Merci de ton aide Desintegr
donc là j’ai trouvé un pilote 64 je crois puisqu’il estr charger…
voici le dmesg :
[code]0
ACPI: FADT (v002 A M I OEMFACP 0x04000803 MSFT 0x00000097) @ 0x000000007bfd0200
ACPI: MADT (v001 A M I OEMAPIC 0x04000803 MSFT 0x00000097) @ 0x000000007bfd0390
ACPI: MCFG (v001 A M I OEMMCFG 0x04000803 MSFT 0x00000097) @ 0x000000007bfd0400
ACPI: OEMB (v001 A M I AMI_OEM 0x04000803 MSFT 0x00000097) @ 0x000000007bfde040
ACPI: HPET (v001 A M I OEMHPET0 0x04000803 MSFT 0x00000097) @ 0x000000007bfd47e0
ACPI: DSDT (v001 1ADMB 1ADMB006 0x00000006 INTL 0x20051117) @ 0x0000000000000000
Scanning NUMA topology in Northbridge 24
Number of nodes 1
Node 0 MemBase 0000000000000000 Limit 000000007bfd0000
NUMA: Using 63 for the hash shift.
Using node hash shift of 63
Bootmem setup node 0 0000000000000000-000000007bfd0000
On node 0 totalpages: 499929
DMA zone: 3056 pages, LIFO batch:0
DMA32 zone: 496873 pages, LIFO batch:31
ACPI: PM-Timer IO Port: 0x4008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 15:11 APIC version 16
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Processor #1 15:11 APIC version 16
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
ACPI: IRQ14 used by override.
ACPI: IRQ15 used by override.
Setting APIC routing to physical flat
ACPI: HPET id: 0x10de8201 base: 0xfeff0000
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 80000000 (gap: 7c000000:82c00000)
SMP: Allowing 2 CPUs, 0 hotplug CPUs
Built 1 zonelists. Total pages: 499929
Kernel command line: root=/dev/sda1 ro
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 32768 bytes)
time.c: Using 25.000000 MHz WALL HPET GTOD HPET timer.
time.c: Detected 2712.965 MHz processor.
Console: colour VGA+ 80x25
Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Checking aperture…
CPU 0: aperture @ 1230000000 size 32 MB
Aperture too small (32 MB)
No AGP bridge found
Memory: 1991560k/2031424k available (1929k kernel code, 39476k reserved, 870k data, 176k init)
Calibrating delay using timer specific routine… 5431.83 BogoMIPS (lpj=10863660)Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 256
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
CPU 0/0 -> Node 0
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
SMP alternatives: switching to UP code
ACPI: Core revision 20060707
Using local APIC timer interrupts.
result 12560023
Detected 12.560 MHz APIC timer.
SMP alternatives: switching to SMP code
Booting processor 1/2 APIC 0x1
Initializing CPU#1
Calibrating delay using timer specific routine… 5425.07 BogoMIPS (lpj=10850145)CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU 1/1 -> Node 0
CPU: Processor Core ID: 1
AMD Athlon™ 64 X2 Dual Core Processor 5200+ stepping 02
CPU 1: Syncing TSC to CPU 0.
CPU 1: synchronized TSC with CPU 0 (last diff 13 cycles, maxerr 576 cycles)
Brought up 2 CPUs
testing NMI watchdog … OK.
migration_cost=194
checking if image is initramfs… it is
Freeing initrd memory: 4898k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: BIOS Bug: MCFG area at e0000000 is not E820-reserved
PCI: Not using MMCONFIG.
PCI: Using configuration type 1
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
Error attaching device data
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:00:0d.0
PCI: Transparent bridge - 0000:00:04.0
ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.P0P1.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.BR10.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.BR11.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.BR12._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *11
ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNEA] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNEB] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNEC] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNED] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LUB0] (IRQs 20 21 22 23) *5
ACPI: PCI Interrupt Link [LUB2] (IRQs 20 21 22 23) *10
ACPI: PCI Interrupt Link [LMAC] (IRQs 20 21 22 23) *5
ACPI: PCI Interrupt Link [LAZA] (IRQs 20 21 22 23) *11
ACPI: PCI Interrupt Link [LACI] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [LMC9] (IRQs 20 21 22 23) *10
ACPI: PCI Interrupt Link [LSMB] (IRQs 20 21 22 23) *11
ACPI: PCI Interrupt Link [LPMU] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [LSA0] (IRQs 20 21 22 23) *10
ACPI: PCI Interrupt Link [LSA1] (IRQs 20 21 22 23) *10
ACPI: PCI Interrupt Link [LATA] (IRQs 20 21 22 23) *0, disabled.
