Pas d'accélération graphique carte intel
Bonjour !
Je n’ai pas l’accélération graphique sous ma debian, j’espère que vous allez m’aider…
Un p’ti coup de lspci :
00:00.0 Host bridge: Intel Corporation Mobile PM965/GM965/GL960 Memory Controller Hub (rev 03) 00:02.0 VGA compatible controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (rev 03) 00:02.1 Display controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (rev 03) 00:1a.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Contoller #4 (rev 03) 00:1a.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 03) 00:1a.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 03) 00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03) 00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 03) 00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 03) 00:1d.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 03) 00:1d.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 03) 00:1d.2 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 03) 00:1d.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 03) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f3) 00:1f.0 ISA bridge: Intel Corporation 82801HEM (ICH8M) LPC Interface Controller (rev 03) 00:1f.1 IDE interface: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 03) 00:1f.2 SATA controller: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) SATA AHCI Controller (rev 03) 01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E PCI Express Fast Ethernet controller (rev 01) 02:00.0 Ethernet controller: Atheros Communications, Inc. AR242x 802.11abg Wireless PCI Express Adapter (rev 01)
Voila mon xorg :
[code]# xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option “SendCoreEvents” "true"
Option “Device” "/dev/psaux"
Option “Protocol” "auto-dev"
Option “HorizScrollDelta” "0"
EndSection
Section "Device"
Identifier "Carte vidéo générique"
Driver "intel"
BusID "PCI:0:2:0"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
HorizSync 28-33
VertRefresh 43-72
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Carte vidéo générique"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Modes "1280x800"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Synaptics Touchpad"
EndSection
Et pourtant :
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
Je pense avoir tout installé, mais bon…
As-tu bien installé le paquet libgl1-mesa-dri ?
Que dit le fichier /var/log/Xorg.0.log ? Des erreurs ?
Salut!
Oui le paquet en question est bien installé.
Je ne pense pas avoir vu d’erreur dans mon log, mais le voici quand même :
[code]cat /var/log/Xorg.0.log
X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Linux Debian (xorg-server 2:1.3.0.0.dfsg-12)
Current Operating System: Linux ThePhysicien 2.6.22-3-686 #1 SMP Mon Nov 12 08:32:57 UTC 2007 i686
Build Date: 09 August 2007
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Mon Apr 14 11:06:42 2008
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
) |–>Screen “Default Screen” (0)
() | |–>Monitor “Écran générique”
) | |–>Device “Carte vidéo générique”
() |–>Input Device “Generic Keyboard”
) |–>Input Device “Configured Mouse”
(**) |–>Input Device “Synaptics Touchpad”
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to “/etc/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81e5140
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.2
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.2
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,2a00 card 1631,c10a rev 03 class 06,00,00 hdr 00
(II) PCI: 00:02:0: chip 8086,2a02 card 1631,c10a rev 03 class 03,00,00 hdr 80
(II) PCI: 00:02:1: chip 8086,2a03 card 1631,c10a rev 03 class 03,80,00 hdr 80
(II) PCI: 00:1a:0: chip 8086,2834 card 1631,c10a rev 03 class 0c,03,00 hdr 80
(II) PCI: 00:1a:1: chip 8086,2835 card 1631,c10a rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1a:7: chip 8086,283a card 1631,c10a rev 03 class 0c,03,20 hdr 00
(II) PCI: 00:1b:0: chip 8086,284b card 1631,c10a rev 03 class 04,03,00 hdr 00
(II) PCI: 00:1c:0: chip 8086,283f card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1c:1: chip 8086,2841 card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1d:0: chip 8086,2830 card 1631,c10a rev 03 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,2831 card 1631,c10a rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,2832 card 1631,c10a rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,2836 card 1631,c10a rev 03 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,2448 card 0000,0000 rev f3 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,2815 card 1631,c10a rev 03 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,2850 card 1631,c10a rev 03 class 01,01,8a hdr 00
