J’ai installé smartmontools et lancé:
$sudo smartctl -i /dev/sde
smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.19.0-16-amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Read Device Identity failed: scsi error unsupported field in scsi command
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
puis:
$sudo smartctl -i -T permissive /dev/sde
=== START OF INFORMATION SECTION ===
Device Model: [No Information Found]
Serial Number: [No Information Found]
Firmware Version: [No Information Found]
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: [No Information Found]
Local Time is: Wed Apr 14 15:34:05 2021 CEST
SMART support is: Ambiguous - ATA IDENTIFY DEVICE words 82-83 don't show if SMART supported.
SMART support is: Ambiguous - ATA IDENTIFY DEVICE words 85-87 don't show if SMART is enabled.
SMART support is: Unknown - Try option -s with argument 'on' to enable it.
puis:
$sudo smartctl -i -s on -T permissive -T permissive /dev/sde
Local Time is: Wed Apr 14 15:37:10 2021 CEST
Checking to be sure by trying SMART RETURN STATUS command.
(etc, jusqu’à 4 fois « -T permissive » )
Je pense repartitionner:
umount /dev/sde1
mkfs.ext4 /dev/sde1
Puis recréer le volume physique et les 2 volumes logiques, à moins que le recours à LVM soit la cause de la difficulté?
Est-ce une bonne démarche, ou faut-il explorer autrement ?