Linux Plug and Play Support v0.97 © Adam Belay
pnp: PnP ACPI init
pnp: ACPI device : hid PNP0A03
pnp: ACPI device : hid PNP0200
pnp: ACPI device : hid PNP0B00
pnp: ACPI device : hid PNP0800
pnp: ACPI device : hid PNP0C04
pnp: ACPI device : hid PNP0501
pnp: ACPI device : hid PNP0400
pnp: ACPI device : hid PNP0C02
pnp: ACPI device : hid PNP0103
pnp: ACPI device : hid PNP0303
pnp: ACPI device : hid PNP0F03
pnp: ACPI device : hid PNP0C01
pnp: PnP ACPI: found 15 devices
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Using ACPI for IRQ routing
PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
hpet0: at MMIO 0xfeff0000 (virtual 0xffffffffff5fe000), IRQs 2, 8, 31
hpet0: 3 32-bit timers, 25000000 Hz
PCI-DMA: Disabling IOMMU.
pnp: the driver ‘system’ has been registered
pnp: match found with the PnP device ‘00:07’ and the driver 'system’
pnp: match found with the PnP device ‘00:09’ and the driver 'system’
pnp: match found with the PnP device ‘00:0c’ and the driver 'system’
pnp: 00:0c: ioport range 0xa00-0xadf has been reserved
pnp: 00:0c: ioport range 0xae0-0xaef has been reserved
pnp: match found with the PnP device ‘00:0d’ and the driver 'system’
pnp: match found with the PnP device ‘00:0e’ and the driver 'system’
PCI: Bridge: 0000:00:04.0
IO window: disabled.
MEM window: feb00000-febfffff
PREFETCH window: disabled.
PCI: Bridge: 0000:00:09.0
MEM window: disabled.
PCI: Bridge: 0000:00:0b.0
PCI: Bridge: 0000:00:0c.0
PCI: Setting latency timer of device 0000:00:04.0 to 64
PCI: Setting latency timer of device 0000:00:09.0 to 64
PCI: Setting latency timer of device 0000:00:0b.0 to 64
PCI: Setting latency timer of device 0000:00:0c.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
TCP: Hash tables configured (established 262144 bind 65536)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1235591791.696:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
pcie_portdrv_probe->Dev[03e8:10de] has invalid IRQ. Check vendor BIOS
assign_interrupt_mode Found MSI capability
Allocate Port Service[0000:00:09.0:pcie00]
pcie_portdrv_probe->Dev[03e9:10de] has invalid IRQ. Check vendor BIOS
Allocate Port Service[0000:00:0b.0:pcie00]
Allocate Port Service[0000:00:0c.0:pcie00]
Real Time Clock Driver v1.12ac
hpet_resources: 0xfeff0000 is busy
Linux agpgart interface v0.101 © Dave Jones
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
pnp: the driver ‘serial’ has been registered
pnp: match found with the PnP device ‘00:05’ and the driver 'serial’
00:05: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
pnp: the driver ‘i8042 kbd’ has been registered
pnp: match found with the PnP device ‘00:0a’ and the driver 'i8042 kbd’
pnp: the driver ‘i8042 aux’ has been registered
pnp: match found with the PnP device ‘00:0b’ and the driver 'i8042 aux’
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
ACPI: (supports S0 S1 S3 S4 S5)
Freeing unused kernel memory: 176k freed
SCSI subsystem initialized
libata version 2.00 loaded.
forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.56.