(II) PCI: 00:1f:2: chip 8086,2829 card 1631,c10a rev 03 class 01,06,01 hdr 00
(II) PCI: 01:00:0: chip 10ec,8136 card 10ec,8136 rev 01 class 02,00,00 hdr 00
(II) PCI: 02:00:0: chip 168c,001c card 1a3b,1026 rev 01 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,3), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:28:0), (0,1,1), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 1 I/O range:
[0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xfe500000 - 0xfe5fffff (0x100000) MX[B]
(II) Bus 2: bridge is at (0:28:1), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xfe600000 - 0xfe6fffff (0x100000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 3: bridge is at (0:30:0), (0,3,3), BCTRL: 0x0002 (VGA_EN is cleared)
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(0:2:0) Intel Corporation Mobile Integrated Graphics Controller rev 3, Mem @ 0xfeb00000/20, 0xe0000000/28, I/O @ 0xec00/3
(–) PCI: (0:2:1) Intel Corporation Mobile Integrated Graphics Controller rev 3, Mem @ 0xfe900000/20
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xfe6f0000 - 0xfe6fffff (0x10000) MX[B]
[1] -1 0 0xfe5ff000 - 0xfe5fffff (0x1000) MX[B]
[2] -1 0 0xfeaff800 - 0xfeafffff (0x800) MX[B]
[3] -1 0 0xfeaff000 - 0xfeaff3ff (0x400) MX[B]
[4] -1 0 0xfeaf8000 - 0xfeafbfff (0x4000) MX[B]
[5] -1 0 0xfeaff400 - 0xfeaff7ff (0x400) MX[B]
[6] -1 0 0xfe900000 - 0xfe9fffff (0x100000) MXB
[7] -1 0 0xe0000000 - 0xefffffff (0x10000000) MXB
[8] -1 0 0xfeb00000 - 0xfebfffff (0x100000) MXB
[9] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[10] -1 0 0x0000e080 - 0x0000e09f (0x20) IX[B]
[11] -1 0 0x0000e400 - 0x0000e403 (0x4) IX[B]
[12] -1 0 0x0000e480 - 0x0000e487 (0x8) IX[B]
[13] -1 0 0x0000e800 - 0x0000e803 (0x4) IX[B]
[14] -1 0 0x0000e880 - 0x0000e887 (0x8) IX[B]
[15] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[16] -1 0 0x00000374 - 0x00000374 (0x1) IX[B]
[17] -1 0 0x00000170 - 0x00000177 (0x8) IX[B]
[18] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[19] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[20] -1 0 0x0000d480 - 0x0000d49f (0x20) IX[B]
[21] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[22] -1 0 0x0000d880 - 0x0000d89f (0x20) IX[B]
[23] -1 0 0x0000dc00 - 0x0000dc1f (0x20) IX[B]
[24] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
[25] -1 0 0x0000ec00 - 0x0000ec07 (0x8) IXB
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xfe6f0000 - 0xfe6fffff (0x10000) MX[B]
[5] -1 0 0xfe5ff000 - 0xfe5fffff (0x1000) MX[B]
[6] -1 0 0xfeaff800 - 0xfeafffff (0x800) MX[B]
[7] -1 0 0xfeaff000 - 0xfeaff3ff (0x400) MX[B]
[8] -1 0 0xfeaf8000 - 0xfeafbfff (0x4000) MX[B]
[9] -1 0 0xfeaff400 - 0xfeaff7ff (0x400) MX[B]
[10] -1 0 0xfe900000 - 0xfe9fffff (0x100000) MXB
[11] -1 0 0xe0000000 - 0xefffffff (0x10000000) MXB
[12] -1 0 0xfeb00000 - 0xfebfffff (0x100000) MXB
[13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[15] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[16] -1 0 0x0000e080 - 0x0000e09f (0x20) IX[B]
[17] -1 0 0x0000e400 - 0x0000e403 (0x4) IX[B]
[18] -1 0 0x0000e480 - 0x0000e487 (0x8) IX[B]
[19] -1 0 0x0000e800 - 0x0000e803 (0x4) IX[B]
[20] -1 0 0x0000e880 - 0x0000e887 (0x8) IX[B]
[21] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[22] -1 0 0x00000374 - 0x00000374 (0x1) IX[B]
[23] -1 0 0x00000170 - 0x00000177 (0x8) IX[B]
[24] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[25] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[26] -1 0 0x0000d480 - 0x0000d49f (0x20) IX[B]
[27] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[28] -1 0 0x0000d880 - 0x0000d89f (0x20) IX[B]
[29] -1 0 0x0000dc00 - 0x0000dc1f (0x20) IX[B]
[30] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
[31] -1 0 0x0000ec00 - 0x0000ec07 (0x8) IXB
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 1.3.0, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “intel”
(II) Loading /usr/lib/xorg/modules/drivers//intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
Module class: X.Org Video Driver
(II) LoadModule: “kbd”
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.2.1
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.7
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.2.2
(II) LoadModule: “synaptics”
(II) Loading /usr/lib/xorg/modules/input//synaptics_drv.so
(II) Module synaptics: vendor="X.Org Foundation"
compiled for 4.3.99.902, module version = 1.0.0
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, 965G, 965G, 965Q, 946GZ,
965GM, 965GME/GLE, G33, Q35, Q33
(II) Primary Device is: PCI 00:02:0
(WW) intel: No matching Device section for instance (BusID PCI:0:2:1) found
