J’ai été catapulté responsable d’un serveur dédié tournant sous Debian. Tout doucement, avec différents tutoriaux, je commence péniblement à m’y retrouver.
Cependant, j’ai des erreurs au niveau de mon log Apache et je ne vois pas trop comment résoudre le problème.
Voici ce que je peux voir :
root@xxxx:/# php5 -v
No log handling enabled - turning on stderr logging
Cannot find module (HOST-RESOURCES-MIB): At line 0 in (none)
Cannot find module (HOST-RESOURCES-TYPES): At line 0 in (none)
Cannot find module (UCD-DLMOD-MIB): At line 0 in (none)
Cannot find module (UCD-DISKIO-MIB): At line 0 in (none)
Cannot find module (LM-SENSORS-MIB): At line 0 in (none)
Cannot find module (IP-MIB): At line 0 in (none)
Cannot find module (IF-MIB): At line 0 in (none)
Cannot find module (TCP-MIB): At line 0 in (none)
Cannot find module (UDP-MIB): At line 0 in (none)
Cannot find module (SNMPv2-MIB): At line 0 in (none)
Cannot find module (SNMPv2-SMI): At line 0 in (none)
Cannot find module (NOTIFICATION-LOG-MIB): At line 0 in (none)
Cannot find module (DISMAN-EVENT-MIB): At line 0 in (none)
Cannot find module (DISMAN-SCHEDULE-MIB): At line 0 in (none)
Cannot find module (UCD-SNMP-MIB): At line 0 in (none)
Cannot find module (UCD-DEMO-MIB): At line 0 in (none)
Cannot find module (SNMP-TARGET-MIB): At line 0 in (none)
Cannot find module (NET-SNMP-AGENT-MIB): At line 0 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 0 in (none)
Cannot find module (SNMP-MPD-MIB): At line 0 in (none)
Cannot find module (SNMP-USER-BASED-SM-MIB): At line 0 in (none)
Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 0 in (none)
Cannot find module (SNMP-COMMUNITY-MIB): At line 0 in (none)
Cannot find module (IPV6-ICMP-MIB): At line 0 in (none)
Cannot find module (IPV6-MIB): At line 0 in (none)
Cannot find module (IPV6-TCP-MIB): At line 0 in (none)
Cannot find module (IPV6-UDP-MIB): At line 0 in (none)
Cannot find module (IP-FORWARD-MIB): At line 0 in (none)
Cannot find module (NET-SNMP-EXTEND-MIB): At line 0 in (none)
Cannot find module (SNMP-NOTIFICATION-MIB): At line 0 in (none)
Cannot find module (SNMPv2-TM): At line 0 in (none)
Cannot find module (NET-SNMP-VACM-MIB): At line 0 in (none)
PHP 5.2.6-1+lenny9 with Suhosin-Patch 0.9.6.2 (cli) (built: Aug 4 2010 03:25:57)
Copyright (c) 1997-2008 The PHP Group
Zend Engine v2.2.0, Copyright (c) 1998-2008 Zend Technologies
Merci d’avance pour votre aide, je suis perdu
Christophe