ACPI: PCI Interrupt Link [LMAC] enabled at IRQ 23
GSI 16 sharing vector 0xC9 and IRQ 16
ACPI: PCI Interrupt 0000:00:07.0[A] -> Link [LMAC] -> GSI 23 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:07.0 to 64
forcedeth: using HIGHDMA
0000:00:07.0: Invalid Mac address detected: fb:b7:3b:85:21:00
Please complain to your hardware vendor. Switching to a random MAC.
ohci_hcd: 2005 April 22 USB 1.1 ‘Open’ Host Controller (OHCI) Driver (PCI)
input: AT Translated Set 2 keyboard as /class/input/input0
eth0: forcedeth.c: subsystem: 01462:7309 bound to 0000:00:07.0
ACPI: PCI Interrupt Link [LUB0] enabled at IRQ 22
GSI 17 sharing vector 0xD1 and IRQ 17
ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LUB0] -> GSI 22 (level, low) -> IRQ 209
PCI: Setting latency timer of device 0000:00:02.0 to 64
ohci_hcd 0000:00:02.0: OHCI Host Controller
ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
ohci_hcd 0000:00:02.0: irq 209, io mem 0xfeafb000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 10 ports detected
sata_nv 0000:00:08.0: version 2.0
ACPI: PCI Interrupt Link [LSA0] enabled at IRQ 21
GSI 18 sharing vector 0xD9 and IRQ 18
ACPI: PCI Interrupt 0000:00:08.0[A] -> Link [LSA0] -> GSI 21 (level, low) -> IRQ 217
PCI: Setting latency timer of device 0000:00:08.0 to 64
ata1: SATA max UDMA/133 cmd 0xE400 ctl 0xE082 bmdma 0xD880 irq 217
ata2: SATA max UDMA/133 cmd 0xE000 ctl 0xDC02 bmdma 0xD888 irq 217
scsi0 : sata_nv
usb 1-2: new full speed USB device using ohci_hcd and address 2
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata1.00: ATA-7, max UDMA/133, 488397168 sectors: LBA48 NCQ (depth 0/32)
ata1.00: ata1: dev 0 multi count 16
ata1.00: configured for UDMA/133
scsi1 : sata_nv
usb 1-2: configuration #1 chosen from 1 choice
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Initializing USB Mass Storage driver…
usb 1-4: new low speed USB device using ohci_hcd and address 3
ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata2.00: ATAPI, max UDMA/100
usb 1-4: configuration #1 chosen from 1 choice
ata2.00: configured for UDMA/100
Vendor: ATA Model: MAXTOR STM325031 Rev: 4.AA
Type: Direct-Access ANSI SCSI revision: 05
Vendor: TSSTcorp Model: CDDVDW SH-S223F Rev: SB02
Type: CD-ROM ANSI SCSI revision: 05
ACPI: PCI Interrupt Link [LSA1] enabled at IRQ 20
GSI 19 sharing vector 0xE1 and IRQ 19
ACPI: PCI Interrupt 0000:00:08.1[B] -> Link [LSA1] -> GSI 20 (level, low) -> IRQ 225
PCI: Setting latency timer of device 0000:00:08.1 to 64
ata3: SATA max UDMA/133 cmd 0xD800 ctl 0xD482 bmdma 0xD000 irq 225
ata4: SATA max UDMA/133 cmd 0xD400 ctl 0xD082 bmdma 0xD008 irq 225
scsi2 : sata_nv
usb 1-5: new full speed USB device using ohci_hcd and address 4
ata3: SATA link down (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0xD807
scsi3 : sata_nv
usb 1-5: configuration #1 chosen from 1 choice
scsi4 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
scsi5 : SCSI emulation for USB Mass Storage devices
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 4
usbcore: registered new driver hiddev
input: Logitech USB Receiver as /class/input/input1
input: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-0000:00:02.0-4
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
ata4: SATA link down (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0xD407
ACPI: PCI Interrupt Link [LUB2] enabled at IRQ 23
ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [LUB2] -> GSI 23 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:02.1 to 64
