Machine virtuel wheezy impossible d'installer acpid
Tags: #<Tag:0x00007f46affc4250>
J’ai une machine virtuelle que je viens de mettre à jour de squeeze vers wheezy. Je rencontre actuellement ce problème : il est impossible de mettre à jour les paquet acpid et acpi-support-base.
Setting up acpid (1:2.0.16-1+deb7u1) ...
[....] Starting ACPI services...invoke-rc.d: initscript acpid, action "start" failed.
dpkg: error processing acpid (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of acpi-support-base:
 acpi-support-base depends on acpid (>= 1.0.4); however:
  Package acpid is not configured yet.
dpkg: error processing acpi-support-base (--configure):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
 acpid
 acpi-support-base
Comme ce sont les paquets qui gèrent la gestion d’énergie des batteries, je pense qu’il serait normal de les laisser désinstallé sur cette machine. Pouvez vous m’en dire plus ?
Merci de votre aide.
J’ai trouvé une solution sur un site, avec laquelle il faut ecraser d’un exit 0 le script de dameon /etc/init.d/acpid. Effectivement cela fonctionne :
The following NEW packages will be installed:
  acpi-support-base acpid
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/79.4 kB of archives.
After this operation, 249 kB of additional disk space will be used.
Selecting previously unselected package acpid.
(Reading database ... 35200 files and directories currently installed.)
Unpacking acpid (from .../acpid_1%3a2.0.16-1+deb7u1_i386.deb) ...
Selecting previously unselected package acpi-support-base.
Unpacking acpi-support-base (from .../acpi-support-base_0.140-5+deb7u3_all.deb) ...
Processing triggers for man-db ...
insserv: warning: script 'S17acpid' missing LSB tags and overrides
insserv: warning: script 'acpid' missing LSB tags and overrides
insserv: warning: current stop runlevel(s) (empty) of script `acpid' overrides LSB defaults (0 1 6).
Setting up acpi-support-base (0.140-5+deb7u3) ...
Par contre, on perd le démon de démarrage qui ne sert plus a rien puisqu’il est vide.
Qu’elles sont les impactes ?
