Nvidia Facile - Installation des pilotes nvidia pour Debian
bonjour,
je viens d’installer debian 5.03 sur mon nouveau pc avec une cg nvidia n220gt
j’ai essayer de suivre les tutos mais bien sur j’ai droit à un plantage
lsmod |grep nvidia nvidia 8105072 0 i2c_core 27936 2 nvidia,i2c_i801 ip-124:/home/jean# vi /etc/X11/xorg.conf.nvidia ip-124:/home/jean# dpkg -l |grep nvidia ii nvidia-glx 173.14.09-5 NVIDIA binary Xorg driver ii nvidia-kernel-2.6.26-2-amd64 173.14.09-5+2.6.26-19lenny2 NVIDIA binary kernel module for Linux 2.6.26 ii nvidia-kernel-common 20080825+1 NVIDIA binary kernel module common files ii nvidia-kernel-source 173.14.09-5 NVIDIA binary kernel module source ii nvidia-settings 173.14.09-1 Tool of configuring the NVIDIA graphics driv ii nvidia-xconfig 1.0+20080522-2 The NVIDIA X Configuration Tool
par contre
un modprobe nvidia
me renvoi que dalle!!
mon xorg nvidia
[code]# nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 1.0 (randy@juliet2) Fri Sep 5 15:03:39 PDT 2008
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice “Keyboard0” "CoreKeyboard"
InputDevice “Mouse0” "CorePointer"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section “InputDevice”
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option “Protocol” "auto"
Option “Device” "/dev/psaux"
Option “Emulate3Buttons” "no"
Option “ZAxisMapping” "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 30.0 - 110.0
VertRefresh 50.0 - 150.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
aurais je oublier quelque chose ?
merci de vos avis
a+
ps: bon je tourne avec un xorg simple
Après plusieurs mois ( heu non j’exagère) de guerre acharnée pour installer ces $ù:^ de drivers, bhen j’ai réussi ( je ne sais pas trop comment d’ailleurs :confused: ). Et mon fichier .conf est le même que le tiens; à un détail près:[quote=“jeanbi”]
Driver "kbd"
EndSection[/quote]
Cette section chez moi est la suivante:
[quote]Section “InputDevice”
Driver "keyboard"
EndSection[/quote]
Je ne sais pas si ça a un rapport :question: :question: :question:
Jeanbi quel plantage as-tu ? Message ?
bonjour,
il me semblait avoir ete clair il semble que le module nvidia ne soit pas installe vu que modprobe ne renvoi rien
a+
lsmod te dit qu’il a un module nvidia de chargé, et tu t’étonne qu’un modprobe nvidia ne te retourne rien ??? Tu veux quoi ? Désolé mon p’tit gars mais j’ai déjà fait ce que tu me demandes !
D’où ma question, pourquoi dis-tu que ça ne fonctionne pas ? Quel message as-tu lors de ton plantage ?
Question subsidiaire ; As-tu bien pensé à installer nvidia-glx APRÈS avoir recompiler ton module ?
Tout petit hors sujet à la gloire de Debianhadic:
Je reviens sous Debian, j’installe la Sid 64 sur mon Amd quad 9550, geforce 8200,je reviens au tuto de Debianhadic fait il y a presque deux ans, je le suis à la lettre et …mince alors…tout est nickel pile poil.
Je vais te fournir les coordonnées de mon compte Paypal en MP :wink:
Le tuto a été commencé il y a deux ans, mais il est régulièrement modifié pour suivre l’évolution des composants.
Je vais d’ailleurs ajouter cette référence : beronono.com/wiki-debian/index.p … _privateur la partie développé en Annexe2 par Fran.b est instructive.
Effectivement la partie notée par Fran.b est instructive surtout pour les gens pressés et aimant le risque, mais cela peut être un fort intéressant dépannage pour ceux qui ont besoin d’un .run installé proprement.
