PAs de soucis pour les infos, meme si ma question restait basée sur un cas tres theorique.
Je n’ai pas pu tester le mount, car bien sur c’etait le jour, mais impossible de se connecter en remote. Je le ferait ce soir.
Voici en tout cas les questions demandées
[code]# cat /proc/mdstat
Personalities : [raid1]
md0 : inactive sdc11
488383936 blocks
md1 : active raid1 sdd1[0] sde1[1]
1465135936 blocks [2/2] [UU]
md2 : active raid1 sdf1[0] sdg1[1]
1465134841 blocks super 1.2 [2/2] [UU]
unused devices:
[code]# fdisk -l
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders
Disk identifier: 0x0005f543
/dev/sda1 * 1 382 3068383+ 83 Linux
/dev/sda2 383 443 489982+ 82 Linux swap / Solaris
/dev/sda3 444 60801 484825635 f W95 Ext’d (LBA)
/dev/sda5 445 60801 484817602+ 83 Linux
Disk /dev/sdb: 500.1 GB, 500107862016 bytes
Disk identifier: 0xf4baf4ba
/dev/sdb1 1 60801 488384001 fd Linux raid autodetect
Disk /dev/sdd: 1500.3 GB, 1500301910016 bytes
255 heads, 63 sectors/track, 182401 cylinders
Disk identifier: 0x000d923c
/dev/sdd1 1 182401 1465136001 fd Linux raid autodetect
Disk /dev/sdf: 1500.3 GB, 1500301910016 bytes
Disk identifier: 0x6f018f9b
/dev/sdf1 1 182401 1465136001 83 Linux
Disk /dev/sde: 1500.3 GB, 1500301910016 bytes
Disk identifier: 0xbbbbbbbb
/dev/sde1 1 182401 1465136001 fd Linux raid autodetect
Disk /dev/sdg: 1500.3 GB, 1500301910016 bytes
Disk identifier: 0x6f018f9a
/dev/sdg1 1 182401 1465136001 83 Linux
Disk /dev/sdc: 500.1 GB, 500107862016 bytes
Disk identifier: 0xf4baf4bb
/dev/sdc1 1 60801 488384001 fd Linux raid autodetect
Disk /dev/md2: 1500.3 GB, 1500298077184 bytes
2 heads, 4 sectors/track, 366283710 cylinders
Units = cylinders of 8 * 512 = 4096 bytes
Disk identifier: 0x00000000
Disk /dev/md2 doesn’t contain a valid partition table
Disk /dev/md1: 1500.3 GB, 1500299198464 bytes
2 heads, 4 sectors/track, 366283984 cylinders
Disk /dev/md1 doesn’t contain a valid partition table