(–) Chipset 965GM found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[13] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[14] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[15] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[18] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[19] -1 0 0x0000e080 - 0x0000e09f (0x20) IX[B]
[20] -1 0 0x0000e400 - 0x0000e403 (0x4) IX[B]
[21] -1 0 0x0000e480 - 0x0000e487 (0x8) IX[B]
[22] -1 0 0x0000e800 - 0x0000e803 (0x4) IX[B]
[23] -1 0 0x0000e880 - 0x0000e887 (0x8) IX[B]
[24] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[25] -1 0 0x00000374 - 0x00000374 (0x1) IX[B]
[26] -1 0 0x00000170 - 0x00000177 (0x8) IX[B]
[27] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[28] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[29] -1 0 0x0000d480 - 0x0000d49f (0x20) IX[B]
[30] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[31] -1 0 0x0000d880 - 0x0000d89f (0x20) IX[B]
[32] -1 0 0x0000dc00 - 0x0000dc1f (0x20) IX[B]
[33] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
[34] -1 0 0x0000ec00 - 0x0000ec07 (0x8) IXB
[35] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[36] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module “int10”
(II) LoadModule: “int10”
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) Loading sub module “vbe”
(II) LoadModule: “vbe”
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.1.0
(II) Loading sub module “vgahw”
(II) LoadModule: “vgahw”
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 0.1.0
() intel(0): Depth 24, (–) framebuffer bpp 32
(==) intel(0): RGB weight 888
(==) intel(0): Default visual is TrueColor
(II) intel(0): Integrated Graphics Chipset: Intel® 965GM
(–) intel(0): Chipset: “965GM”
(–) intel(0): Linear framebuffer at 0xE0000000
(–) intel(0): IO registers at addr 0xFEB00000
(II) intel(0): 2 display pipes available.
(==) intel(0): Using XAA for acceleration
(–) intel(0): Will try to allocate texture pool for old Mesa 3D driver.
(II) intel(0): Will try to reserve 32768 kiB of AGP aperture space
for the DRM memory manager.
(II) Loading sub module “ddc”
(II) LoadModule: “ddc”(II) Module already built-in
(II) Loading sub module “i2c”
(II) LoadModule: “i2c”(II) Module already built-in
(II) intel(0): Output VGA using monitor section Écran générique
(II) intel(0): I2C bus “CRTDDC_A” initialized.
(II) intel(0): Output LVDS has no monitor section
(II) intel(0): I2C bus “LVDSDDC_C” initialized.
(II) intel(0): I2C device “LVDSDDC_C:ddc2” registered at address 0xA0.
(II) intel(0): I2C device “LVDSDDC_C:ddc2” removed.
(II) intel(0): EDID for output LVDS
(II) intel(0): Manufacturer: LPL Model: b600 Serial#: 0
(II) intel(0): Year: 2006 Week: 0
(II) intel(0): EDID Version: 1.2
(II) intel(0): Digital Display Input
(II) intel(0): Max H-Image Size [cm]: horiz.: 26 vert.: 16
(II) intel(0): Gamma: 2.20
(II) intel(0): No DPMS capabilities specified; RGB/Color Display
(II) intel(0): First detailed timing is preferred mode
(II) intel(0): redX: 0.592 redY: 0.344 greenX: 0.331 greenY: 0.543
(II) intel(0): blueX: 0.158 blueY: 0.146 whiteX: 0.312 whiteY: 0.328
(II) intel(0): Manufacturer’s mask: 0
(II) intel(0): Supported additional Video Mode:
(II) intel(0): clock: 71.0 MHz Image Size: 261 x 163 mm
(II) intel(0): h_active: 1280 h_sync: 1328 h_sync_end 1376 h_blank_end 1440 h_border: 0
(II) intel(0): v_active: 800 v_sync: 802 v_sync_end 808 v_blanking: 823 v_border: 0
(II) intel(0): LGPhilipsLCD
(II) intel(0): LP121WX1-TLA2
(II) intel(0): EDID (in hex):
(II) intel(0): 00ffffffffffff00320c00b600000000
(II) intel(0): 00100102801a10780a8ca09758548b28
(II) intel(0): 25505400000001010101010101010101
(II) intel(0): 010101010101bc1b00a0502017303030
(II) intel(0): 260005a3100000190000000000000000
(II) intel(0): 00000000000000000000000000fe004c
(II) intel(0): 475068696c6970734c43440a000000fe
(II) intel(0): 004c503132315758312d544c413200be
(II) intel(0): EDID vendor “LPL”, prod id 46592
(II) Reloading /usr/lib/xorg/modules//libint10.so
(II) intel(0): initializing int10
(WW) intel(0): Bad V_BIOS checksum
(II) intel(0): Primary V_BIOS segment is: 0xc000
(II) intel(0): VESA BIOS detected
(II) intel(0): VESA VBE Version 3.0
(II) intel(0): VESA VBE Total Mem: 7616 kB
(II) intel(0): VESA VBE OEM: Intel®Crestline Graphics Chip Accelerated VGA BIOS
(II) intel(0): VESA VBE OEM Software Rev: 1.0
(II) intel(0): VESA VBE OEM Vendor: Intel Corporation
(II) intel(0): VESA VBE OEM Product: Intel®Crestline Graphics Controller
(II) intel(0): VESA VBE OEM Product Rev: Hardware Version 0.0
(II) intel(0): I2C bus “SDVOCTRL_E for SDVOB” initialized.