Par contre dans ton wiki ne serait-il pas souhaitable que tu indiques, pour les débutants surtout, que le fameux fichier /etc/X11/xorg.conf est désormais un fichier vide et qu’il faut y coller pour reprendre ton exemple:
Section "Device"
Identifier "NVIDIA Corporation NV41.8 [GeForce Go 6800]"
Driver "nvidia"
EndSection
En fait je dis : (Si vous ne trouvez pas cette section, alors ajoutez la !)
Avec nano il va créer le fichier, est-ce que tu peux confirmer que la seule mention de cette section dans un fichier xorg.conf vide suffit ?
Peut être que sous Lenny on a encore une vielle version de Xorg: je n’avais pas pensé à cela en écrivant mon post précédent. :unamused:
Désolé si c’est le cas mais j’ai installé une iso Testing que j’ai immédiatement passé en Sid.
J’ai sauté le texte entre parenthèses :smt003
Méa culpa :neutral_face:
Je tente de migrer d’Ubuntu vers Debian mais je bloque sur l’installation du pilote NVidia (configuration de mon PC en signature).
J’ai fait mon installation depuis le CD1 de Squeeze (noyau 2.6.30-2-686) puis mises à jour (noyau 2.6.32-trunk-686). Je n’ai pas accès à des résolutions supérieures à 800x600 (alors que mon écran est en 1920x1080, 22"). Je n’ai pas de fichier /etc/X11/xorg.conf (normal, d’après ce que j’ai compris du nouveau Xorg) et pas de module nvidia ou nv chargé.
[code]# lsmod | grep nv
Par contre, si je regarde dans le Xorg.0.log (avec la commande trouvée sur le Wiki), j’ai ceci :
[code]# grep -B2 ‘Module class: X.Org Video Driver’ /var/log/Xorg.0.log
(II) Module nv: vendor="X.Org Foundation"
compiled for 1.7.3.902, module version = 2.1.15
(II) Module vesa: vendor="X.Org Foundation"
compiled for 1.7.4, module version = 2.3.0
J’en déduit que le module “nv” est chargé… mais je ne sais pas comment ni quel module est utilisé “nv” ou “vesa”. Dans le doute, j’avais désinstallé le paquet “xserver-xorg-video-vesa” mais cela ne changeait rien.
J’ai ensuite suivi ce tutoriel, d’abord avec un sources.list simple (uniquement Squeeze) puis avec le sources.list et /etc/apt/preferences (prioritairement Squeeze) conseillés ici : Sources.list au carré ou minimaliste (viewtopic.php?f=8&t=5659). Mais à chaque fois cela bloque au moment de la commande “m-a a-i -i nvidia-kernel-source”, même en utilisant le noyau “2.6.32-1-686”. Voici les erreurs obtenues :
[code]/usr/bin/make -C . LINUXDIR=/lib/modules/2.6.32-1-686/build KVERREL=2.6.32-1-686 clean
make[1]: entrant dans le répertoire « /usr/src/modules/nvidia-kernel »
rm -rf .o .ko .depend ..flags ..d .*.cmd .mod.c .tmp_versions
make[1]: quittant le répertoire « /usr/src/modules/nvidia-kernel »
dh_clean
/usr/bin/make -f debian/rules kdist_clean kdist_config binary-modules
make[2]: entrant dans le répertoire « /usr/src/modules/nvidia-kernel »
.cmd *.mod.c .tmp_versions
make[2]: quittant le répertoire « /usr/src/modules/nvidia-kernel »
dh_clean
/usr/bin/make -w -f debian/rules configure
sed ‘s/#KVERS#/2.6.32-1-686/g’ debian/control.template > /usr/src/modules/nvidia-kernel/debian/control
sed ‘s/#KVERS#/2.6.32-1-686/g’ debian/dirs.template > /usr/src/modules/nvidia-kernel/debian/dirs
sed ‘s/#KVERS#/2.6.32-1-686/g’ debian/override.template > /usr/src/modules/nvidia-kernel/debian/override
dh_testroot
dh_prep
Build the modules
make -C /lib/modules/2.6.32-1-686/build M=/bin/pwd modules
make[3]: entrant dans le répertoire « /usr/src/linux-headers-2.6.32-1-686 »
/usr/src/linux-headers-2.6.32-1-common/Makefile:274: /usr/src/linux-headers-2.6.32-1-common/scripts/Kbuild.include: Aucun fichier ou dossier de ce type
/bin/bash: /usr/src/linux-headers-2.6.32-1-common/scripts/gcc-x86_32-has-stack-protector.sh: Aucun fichier ou dossier de ce type
/usr/src/linux-headers-2.6.32-1-common/arch/x86/Makefile:81: stack protector enabled but no compiler support
make: *** nom de variable vide. Arrêt.
