Un de mes ordinateurs portables a un problème (lié au disque dur car quand je le change, pas de problème) depuis qu’un petit chat a décidé que l’ordinateur était mieux par terre que sur le sol
Au démarrage je vois le message suivant en boucle durant 3minutes (environ), puis je tombe sur ma session gdm naturellement (le chargement de la session est long et quand je lance gparted, /dev/sda a un chargement étrangement long également)
[ 5.311482] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 5.311531] ata1.00: BMDMA stat 0x25
[ 5.311571] ata1.00: failed command: READ DMA
[ 5.311617] ata1.00: cmd c8/00:08:50:01:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 5.311619] res 51/40:04:54:01:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 5.311708] ata1.00: status: { DRDY ERR }
[ 5.311748] ata1.00: error: { UNC }
[ 5.332433] ata1.00: configured for UDMA/133
[ 5.332445] ata1: EH complete
J’ai tenté voir les erreurs avec
[code]root@debian:/home/tt# smartctl -l error /dev/sda
smartctl 5.41 2011-06-09 r3365 [i686-linux-3.2.0-3-686-pae] (local build)
Copyright © 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF READ SMART DATA SECTION ===
SMART Error Log Version: 1
ATA Error Count: 285 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It “wraps” after 49.710 days.
Error 285 occurred at disk power-on lifetime: 11269 hours (469 days + 13 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 04 54 01 00 e0 Error: UNC 4 sectors at LBA = 0x00000154 = 340
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 08 50 01 00 e0 08 00:19:40.900 READ DMA
27 00 00 00 00 00 e0 08 00:19:40.900 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 08 00:19:40.900 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 08 00:19:40.900 SET FEATURES [Set transfer mode]
Error 284 occurred at disk power-on lifetime: 11269 hours (469 days + 13 hours)
c8 00 08 50 01 00 e0 08 00:19:37.300 READ DMA
27 00 00 00 00 00 e0 08 00:19:37.300 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 08 00:19:37.300 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 08 00:19:37.300 SET FEATURES [Set transfer mode]
Error 283 occurred at disk power-on lifetime: 11269 hours (469 days + 13 hours)
c8 00 08 50 01 00 e0 08 00:19:33.600 READ DMA
27 00 00 00 00 00 e0 08 00:19:33.600 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 08 00:19:33.600 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 08 00:19:33.600 SET FEATURES [Set transfer mode]
Error 282 occurred at disk power-on lifetime: 11269 hours (469 days + 13 hours)
c8 00 08 50 01 00 e0 08 00:19:29.900 READ DMA
27 00 00 00 00 00 e0 08 00:19:29.900 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 08 00:19:29.900 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 08 00:19:29.900 SET FEATURES [Set transfer mode]
Error 281 occurred at disk power-on lifetime: 11269 hours (469 days + 13 hours)
c8 00 08 50 01 00 e0 08 00:19:26.300 READ DMA
27 00 00 00 00 00 e0 08 00:19:26.300 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 08 00:19:26.300 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 08 00:19:26.300 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 08 00:19:26.300 READ NATIV[/code]
Est-ce que je peux faire quelque chose où ce disque dur est voué à s’éteindre pour de bon ?
Ne connaissant rien dans ce domaine je sais pas quelles données donner …
Le disque dur c’est un SATA (serial ATA 500GB)
EDIT : Je précise que je n’ai aucun problème apparent de données et que l’analyseur d’utilisation de gnome a l’air de bien marcher …