(II) intel(0): I2C device “SDVOCTRL_E for SDVOB:SDVO Controller B” registered at address 0x70.
(II) intel(0): No SDVO device found on SDVOB
(II) intel(0): I2C device “SDVOCTRL_E for SDVOB:SDVO Controller B” removed.
(II) intel(0): I2C bus “SDVOCTRL_E for SDVOB” removed.
(II) intel(0): I2C bus “SDVOCTRL_E for SDVOC” initialized.
(II) intel(0): I2C device “SDVOCTRL_E for SDVOC:SDVO Controller C” registered at address 0x72.
(II) intel(0): No SDVO device found on SDVOC
(II) intel(0): I2C device “SDVOCTRL_E for SDVOC:SDVO Controller C” removed.
(II) intel(0): I2C bus “SDVOCTRL_E for SDVOC” removed.
(II) intel(0): Output TV has no monitor section
(II) intel(0): Output VGA disconnected
(II) intel(0): EDID for output VGA
(II) intel(0): Output LVDS connected
(II) intel(0): Not using default mode “640x350” (vrefresh out of range)
(II) intel(0): Not using default mode “640x400” (vrefresh out of range)
(II) intel(0): Not using default mode “720x400” (vrefresh out of range)
(II) intel(0): Not using default mode “640x480” (vrefresh out of range)
(II) intel(0): Not using default mode “800x600” (vrefresh out of range)
(II) intel(0): Not using default mode “1024x768” (vrefresh out of range)
(II) intel(0): Not using default mode “1152x864” (vrefresh out of range)
(II) intel(0): Not using default mode “1280x960” (hsync out of range)
(II) intel(0): Not using default mode “1280x960” (vrefresh out of range)
(II) intel(0): Not using default mode “1280x1024” (hsync out of range)
(II) intel(0): Not using default mode “1280x1024” (vrefresh out of range)
(II) intel(0): Not using default mode “1600x1200” (hsync out of range)
(II) intel(0): Not using default mode “1600x1200” (vrefresh out of range)
(II) intel(0): Not using default mode “1792x1344” (hsync out of range)
(II) intel(0): Not using default mode “1792x1344” (vrefresh out of range)
(II) intel(0): Not using default mode “1856x1392” (hsync out of range)
(II) intel(0): Not using default mode “1856x1392” (vrefresh out of range)
(II) intel(0): Not using default mode “1920x1440” (hsync out of range)
(II) intel(0): Not using default mode “1920x1440” (vrefresh out of range)
(II) intel(0): Not using default mode “832x624” (vrefresh out of range)
(II) intel(0): Not using default mode “1152x768” (vrefresh out of range)
(II) intel(0): Not using default mode “1400x1050” (hsync out of range)
(II) intel(0): Not using default mode “1400x1050” (vrefresh out of range)
(II) intel(0): Not using default mode “1440x900” (hsync out of range)
(II) intel(0): Not using default mode “1600x1024” (hsync out of range)
(II) intel(0): Not using default mode “1680x1050” (hsync out of range)
(II) intel(0): Not using default mode “1920x1200” (hsync out of range)
(II) intel(0): Not using default mode “1920x1200” (vrefresh out of range)
(II) intel(0): Not using default mode “2048x1536” (hsync out of range)
(II) intel(0): Not using default mode “2048x1536” (vrefresh out of range)
(II) intel(0): Printing probed modes for output LVDS
(II) intel(0): Modeline "1280x800"x59.9 71.00 1280 1328 1376 1440 800 802 808 823 -hsync -vsync (49.3 kHz)
(II) intel(0): Modeline "1280x800"x60.0 83.46 1280 1344 1480 1680 800 801 804 828 (49.7 kHz)
(II) intel(0): Modeline "1280x768"x60.0 80.14 1280 1344 1480 1680 768 769 772 795 (47.7 kHz)
(II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) intel(0): Output TV connected
(II) intel(0): Not using default mode “640x480” (bad mode clock/interlace/doublescan)
(II) intel(0): Not using default mode “800x600” (bad mode clock/interlace/doublescan)
(II) intel(0): Not using default mode “1024x768” (bad mode clock/interlace/doublescan)
(II) intel(0): Not using default mode “1280x768” (bad mode clock/interlace/doublescan)
(II) intel(0): Not using default mode “1280x800” (bad mode clock/interlace/doublescan)
(II) intel(0): Printing probed modes for output TV
(II) intel(0): Modeline "1024x768"x30.0 26.89 1024 1025 1088 1120 768 769 800 801 (24.0 kHz)
(II) intel(0): Modeline "800x600"x30.0 17.00 800 801 864 896 600 601 632 633 (19.0 kHz)
(II) intel(0): Modeline "848x480"x30.0 14.51 848 849 912 944 480 481 512 513 (15.4 kHz)
(II) intel(0): Modeline "640x480"x30.0 11.31 640 641 704 736 480 481 512 513 (15.4 kHz)
(II) intel(0): Output LVDS using initial mode 1280x800
(II) intel(0): Output TV using initial mode 1024x768
(II) intel(0): Monitoring connected displays enabled
(II) intel(0): detected 512 kB GTT.