make[5]: *** [module/usr/src/modules/nvidia-kernel] Erreur 2
make[4]: *** [sub-make] Erreur 2
make[3]: *** [all] Erreur 2
make[3]: quittant le répertoire « /usr/src/linux-headers-2.6.32-1-686 »
make[2]: *** [modules] Erreur 2
make[1]: *** [binary-modules] Erreur 2
make: *** [kdist_build] Erreur 2
Voici mon fichier “sources.list” :
[code]##
deb cdrom:[Debian GNU/Linux testing Squeeze - Official Snapshot i386 CD Binary-1 20100118-04:20]/ squeeze main
##deb cdrom:[Debian GNU/Linux testing Squeeze - Official Snapshot i386 CD Binary-1 20100118-04:20]/ squeeze main
#deb http://security.debian.org/ squeeze/updates main contrib non-free
#deb-src http://security.debian.org/ squeeze/updates main contrib non-free
#deb http://ftp.fr.debian.org/debian squeeze main contrib non-free
#deb-src http://ftp.fr.debian.org/debian squeeze main contrib non-free
lenny
deb http://ftp.fr.debian.org/debian/ lenny main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ lenny main contrib non-free
lenny multimedia
deb http://mirror.home-dn.net/debian-multimedia lenny main
deb-src http://mirror.home-dn.net/debian-multimedia lenny main
lenny security
deb http://security.debian.org/ lenny/updates main contrib non-free
deb-src http://security.debian.org/ lenny/updates main contrib non-free
volatile
deb http://volatile.debian.org/debian-volatile lenny/volatile main contrib non-free
deb-src http://volatile.debian.org/debian-volatile lenny/volatile main contrib non-free
squeeze
deb http://ftp.fr.debian.org/debian/ squeeze main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ squeeze main contrib non-free
squeeze multimedia
deb http://mirror.home-dn.net/debian-multimedia squeeze main
deb-src http://mirror.home-dn.net/debian-multimedia squeeze main
squeeze security
sid
deb http://ftp.fr.debian.org/debian/ sid main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ sid main contrib non-free
sid multimedia
deb http://mirror.home-dn.net/debian-multimedia sid main
deb-src http://mirror.home-dn.net/debian-multimedia sid main
experimental
deb http://ftp.fr.debian.org/debian/ experimental main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ experimental main contrib non-free
experimental multimedia (uniquement 64 bits, décommentez les lignes dans ce cas)
#deb http://mirror.home-dn.net/debian-multimedia experimental main
#deb-src http://mirror.home-dn.net/debian-multimedia experimental main
et mon fichier /etc/apt/preferences :
[code]Package: *
Pin: release o=apt-build
Pin-Priority: 989
Package: *
Pin: release o=Debian,a=testing,l=Debian-Security
Pin-Priority: 988
Package: *
Pin: release o=Unofficial Multimedia Packages,a=testing,l=Unofficial Multimedia Packages
Pin-Priority: 987
Package: *
Pin-Priority: 986
Package: *
Pin: release o=volatile.debian.org,a=stable,l=debian-volatile
Pin-Priority: 985
Package: *
Pin: release o=Debian,a=stable,l=Debian-Security
Pin-Priority: 984
Package: *
Pin: release o=Unofficial Multimedia Packages,a=stable,l=Unofficial Multimedia Packages
Pin-Priority: 983
Package: *
Pin-Priority: 982
Package: *
Pin: release o=Unofficial Multimedia Packages,a=unstable,l=Unofficial Multimedia Packages
Pin-Priority: 99
Package: *
Pin: release o=Debian,a=unstable,l=Debian
Pin-Priority: 98
Package: *
Pin: release o=Unofficial Multimedia Packages,a=experimental,l=Unofficial Multimedia Packages
Pin-Priority: 97
Package: *
Pin: release o=Debian,a=experimental,l=Debian
Pin-Priority: 96
J’ai également essayé, sans succès, les manipulations décrites en Annexe 1.
