Plus de touchpad
Salut !
J’ai un petit problème depuis hier (après un upgrade de nombreux paquets système) : mon touchpad ne fonctionne plus. Les boutons de clic intégrés fonctionnent parfaitement, mais impossible de faire fonctionner le trackpad. J’ai installé le paquet tpconfig, et fait quelques tests vite fait mais je vois pas quoi faire de plus :
root@n0x:~# egrep -i 'synap|alps|etps' /proc/bus/input/devices N: Name="AlpsPS/2 ALPS DualPoint TouchPad" root@n0x:~#
J’ai aussi remarqué une différence dans les logs :
root@n0x:~# grep -i alps /var/log/messages Jun 23 13:05:16 n0x kernel: [ 17.950964] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input7 Jun 23 13:53:26 n0x kernel: [ 11.817442] input: AlpsPS/2 ALPS DualPoint TouchPad as /devices/platform/i8042/serio1/input/input10 Jun 23 19:53:16 n0x kernel: [ 26.190216] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input7 Jun 24 08:21:25 n0x kernel: [ 19.397626] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input6 Jun 25 10:05:33 n0x kernel: [ 758.436139] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input52 Jun 26 08:09:25 n0x kernel: [ 36.968776] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input7 Jun 26 16:52:10 n0x kernel: [ 32.550061] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input6 Jun 27 08:11:41 n0x kernel: [ 47.280912] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input7 Jun 27 16:49:33 n0x kernel: [ 19.091459] input: AlpsPS/2 ALPS DualPoint TouchPad as /devices/platform/i8042/serio1/input/input10 Jun 27 17:00:17 n0x kernel: [ 11.310452] input: AlpsPS/2 ALPS DualPoint TouchPad as /devices/platform/i8042/serio1/input/input10 Jun 27 17:10:56 n0x kernel: [ 12.980767] input: AlpsPS/2 ALPS DualPoint TouchPad as /devices/platform/i8042/serio1/input/input10 Jun 27 18:32:12 n0x kernel: [ 11.750591] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input7 Jun 27 18:43:25 n0x kernel: [ 20.154791] input: AlpsPS/2 ALPS DualPoint TouchPad as /devices/platform/i8042/serio1/input/input9 Jun 27 20:24:34 n0x kernel: [ 192.086663] input: AlpsPS/2 ALPS DualPoint TouchPad as /devices/platform/i8042/serio1/input/input7 Jun 27 20:26:23 n0x kernel: [ 46.062589] input: AlpsPS/2 ALPS DualPoint TouchPad as /devices/platform/i8042/serio1/input/input10 root@n0x:~#
Merci de votre aide :slightly_smiling:
Sid ?
Testing ?
Apt-listbugs ?
Merde encore oublié de mettre ma distrib, je croyais avoir modifié ma signature ><
Je suis sous crunchbang, donc debian wheezy.
J’ai voulu faire une mise a jour jessie, mais aucun de mes problèmes n’étaient résolus, je suis donc repassé en wheezy.
Non, c’est une version dérivée.
Comment ?
Je me suis mal exprimé :smiley: Je suis donc sous Crunchbang linux, qui utilise les paquets wheezy de Debian.
Donc j’avais ajouté les dépôts Jessie, installé les paquets que je pensais nécessaires pour la résolution de mes problèmes (graphiques entre autres) mais comme aucun n’était résolu, j’ai supprimé les dépôts jessie, désinstallé les paquets concernés et ensuite réinstallés avec les dépôts wheezy.
Que faut-il comprendre par réinstallés ?
[ul]- réinstallés les paquets ?
  • réinstallés de A à Z le bouzin ? [/ul]
Non non simplement les paquets ! J’ai pas vraiment envie de réinstaller le PC maintenant :smiley:
J’ai également ça :
[code]root@n0x:~# grep -i touchpad /var/log/Xorg.0.log
[ 49.212] (II) config/udev: Adding input device AlpsPS/2 ALPS DualPoint TouchPad (/dev/input/event12)
[ 49.212] () AlpsPS/2 ALPS DualPoint TouchPad: Applying InputClass “evdev touchpad catchall”
[ 49.212] (II) Using input driver ‘evdev’ for ‘AlpsPS/2 ALPS DualPoint TouchPad’
[ 49.212] (
) AlpsPS/2 ALPS DualPoint TouchPad: always reports core events
[ 49.212] () evdev: AlpsPS/2 ALPS DualPoint TouchPad: Device: “/dev/input/event12”
[ 49.212] (II) evdev: AlpsPS/2 ALPS DualPoint TouchPad: Using mtdev for this device
[ 49.212] (–) evdev: AlpsPS/2 ALPS DualPoint TouchPad: Vendor 0x2 Product 0x8
[ 49.212] (–) evdev: AlpsPS/2 ALPS DualPoint TouchPad: Found 3 mouse buttons
[ 49.212] (–) evdev: AlpsPS/2 ALPS DualPoint TouchPad: Found absolute axes
[ 49.212] (–) evdev: AlpsPS/2 ALPS DualPoint TouchPad: Found absolute multitouch axes
[ 49.212] (–) evdev: AlpsPS/2 ALPS DualPoint TouchPad: Found x and y absolute axes
[ 49.212] (–) evdev: AlpsPS/2 ALPS DualPoint TouchPad: Found absolute touchpad.
[ 49.212] (II) evdev: AlpsPS/2 ALPS DualPoint TouchPad: Configuring as touchpad
[ 49.212] (
) evdev: AlpsPS/2 ALPS DualPoint TouchPad: YAxisMapping: buttons 4 and 5
[ 49.212] () evdev: AlpsPS/2 ALPS DualPoint TouchPad: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 49.212] (II) XINPUT: Adding extended input device “AlpsPS/2 ALPS DualPoint TouchPad” (type: TOUCHPAD, id 15)
[ 49.213] (II) evdev: AlpsPS/2 ALPS DualPoint TouchPad: initialized for absolute axes.
[ 49.213] (
) AlpsPS/2 ALPS DualPoint TouchPad: (accel) keeping acceleration scheme 1
[ 49.213] () AlpsPS/2 ALPS DualPoint TouchPad: (accel) acceleration profile 0
[ 49.213] (
) AlpsPS/2 ALPS DualPoint TouchPad: (accel) acceleration factor: 2.000
[ 49.213] (**) AlpsPS/2 ALPS DualPoint TouchPad: (accel) acceleration threshold: 4
[ 49.213] (II) config/udev: Adding input device AlpsPS/2 ALPS DualPoint TouchPad (/dev/input/mouse2)
root@n0x:~#
Et pourtant, tu devrais. :033
Donc tes clicks fonctionnent, mais tu ne peux pas déplacer le curseur de la souris, c’est ça ?
C’est curieux.
Si le problème était matériel, tu n’aurais à mon avis ni click ni mouvement de curseur possible. Donc ça fait penser à un problème de configuration du touchpad.
Je ne connais pas tpconfig.
Par contre je connais synclient.
manpages.debian.org/cgi-bin/man. … &locale=en
Ceci listera les infos de configuration:
… ça te permettra peut-être de voir s’il y a une anomalie.