(II) intel(0): detected 7676 kB stolen memory.
(==) intel(0): video overlay key set to 0x101fe
(==) intel(0): Will not try to enable page flipping
(==) intel(0): Triple buffering disabled
(==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
(==) intel(0): DPI set to (75, 75)
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module “xaa”
(II) LoadModule: “xaa”
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.2.0
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”(II) Module already built-in
(II) intel(0): Comparing regs from server start up to After PreInit
(WW) intel(0): Register 0x61114 (PORT_HOTPLUG_STAT) changed from 0x00000000 to 0x00000400
(==) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don’t.
(II) resource ranges after preInit:
[0] 0 0 0xe0000000 - 0xefffffff (0x10000000) MS[B]
[1] 0 0 0xfeb00000 - 0xfebfffff (0x100000) MS[B]
[2] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[3] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[4] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[5] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[6] -1 0 0xfe6f0000 - 0xfe6fffff (0x10000) MX[B]
[7] -1 0 0xfe5ff000 - 0xfe5fffff (0x1000) MX[B]
[8] -1 0 0xfeaff800 - 0xfeafffff (0x800) MX[B]
[9] -1 0 0xfeaff000 - 0xfeaff3ff (0x400) MX[B]
[10] -1 0 0xfeaf8000 - 0xfeafbfff (0x4000) MX[B]
[11] -1 0 0xfeaff400 - 0xfeaff7ff (0x400) MX[B]
[12] -1 0 0xfe900000 - 0xfe9fffff (0x100000) MXB
[13] -1 0 0xe0000000 - 0xefffffff (0x10000000) MXB
[14] -1 0 0xfeb00000 - 0xfebfffff (0x100000) MXB
[15] 0 0 0x000a0000 - 0x000affff (0x10000) MSB
[16] 0 0 0x000b0000 - 0x000b7fff (0x8000) MSB
[17] 0 0 0x000b8000 - 0x000bffff (0x8000) MSB
[18] 0 0 0x0000ec00 - 0x0000ec07 (0x8) IS[B]
[19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[21] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[22] -1 0 0x0000e080 - 0x0000e09f (0x20) IX[B]
[23] -1 0 0x0000e400 - 0x0000e403 (0x4) IX[B]
[24] -1 0 0x0000e480 - 0x0000e487 (0x8) IX[B]
[25] -1 0 0x0000e800 - 0x0000e803 (0x4) IX[B]
[26] -1 0 0x0000e880 - 0x0000e887 (0x8) IX[B]
[27] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[28] -1 0 0x00000374 - 0x00000374 (0x1) IX[B]
[29] -1 0 0x00000170 - 0x00000177 (0x8) IX[B]
[30] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[31] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[32] -1 0 0x0000d480 - 0x0000d49f (0x20) IX[B]
[33] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[34] -1 0 0x0000d880 - 0x0000d89f (0x20) IX[B]
[35] -1 0 0x0000dc00 - 0x0000dc1f (0x20) IX[B]
[36] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
[37] -1 0 0x0000ec00 - 0x0000ec07 (0x8) IXB
[38] 0 0 0x000003b0 - 0x000003bb (0xc) ISB
[39] 0 0 0x000003c0 - 0x000003df (0x20) ISB
(II) intel(0): Kernel reported 489216 total, 1 used
(II) intel(0): I830CheckAvailableMemory: 1956860 kB available
(==) intel(0): VideoRam: 262144 KB
(II) intel(0): Attempting memory allocation with tiled buffers and
large DRI memory manager reservation:
(II) intel(0): Allocating 5472 scanlines for pixmap cache
(II) intel(0): Success.