Mes compétences en la matière étant très limitées, je suis complètement bloqué et ne sais plus quoi faire (et j’ai vraiment envie de passer à Debian). J’ai même essayé l’installateur NVidia (.run), sans succès, que j’utilisais sans problème sous Ubuntu. Ayant lu que c’était une mauvaise méthode, et après avoir recommencé plusieurs fois, j’ai réinstallé Debian pour avoir une base neuve.
Pourriez-vous m’aider ? D’avance merci.
Cordialement.
Hugues
Tout d’abord, il faut que tu saches que l’absence de xorg.conf est normal, puisque c’est Xorg qui cherche le meilleur pilote pour ta carte, forcément, il a choisit “nv” pour toi, donc de désinstaller vesa ne servait à rien :wink:
Ensuite, quel version de Debian as-tu finalement ? Est-ce que les commandes de la première partie ont été faites, et ne génère plus d’erreurs ?
Merci pour la rapidité de ta réponse, Debianhadic.
D’accord pour le choix effectué par Xorg. Mais est-ce qu’il y a un moyen de savoir quel pilote il a choisi et utilise actuellement (juste pour être certain) ?
Par certitude, je viens de refaire :
[code]# apt-get update
apt-get upgrade
apt-get dist-upgrade[/code]
La dernière commande m’installe 2 paquets, mais pas d’erreur :
# apt-get dist-upgrade Lecture des listes de paquets... Fait Construction de l'arbre des dépendances Lecture des informations d'état... Fait Calcul de la mise à jour... Fait Les NOUVEAUX paquets suivants seront installés : [b]diff mktemp[/b] 0 mis à jour, 2 nouvellement installés, 0 à enlever et 0 non mis à jour. Il est nécessaire de prendre 19,7ko dans les archives. Après cette opération, 53,2ko d'espace disque supplémentaires seront utilisés. Souhaitez-vous continuer [O/n] ? o Réception de : 1 http://ftp.fr.debian.org squeeze/main diff 1:2.8.1-18 [5 842B] Réception de : 2 http://ftp.fr.debian.org squeeze/main mktemp 7.4-2 [13,9kB] 19,7ko réceptionnés en 0s (33,8ko/s) Sélection du paquet diff précédemment désélectionné. (Lecture de la base de données... 98928 fichiers et répertoires déjà installés.) Dépaquetage de diff (à partir de .../diff_1%3a2.8.1-18_all.deb) ... Paramétrage de diff (1:2.8.1-18) ... Sélection du paquet mktemp précédemment désélectionné. (Lecture de la base de données... 98931 fichiers et répertoires déjà installés.) Dépaquetage de mktemp (à partir de .../archives/mktemp_7.4-2_all.deb) ... Paramétrage de mktemp (7.4-2) ...
