j’ai installé un reseau nfs
et openvpn
qui fonctionne assez bien MAIS parfois non. en général je lance
systemctl restart nfs-server.service
et ça fonctionne mais pas toujours, parfois je dois redémarer les machines.
C’est aléatoire et surtout c’est bizarre, n’est ce pas ?
le message d’erreur est
root@tchumoportable-HP01:~# mount -t nfs tchumoserveur:/mnt/data /mnt/data -v
mount.nfs: timeout set for Tue Feb 1 10:38:48 2022
mount.nfs: trying text-based options 'vers=4.2,addr=192.168.1.51,clientaddr=192.168.1.55'
mount.nfs: mount(2): Connection refused
mount.nfs: trying text-based options 'addr=192.168.1.51'
mount.nfs: prog 100003, trying vers=3, prot=6
mount.nfs: portmap query retrying: RPC: Program not registered
mount.nfs: prog 100003, trying vers=3, prot=17
mount.nfs: portmap query failed: RPC: Program not registered
mount.nfs: requested NFS version or transport protocol is not supported
j’ai peut être mal configuré /etc/exports/
par exemple
/mnt/data 192.168.1.55(rw,no_root_squash)
car j’ai ça
root@tchumoserveur:~# systemctl status nfs-server.service
● nfs-server.service - NFS server and services
Loaded: loaded (/lib/systemd/system/nfs-server.service; enabled; vendor prese
Active: failed (Result: exit-code) since Tue 2022-02-01 10:40:28 CET; 39s ago
Process: 1951 ExecStartPre=/usr/sbin/exportfs -r (code=exited, status=1/FAILUR
Process: 1952 ExecStopPost=/usr/sbin/exportfs -au (code=exited, status=0/SUCCE
Process: 1953 ExecStopPost=/usr/sbin/exportfs -f (code=exited, status=0/SUCCES
Feb 01 10:40:28 tchumoserveur exportfs[1951]: Assuming default behaviour ('no_
Feb 01 10:40:28 tchumoserveur exportfs[1951]: NOTE: this default has changed s
Feb 01 10:40:28 tchumoserveur exportfs[1951]: exportfs: /etc/exports [30]: Neith
Feb 01 10:40:28 tchumoserveur exportfs[1951]: exportfs: /etc/exports [31]: Neith
Feb 01 10:40:28 tchumoserveur systemd[1]: nfs-server.service: Failed with result
Feb 01 10:40:28 tchumoserveur systemd[1]: Failed to start NFS server and service
lines 1-17/17 (END)...skipping...