(II) intel(0): Memory allocation layout:
(II) intel(0): 0x00000000-0x0001ffff: ring buffer (128 kB)
(II) intel(0): 0x00020000-0x00029fff: HW cursors (40 kB)
(II) intel(0): 0x0002a000-0x00031fff: logical 3D context (32 kB)
(II) intel(0): 0x00032000-0x00041fff: exa G965 state buffer (64 kB)
(II) intel(0): 0x00050000-0x02147fff: front buffer (33760 kB)
(II) intel(0): 0x0077f000: end of stolen memory
(II) intel(0): 0x02148000-0x02157fff: xaa scratch (64 kB)
(II) intel(0): 0x02158000-0x02797fff: back buffer (6400 kB)
(II) intel(0): 0x02798000-0x02dd7fff: depth buffer (6400 kB)
(II) intel(0): 0x02dd8000-0x04dd7fff: textures (32768 kB)
(II) intel(0): 0x10000000: end of aperture
(II) intel(0): front buffer is not tiled
(II) intel(0): back buffer is tiled
(II) intel(0): depth buffer is tiled
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such device or address)
drmOpenDevice: Open failed
drmOpenByBusid: Searching for BusID pci:0000:00:02.0
drmOpenDevice: open result is 8, (OK)
drmOpenByBusid: drmOpenMinor returns 8
drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
(II) intel(0): [drm] loaded kernel module for “i915” driver
(II) intel(0): [drm] DRM interface version 1.3
(II) intel(0): [drm] created “i915” driver at busid “pci:0000:00:02.0”
(II) intel(0): [drm] added 8192 byte SAREA at 0xf8c4a000
(II) intel(0): [drm] mapped SAREA 0xf8c4a000 to 0xb7b49000
(II) intel(0): [drm] framebuffer handle = 0xe0050000
(II) intel(0): [drm] added 1 reserved context for kernel
(II) intel(0): [drm] Registers = 0xfeb00000
(II) intel(0): [drm] ring buffer = 0xe0000000
(II) intel(0): [drm] init sarea width,height = 1280 x 1280 (pitch 1280)
(II) intel(0): [drm] Back Buffer = 0xe2158000
(II) intel(0): [drm] Depth Buffer = 0xe2798000
(II) intel(0): [drm] textures = 0xe2dd8000
(II) intel(0): [drm] Initialized kernel agp heap manager, 33554432
(II) intel(0): [dri] visual configs initialized
(II) intel(0): Page Flipping disabled
(==) intel(0): Write-combining range (0xe0000000,0x10000000)
(II) intel(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
(II) intel(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Horizontal and Vertical Lines
Offscreen Pixmaps
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(==) intel(0): Backing store disabled
(==) intel(0): Silken mouse enabled
(II) intel(0): Initializing HW Cursor
(II) intel(0): xf86BindGARTMemory: bind key 0 at 0x0077f000 (pgoffset 1919)
(II) intel(0): xf86BindGARTMemory: bind key 1 at 0x02148000 (pgoffset 8520)
(II) intel(0): xf86BindGARTMemory: bind key 2 at 0x02158000 (pgoffset 8536)
(II) intel(0): xf86BindGARTMemory: bind key 3 at 0x02798000 (pgoffset 10136)
(II) intel(0): xf86BindGARTMemory: bind key 4 at 0x02dd8000 (pgoffset 11736)
(WW) intel(0): ESR is 0x00000010, page table error
(WW) intel(0): PGTBL_ER is 0x00000010, display A pte
(WW) intel(0): Existing errors found in hardware state.
(II) intel(0): Output configuration:
(II) intel(0): Pipe A is on
(II) intel(0): Display plane A is now enabled and connected to pipe A.
(II) intel(0): Pipe B is on
(II) intel(0): Display plane B is now enabled and connected to pipe B.
(II) intel(0): Output VGA is connected to pipe none
(II) intel(0): Output LVDS is connected to pipe B
(II) intel(0): Output TV is connected to pipe A
) Option “dpms”
() intel(0): DPMS enabled
(II) intel(0): Set up textured video
(II) intel(0): X context handle = 0x1
(II) intel(0): [drm] installed DRM signal handler
(II) intel(0): [DRI] installation complete
(II) intel(0): [drm] dma control initialized, using IRQ 16
(II) intel(0): direct rendering: Enabled
(II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(–) RandR disabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
drmOpenDevice: open result is 9, (OK)
drmOpenByBusid: drmOpenMinor returns 9
(WW) AIGLX: 3D driver claims to not support visual 0x23
(WW) AIGLX: 3D driver claims to not support visual 0x24
(WW) AIGLX: 3D driver claims to not support visual 0x25
(WW) AIGLX: 3D driver claims to not support visual 0x26
(WW) AIGLX: 3D driver claims to not support visual 0x27
(WW) AIGLX: 3D driver claims to not support visual 0x28
(WW) AIGLX: 3D driver claims to not support visual 0x29
(WW) AIGLX: 3D driver claims to not support visual 0x2a
(WW) AIGLX: 3D driver claims to not support visual 0x2b
(WW) AIGLX: 3D driver claims to not support visual 0x2c
(WW) AIGLX: 3D driver claims to not support visual 0x2d
(WW) AIGLX: 3D driver claims to not support visual 0x2e
(WW) AIGLX: 3D driver claims to not support visual 0x2f
(WW) AIGLX: 3D driver claims to not support visual 0x30
(WW) AIGLX: 3D driver claims to not support visual 0x31
(WW) AIGLX: 3D driver claims to not support visual 0x32
(II) AIGLX: Loaded and initialized /usr/lib/dri/i965_dri.so
(II) GLX: Initialized DRI GL provider for screen 0
(II) intel(0): Setting screen physical size to 261 x 163
) Option “CoreKeyboard”