Ensuite :
# [b]apt-cache policy nvidia-kernel-source[/b] nvidia-kernel-source: Installé : 190.53-1 Candidat : 190.53-1 Table de version : *** 190.53-1 0 98 http://ftp.fr.debian.org sid/non-free Packages 100 /var/lib/dpkg/status 173.14.09-5 0 982 http://ftp.fr.debian.org lenny/non-free Packages 986 http://ftp.fr.debian.org squeeze/non-free Packages
Ensuite :
[code]# m-a prepare
Récupération des sources du noyau de la version : 2.6.32-1-686
En-têtes du noyau disponibles dans /lib/modules/2.6.32-1-686/build
apt-get install build-essential
build-essential est déjà la plus récente version disponible.
Fait.
Puis :
[code]# m-a clean nvidia-kernel
Et enfin :
[code]# m-a a-i -i nvidia-kernel-source
sh: getcwd() failed: No such file or directory
Données de 1 paquets mises à jour
apt-get -y install build-essential
Fait.
unpack
Extracting the package tarball, /usr/src/nvidia-kernel.tar.bz2, please wait…
"/usr/share/modass/packages/nvidia-kernel-source" build KVERS=2.6.32-1-686 KSRC=/lib/modules/2.6.32-1-686/build KDREV=2.6.32-6 kdist_image
rm -rf .o .ko .depend ..flags ..d .*.cmd *.mod.c .tmp_versions
dh_clean
dh_clean: cannot read debian/control: Aucun fichier ou dossier de ce type
make: [kdist_clean] Erreur 2 (ignorée)
dh_clean
make[1]: [kdist_clean] Erreur 2 (ignorée)
dh_testroot
dh_prep
Build the modules
BUILD FAILED!
See /var/cache/modass/nvidia-kernel-source.buildlog.2.6.32-1-686.1265118643 for details.
sh: getcwd() failed: No such file or directory[/code]
Voilà voilà. Cordialement.
Hugues
J’oubliais :
# lsb_release -a sh: getcwd() failed: No such file or directory sh: getcwd() failed: No such file or directory No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux testing (squeeze) Release: testing Codename: squeeze
Je pense que je suis toujours en squeeze, les seuls paquets (Sid, je crois) installés en plus sont linux-image et linux-headers en 2.6.32-1-686.
Tu as sans arrêt ce message :
Je ne sais pas trop pourquoi tu as ça mais avant de refaire m-a change de répertoire, retourne dans ~ par exemple.
D’accord ! En le faisant, je n’ai plus ces erreurs “getcwd()” mais toujours pas de compilation correcte.
[code]/usr/src/modules/nvidia-kernel/debian# cd ~
~# m-a a-i -i nvidia-kernel-source
Fait.
unpack
dh_clean
dh_clean
dh_testroot
dh_prep
Build the modules
BUILD FAILED!
See /var/cache/modass/nvidia-kernel-source.buildlog.2.6.32-1-686.1265119791 for details.
Et le fichier indiqué à la fin “/var/cache/modass/nvidia-kernel-source.buildlog.2.6.32-1-686.1265119791” :
dh_clean
dh_clean
dh_testroot
dh_prep
Build the modules
make: *** [kdist_build] Erreur 2[/code]
Je n’y connais rien mais est-ce normal qu’il aille ici : /usr/src/linux-headers-2.6.32-1-common/ ?
Ouai c’est normal … Tu peux refaire un m-a prepare avant, au cas ou …
Cela ne change rien… C’est un peu du chinois pour moi mais on dirait que sa première erreur est ici :
make[3]: entrant dans le répertoire « /usr/src/linux-headers-2.6.32-1-686 » /usr/src/linux-headers-2.6.32-1-common/Makefile:274: /usr/src/linux-headers-2.6.32-1-common/scripts/Kbuild.include: Aucun fichier ou dossier de ce type
J’ai le paquet “linux-kbuild-2.6.32” installé mais pas le “kbuild”. Est-ce problématique ?
C’est justement censé être la même chose ! tu peux essayer avec un autre noyau ? (tu recommences le tuto)
