hotkeys est bien installé.
[code]# aptitude show hotkeys
Paquet : hotkeys
Nouveau: oui
État: installé
Automatiquement installé: non
Version : 0.5.7.4
Priorité : optionnel
Section : x11
Responsable : Alexander Wirt formorer@debian.org
Taille décompressée : 344k
Dépend: libatk1.0-0 (>= 1.9.0), libc6 (>= 2.3.5-1), libcairo2 (>= 1.0.2-2),
libdb3 (>= 3.2.9-23), libfontconfig1 (>= 2.3.0), libglib2.0-0 (>=
2.8.5), libgtk2.0-0 (>= 2.8.0), libpango1.0-0 (>= 1.10.2), libx11-6,
libxcursor1 (> 1.1.2), libxext6, libxi6, libxinerama1, libxml2 (>=
2.2.8), libxmu6, libxosd2 (>= 2.2.13), libxrandr2, libxrender1 (>=
1:0.9.0.2), zlib1g (>= 1:1.2.1)
Est en conflit: xmms (< 1.2.6-1)
Description : A hotkeys daemon for your Internet/multimedia keyboard in X
This program sits at the back and listens for the “special” hotkeys that you
won’t normally use on your Internet/Multimedia keyboards. The buttons perform
their intended behaviors, such as volume up and down, mute the speaker, launch
applications, etc. It has On-screen display (OSD) to show the volume, program
that’s being started, etc.
It features an XML-based keycode configuration file format, which makes it
possible to define the hotkeys to launch any programs you want.
Marqueurs: hardware::input:keyboard, interface::daemon, uitoolkit::gtk,
x11::application