() Generic Keyboard: Core Keyboard
) Option “Protocol” “standard”
() Generic Keyboard: Protocol: standard
) Option “AutoRepeat” “500 30”
() Option “XkbRules” “xorg”
) Generic Keyboard: XkbRules: “xorg”
() Option “XkbModel” “pc105”
) Generic Keyboard: XkbModel: “pc105”
() Option “XkbLayout” “fr”
) Generic Keyboard: XkbLayout: “fr”
() Option “XkbVariant” “latin9”
) Generic Keyboard: XkbVariant: “latin9”
() Option “CustomKeycodes” “off”
) Generic Keyboard: CustomKeycodes disabled
() Option “Protocol” “ImPS/2”
) Configured Mouse: Device: “/dev/input/mice”
() Configured Mouse: Protocol: “ImPS/2”
) Option “CorePointer”
() Configured Mouse: Core Pointer
) Option “Device” “/dev/input/mice”
() Option “Emulate3Buttons” “true”
) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
() Configured Mouse: ZAxisMapping: buttons 4 and 5
) Configured Mouse: Buttons: 9
() Configured Mouse: Sensitivity: 1
(II) Synaptics touchpad driver version 0.14.6 (1406)
(–) Synaptics Touchpad auto-dev sets device to /dev/input/event2
) Option “Device” “/dev/input/event2”
() Option “HorizScrollDelta” “0”
(–) Synaptics Touchpad touchpad found
) Option “SendCoreEvents” “true”
() Synaptics Touchpad: always reports core events
(II) XINPUT: Adding extended input device “Synaptics Touchpad” (type: MOUSE)
(II) XINPUT: Adding extended input device “Configured Mouse” (type: MOUSE)
(II) XINPUT: Adding extended input device “Generic Keyboard” (type: KEYBOARD)
Synaptics DeviceInit called
SynapticsCtrl called.
(II) Configured Mouse: ps2EnableDataReporting: succeeded
Synaptics DeviceOn called
AUDIT: Mon Apr 14 11:06:48 2008: 3479 X: client 2 rejected from local host (uid 0)
(->Cette ligne est répettée beaucoup de fois avec des heures différentes…)
Merci de ton aide!
ps: dsl pour la longueur…
À part code intel(0): ESR is 0x00000010, page table error
(WW) intel(0): Existing errors found in hardware state.[/code]
Mon Xorg.0.log est quasiment similaire au tien.
Que te dit LIBGL_DEBUG=verbose glxinfo ?
EDIT: sinon il y a aussi ce rapport de bogue :
bugs.debian.org/cgi-bin/bugreport.cgi?bug=464353
Peut-être es-tu concerné ?
load “dri” dans la section module du xorg.conf
glxinfo | grep rendering te donne quoi?
Bonsoir!
Je pense pouvoir avoir une piste :
Voila le résultat de : LIBGL_DEBUG=verbose glxinfo :
[code]name of display: :0.0
libGL: XF86DRIGetClientDriverName: 1.8.0 i965 (screen 0)
libGL: OpenDriver: trying /usr/lib/dri/i965_dri.so
libGL error: dlopen /usr/lib/dri/i965_dri.so failed (/usr/lib/dri/i965_dri.so: undefined symbol: _glapi_Dispatch)
libGL error: unable to load driver: i965_dri.so
display: :0 screen: 0
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_swap_control, GLX_MESA_swap_frame_usage, GLX_OML_swap_method,
GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX version: 1.2
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group,
OpenGL vendor string: Tungsten Graphics, Inc
OpenGL renderer string: Mesa DRI Intel® 965GM 4.1.3002 x86/MMX/SSE2
OpenGL version string: 1.4 Mesa 7.0.3-rc2
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_imaging,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_point_parameters,
GL_ARB_shadow, GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_program, GL_ARB_window_pos,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_clip_volume_hint, GL_EXT_copy_texture, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels,
GL_EXT_point_parameters, GL_EXT_polygon_offset, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shadow_funcs, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_vertex_array,
GL_3DFX_texture_compression_FXT1, GL_APPLE_packed_pixels,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_MESA_pack_invert, GL_MESA_ycbcr_texture, GL_NV_blend_square,
GL_NV_light_max_exponent, GL_NV_texgen_reflection,
GL_NV_texture_rectangle, GL_SGI_color_matrix, GL_SGI_color_table,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
GL_SUN_multi_draw_arrays
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x24 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x25 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x27 24 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x28 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2a 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2b 24 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x2c 24 dc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x2d 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x2e 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x2f 24 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x30 24 dc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x31 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x32 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
Erreur de segmentation
Les lignes libGL m’intriguent beaucoup…
En tout cas merci de votre aide!