ehci_hcd 0000:00:02.1: EHCI Host Controller
ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 2
ehci_hcd 0000:00:02.1: debug port 1
PCI: cache line size of 64 is not supported by device 0000:00:02.1
ehci_hcd 0000:00:02.1: irq 201, io mem 0xfeafac00
ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 10 ports detected
NFORCE-MCP61: IDE controller at PCI slot 0000:00:06.0
NFORCE-MCP61: chipset revision 162
NFORCE-MCP61: not 100% native mode: will probe irqs later
NFORCE-MCP61: 0000:00:06.0 (rev a2) UDMA133 controller
ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:pio, hdb:pio
Probing IDE interface ide0…
SCSI device sda: 488397168 512-byte hdwr sectors (250059 MB)
sda: Write Protect is off
sda: Mode Sense: 00 3a 00 00
SCSI device sda: drive cache: write back
sda: sda1 sda2 sda3 sda4
sd 0:0:0:0: Attached scsi disk sda
usb 2-2: new high speed USB device using ehci_hcd and address 2
usb 2-2: configuration #1 chosen from 1 choice
scsi6 : SCSI emulation for USB Mass Storage devices
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
usb 2-5: new high speed USB device using ehci_hcd and address 4
usb 2-5: configuration #1 chosen from 1 choice
scsi7 : SCSI emulation for USB Mass Storage devices
usb 1-2: USB disconnect, address 2
usb 1-4: USB disconnect, address 3
usb 1-4: new low speed USB device using ohci_hcd and address 5
input: Logitech USB Receiver as /class/input/input2
usb 1-5: USB disconnect, address 4
sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
Uniform CD-ROM driver Revision: 3.20
sr 1:0:0:0: Attached scsi CD-ROM sr0
ts: Compaq touchscreen protocol output
input: PC Speaker as /class/input/input3
sd 0:0:0:0: Attached scsi generic sg0 type 0
sr 1:0:0:0: Attached scsi generic sg1 type 5
pnp: the driver ‘parport_pc’ has been registered
pnp: match found with the PnP device ‘00:06’ and the driver 'parport_pc’
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
EXT3 FS on sda1, internal journal
loop: loaded (max 8 devices)
ndiswrapper version 1.53 loaded (smp=yes, preempt=no)
usbcore: registered new driver ndiswrapper
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
Vendor: Hitachi Model: HDT725050VLAT80 Rev: V56O
Type: Direct-Access ANSI SCSI revision: 00
SCSI device sdb: 976773168 512-byte hdwr sectors (500108 MB)
sdb: Write Protect is off
sdb: Mode Sense: 03 00 00 00
sdb: assuming drive cache: write through
sdb:<5> Vendor: Kingston Model: DataTraveler 2.0 Rev: 1.00
Type: Direct-Access ANSI SCSI revision: 02
SCSI device sdc: 1952768 512-byte hdwr sectors (1000 MB)
sdc: Write Protect is off
sdc: Mode Sense: 23 00 00 00
sdc: assuming drive cache: write through
sdc: sdc1
sd 7:0:0:0: Attached scsi removable disk sdc
sd 7:0:0:0: Attached scsi generic sg2 type 0
usb-storage: device scan complete
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
lp0: using parport0 (interrupt-driven).
ppdev: user-space parallel port driver
Installing knfsd (copyright © 1996 okir@monad.swb.de).
NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
NFSD: starting 90-second grace period
sdb1
sd 6:0:0:0: Attached scsi disk sdb
sd 6:0:0:0: Attached scsi generic sg3 type 0
NET: Registered protocol family 5
NTFS driver 2.1.27 [Flags: R/W MODULE].
NTFS-fs warning (device sdb1): parse_options(): Option iocharset is deprecated. Please use option nls= in the future.
NTFS volume version 3.1.
NTFS-fs error (device sdb1): load_system_files(): Volume is dirty. Mounting read-only. Run chkdsk and mount in Windows.
FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
eth16: no IPv6 routers present
usbcore: deregistering driver ndiswrapper
ndiswrapper (link_pe_images:575): fixing KI_USER_SHARED_DATA address in the driver
ndiswrapper: driver netmw126 (Marvell,12/30/2005,3.2.3.2) loaded
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 19
GSI 20 sharing vector 0x32 and IRQ 20
ACPI: PCI Interrupt 0000:01:0a.0[A] -> Link [LNKC] -> GSI 19 (level, low) -> IRQ 50
ndiswrapper: using IRQ 50
Unable to handle kernel paging request at ffffc2025eac0188 RIP:
PGD 7a49d067 PUD 0
Oops: 0000 [1] SMP
CPU 1
Modules linked in: ndiswrapper nls_cp437 vfat fat nls_utf8 ntfs appletalk nfs nfsd exportfs lockd nfs_acl sunrpc ppdev lp button ac battery ipv6 dm_snapshot dm_mirror dm_mod loop serio_raw parport_pc parport psmouse sg pcspkr tsdev sr_mod cdrom evdev ext3 jbd mbcache sd_mod amd74xx generic usbhid usb_storage ide_core ehci_hcd sata_nv ohci_hcd forcedeth libata scsi_mod thermal processor fan
Pid: 4266, comm: modprobe Tainted: P 2.6.18-6-amd64 #1
RIP: 0010:[] []
RSP: 0018:ffff81005cce1890 EFLAGS: 00010216
RAX: 000000025e992800 RBX: ffff810061c84600 RCX: 0000000000000000
RDX: 00000000097a64a0 RSI: 0000000000000004 RDI: ffff81006c3b02c0
RBP: ffff810061c84a30 R08: ffffc2000012d950 R09: ffff81005cce17b8
R10: ffffffff8817e514 R11: ffffffff8022e148 R12: ffff8100639d1030
R13: ffff81005cce1bd8 R14: ffff81005cce1b78 R15: 0000000000000000
FS: 00002b366d0e06d0(0000) GS:ffff810001355ac0(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffffc2025eac0188 CR3: 0000000064d5f000 CR4: 00000000000006e0
Process modprobe (pid: 4266, threadinfo ffff81005cce0000, task ffff81005f026870)Stack: ffff81005e546500 0000000000000001 ffffffff00000000 ffffc200000e47d9
ffff81005cce1b78 ffff8100639d1030 ffff81006c3b02c0 0000000000000004
ffff810061c84600 ffffc200000e1062 ffffc20000077000 ffffc200001032a7
Call Trace:
[] _spin_lock_bh+0x9/0x14
[] :ndiswrapper:IoAcquireCancelSpinLock+0x10/0x15
[] :ndiswrapper:mp_init+0xa5/0x1d5
[] :ndiswrapper:IoSyncForwardIrp+0x62/0x89
[] :ndiswrapper:NdisDispatchPnp+0x7c/0xd63
[] wait_for_completion+0x8a/0xc1
[] default_wake_function+0x0/0xe
[] :ndiswrapper:win2lin2+0xe/0x11
[] :ndiswrapper:IofCallDriver+0x5a/0xb1
[] :ndiswrapper:IofCallDriver+0x85/0xb1
[] :ndiswrapper:IoBuildSynchronousFsdRequest+0x27/0x2e
[] :ndiswrapper:IoSendIrpTopDev+0x94/0xca
[] :ndiswrapper:pnp_start_device+0x45/0x88
[] :ndiswrapper:wrap_pnp_start_device+0x1ec/0x210
[] :ndiswrapper:wrap_pnp_start_pci_device+0x50/0x56
[] pci_device_probe+0xdf/0x147
[] driver_probe_device+0x52/0xa8
[] __driver_attach+0x0/0x9a
[] __driver_attach+0x50/0x9a
[] bus_for_each_dev+0x43/0x6e
[] bus_add_driver+0x7e/0x130
[] __pci_register_driver+0x57/0x7d
[] :ndiswrapper:loader_init+0xab/0x11a
[] :ndiswrapper:wrapper_init+0x7b/0xb0
[] sys_init_module+0x16cc/0x1882
[] system_call+0x7e/0x83
Code: 4a 39 4c 00 38 0f 84 83 00 00 00 8b ca 48 c1 e1 06 bb 02 00
RIP []
RSP
<7>ISO 9660 Extensions: Microsoft Joliet Level 3
ISOFS: changing to secondary root
[/code]mais iwconfig ne me donne rien
je ne c plus comment faire
