpd/conf-available/README first
include_shell “/usr/share/lighttpd/include-conf-enabled.pl”[/code]
voici mon /etc/lighttpd/conf-enabled/10-cgi.conf
[code]## CGI programs allow you to enhance the functionality of the server in a very
straight and simple way…
Documentation: /usr/share/doc/lighttpd-doc/cgi.txt
http://www.lighttpd.net/documentation/cgi.html
server.modules += ( “mod_cgi” )
alias.url += ( “/cgi-bin/” => “/usr/lib/cgi-bin/” )
#$HTTP[“host”] == “localhost” {
$HTTP[“url”] =~ “/cgi-bin/” {
cgi.assign = ( “” => “” )
#$HTTP[“url”] =~ “/cgi-bin/” {
cgi.assign = (
".pl" => “/usr/bin/perl”,
".php" => “/usr/bin/php-cgi”,
".py" => “/usr/bin/python”,
".cgi" => “”,
)[/code]
et voici mon fastcgi.conf
[code]## FastCGI programs have the same functionality as CGI programs,
but are considerably faster through lower interpreter startup
time and socketed communication
Documentation: /usr/share/doc/lighttpd-doc/fastcgi.txt.gz
http://www.lighttpd.net/documentation/fastcgi.html
server.modules += ( “mod_fastcgi” )
Start an FastCGI server for php4 (needs the php4-cgi package)
fastcgi.server = ( “.php” =>
“bin-path” => “/usr/bin/php5-cgi”,
“socket” => “/tmp/php-fastcgi.socket”,
“max-procs” => 2,
“idle-timeout” => 20,
“bin-environment” => (
“PHP_FCGI_CHILDREN” => “4”,
“PHP_FCGI_MAX_REQUESTS” => “10000”
“bin-copy-environment” => (
“PATH”, “SHELL”, “USER”
“broken-scriptfilename” => “enable”
)[/code]
merci d’avance :d
je ne connais pas lighttpd, est comme ce n’est pas installé, je n’ai pas le manuel, mais en regardant un peu j’ai vu des trucs du genre:
cgi.assign = ( ".pl" => "/usr/bin/perl", ".cgi" => "/usr/bin/perl" )j’ai vu la même chose avec l’appel à php.
sinon, ce lien là m’a l’air interressant:
trac.lighttpd.net/trac/wiki/Tuto … ttpdAndPHP
ça concerne le php, mais ça doit être transposable pour les .cgi