Personne n’a fait remarquer que ça pouvait peut être aider de mettre dans le xorg.conf:Section "DRI" Mode 0666 EndSection ou éventuellementSection "Extensions" Option "RENDER" "Enable" EndSection
Il me semble que ça n’est plus nécessaire avec les dernières versions de Xorg. Mais ça ne peut pas faire de mal en effet.
Humm, que donne
$ ldd /usr/lib/dri/i965_dri.so libm.so.6 => /lib/libm.so.6 (0x00007fe05052b000) libpthread.so.0 => /lib/libpthread.so.0 (0x00007fe050415000) libexpat.so.1 => /usr/lib/libexpat.so.1 (0x00007fe0502f3000) libdl.so.2 => /lib/libdl.so.2 (0x00007fe0501f0000) libdrm.so.2 => /usr/lib/libdrm.so.2 (0x00007fe0500e5000) libc.so.6 => /lib/libc.so.6 (0x00007fe04fea8000) /lib64/ld-linux-x86-64.so.2 (0x00007fe050a1d000)
Voila ce que ça donne chez moi :
$ ldd /usr/lib/dri/i965_dri.so linux-gate.so.1 => (0xffffe000) libm.so.6 => /lib/i686/cmov/libm.so.6 (0xb7cb7000) libpthread.so.0 => /lib/i686/cmov/libpthread.so.0 (0xb7c9f000) libexpat.so.1 => /usr/lib/libexpat.so.1 (0xb7c7e000) libdl.so.2 => /lib/i686/cmov/libdl.so.2 (0xb7c7a000) libdrm.so.2 => /usr/lib/libdrm.so.2 (0xb7c71000) libc.so.6 => /lib/i686/cmov/libc.so.6 (0xb7b23000) /lib/ld-linux.so.2 (0x80000000)
J’ai essayé d’installer linux-gate, mais je n’ai pas trouvé le bon paquet…
J’ai essayé les trucs de mattotop mais sans résultats…
Merci à vous!
Et pour cause :
trilithium.com/johan/2005/08/linux-gate/
J’ai un poste où il y a ce chipset graphique, voilà quelques petits “détails” que j’ai dans le xorg.conf de la-dite machine que je ne vois pas dans le tiens (en plus de ce que t’a donné matt…)
[code]Section “Device”
Identifier “Carte vidéo générique”
Driver “intel”
BusID “PCI:0:2:0”
Option “monitor-TV” “TVOutput”
Option “DRI” “true”
Option “AccelMethod” “XAA”<<<
Option “XAANoOffscreenPixmaps” “true”<<<
EndSection
mais aussi:
[code]Section “ServerLayout”
Identifier “Default Layout”
InputDevice “Generic Keyboard”
InputDevice “Configured Mouse”
InputDevice “Synaptics Touchpad”
Option “AIGLX” “true”<<<
EndSection
[/code] c’est “en plus” de ce que t’as donné matt… à part:
[quote=“mattotop”]
Section "Extensions" Option "RENDER" "Enable" EndSection[/quote]ça j’ai pas vu … :blush: mais j’ai le souvenir que fut un temps où ça figurait dans le xorg.conf de cette machine… :blush:
autre “question” (bête, je sais): xserver-xorg-video-intel il est bien installé sur la machine ?
Bon courage à tous/toutes… :smt006
ps: j’ai mis entre “>>> <<<” (qu’il ne faut pas recopier bien sûr… :blush: :wink: :blush: ) ce qui changeait, je n’ai pas réussi à le mettre en gras, visiblement ça ne marche pas entre les balises… :blush: :blush: :blush:
À mon humble avis, tant que la bibliothèque dri ne sera pas chargée on aura beau mettre toutes les options du manuel, ça ne changera pas grand chose. Il faut d’abord savoir pourquoi la bibliothèque dri ne se charge pas.
As-tu essayé de réinstaller ligl1-mesa-dri ? Juste au cas où des manipulations précédentes auraient fichu le bazar…
quote="Num’s"
ps: j’ai mis entre “>>> <<<” (qu’il ne faut pas recopier bien sûr… :blush: :wink: :blush: ) ce qui changeait, je n’ai pas réussi à le mettre en gras, visiblement ça ne marche pas entre les balises… :blush: :blush: :blush:[/quote]Pas les balises [ c o d e ][ / c o d e ], mais avec les balises [ q u o t e ][ / q u o t e ], le gras passe.
[quote=“mattotop”]Pas les balises [ c o d e ][ / c o d e ], mais avec les balises [ q u o t e ][ / q u o t e ], le gras passe.[/quote]Merci pour l’info… :wink:
Yep mais toujours sans résultats :cry:
Merci quand même !
