/var/log/Xorg.0.log
[quote][ 50.312]
X.Org X Server 1.17.3
Release Date: 2015-10-26
[ 50.312] X Protocol Version 11, Revision 0
[ 50.312] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[ 50.312] Current Operating System: Linux debian 4.2.0-1-amd64 #1 SMP Debian 4.2.6-1 (2015-11-10) x86_64
[ 50.312] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.2.0-1-amd64 root=UUID=342477a2-0350-4368-8761-21fe842c6439 ro quiet
[ 50.312] Build Date: 27 October 2015 11:41:02PM
[ 50.312] xorg-server 2:1.17.3-2 (debian.org/support)
[ 50.313] Current version of pixman: 0.33.4
[ 50.313] Before reporting problems, check wiki.x.org
[ 50.313] Markers: (–) probed, () from config file, (==) default setting,
[ 50.317] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Nov 11 22:33:24 2015
[ 50.319] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 50.319] (==) No Layout section. Using the first Screen section.
[ 50.319] (==) No screen section available. Using defaults.
[ 50.319] () |–>Screen “Default Screen Section” (0)
[ 50.319] (**) | |–>Monitor “”
[ 50.319] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 50.319] (==) Automatically adding devices
[ 50.319] (==) Automatically enabling devices
[ 50.319] (==) Automatically adding GPU devices
[ 50.319] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 50.319] Entry deleted from font path.
[ 50.319] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 50.319] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 50.319] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 50.319] (II) Loader magic: 0x55aa31540de0
[ 50.319] (II) Module ABI versions:
[ 50.319] X.Org ANSI C Emulation: 0.4
[ 50.319] X.Org Video Driver: 19.0
[ 50.319] X.Org XInput driver : 21.0
[ 50.319] X.Org Server Extension : 9.0
[ 50.322] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_3115
[ 50.323] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 50.323] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 8 paused 0
[ 50.324] (–) PCI:*(0:0:2:0) 8086:0162:1849:0162 rev 9, Mem @ 0xf7800000/4194304, 0xe0000000/268435456, I/O @ 0x0000f000/64
[ 50.324] (II) LoadModule: “glx”
[ 50.324] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 50.326] (II) Module glx: vendor=“X.Org Foundation”
[ 50.326] compiled for 1.17.3, module version = 1.0.0
[ 50.326] ABI class: X.Org Server Extension, version 9.0
[ 50.326] (==) AIGLX enabled
[ 50.326] (==) Matched intel as autoconfigured driver 0
[ 50.326] (==) Matched intel as autoconfigured driver 1
[ 50.326] (==) Matched modesetting as autoconfigured driver 2
[ 50.326] (==) Matched fbdev as autoconfigured driver 3
[ 50.326] (==) Matched vesa as autoconfigured driver 4
[ 50.326] (==) Assigned the driver to the xf86ConfigLayout
[ 50.326] (II) LoadModule: “intel”
[ 50.326] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 50.326] (II) Module intel: vendor=“X.Org Foundation”
[ 50.326] compiled for 1.17.2, module version = 2.99.917
[ 50.326] Module class: X.Org Video Driver
[ 50.326] ABI class: X.Org Video Driver, version 19.0
[ 50.326] (II) LoadModule: “modesetting”
[ 50.326] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 50.326] (II) Module modesetting: vendor=“X.Org Foundation”
[ 50.326] compiled for 1.17.3, module version = 1.17.3
[ 50.326] (II) LoadModule: “fbdev”
[ 50.326] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 50.326] (II) Module fbdev: vendor=“X.Org Foundation”
[ 50.326] compiled for 1.17.1, module version = 0.4.4
[ 50.326] (II) LoadModule: “vesa”
[ 50.326] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 50.327] (II) Module vesa: vendor=“X.Org Foundation”
[ 50.327] compiled for 1.17.3, module version = 2.3.4
[ 50.327] Module class: X.Org Video Driver
[ 50.327] ABI class: X.Org Video Driver, version 19.0
[ 50.327] (II) intel: Driver for Intel® Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 50.327] (II) intel: Driver for Intel® HD Graphics: 2000-6000
[ 50.327] (II) intel: Driver for Intel® Iris™ Graphics: 5100, 6100
[ 50.327] (II) intel: Driver for Intel® Iris™ Pro Graphics: 5200, 6200, P6300
[ 50.327] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 50.327] (II) FBDEV: driver for framebuffer: fbdev
[ 50.327] (II) VESA: driver for VESA chipsets: vesa
[ 50.327] (++) using VT number 1
[ 50.327] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20150522
[ 50.327] (II) intel(0): SNA compiled: xserver-xorg-video-intel 2:2.99.917-2 (Vincent Cheng vcheng@debian.org)
[ 50.327] (II) intel(0): SNA compiled for use with valgrind
[ 50.327] (WW) Falling back to old probe method for modesetting
[ 50.327] (WW) Falling back to old probe method for fbdev
[ 50.327] (II) Loading sub module “fbdevhw”
[ 50.327] (II) LoadModule: “fbdevhw”
[ 50.327] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 50.327] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 50.327] compiled for 1.17.3, module version = 0.0.2
[ 50.328] (WW) Falling back to old probe method for vesa
[ 50.328] (–) intel(0): Integrated Graphics Chipset: Intel® HD Graphics 4000
[ 50.328] (–) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx
[ 50.328] (II) intel(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 50.328] (==) intel(0): Depth 24, (–) framebuffer bpp 32
[ 50.328] (==) intel(0): RGB weight 888
[ 50.328] (==) intel(0): Default visual is TrueColor
[ 50.328] (II) intel(0): Output VGA1 has no monitor section
[ 50.328] (II) intel(0): Enabled output VGA1
[ 50.328] (II) intel(0): Output HDMI1 has no monitor section
[ 50.328] (II) intel(0): Enabled output HDMI1
[ 50.328] (II) intel(0): Output DP1 has no monitor section
[ 50.328] (II) intel(0): Enabled output DP1
[ 50.328] (II) intel(0): Output HDMI2 has no monitor section
[ 50.328] (II) intel(0): Enabled output HDMI2
[ 50.328] (II) intel(0): Output HDMI3 has no monitor section
[ 50.328] (II) intel(0): Enabled output HDMI3
[ 50.328] (II) intel(0): Output DP2 has no monitor section
[ 50.328] (II) intel(0): Enabled output DP2
[ 50.328] (II) intel(0): Output DP3 has no monitor section
[ 50.328] (II) intel(0): Enabled output DP3
[ 50.328] (–) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 50.328] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 50.328] (II) intel(0): Enabled output VIRTUAL1
[ 50.328] (–) intel(0): Output HDMI1 using initial mode 1280x1024 on pipe 0
[ 50.328] (==) intel(0): TearFree disabled
[ 50.329] (==) intel(0): DPI set to (96, 96)
[ 50.329] (II) Loading sub module “dri2”
[ 50.329] (II) LoadModule: “dri2”
[ 50.329] (II) Module “dri2” already built-in
[ 50.329] (II) Loading sub module “present”
[ 50.329] (II) LoadModule: “present”
[ 50.329] (II) Module “present” already built-in
[ 50.329] (II) UnloadModule: “modesetting”
[ 50.329] (II) Unloading modesetting
[ 50.329] (II) UnloadModule: “fbdev”
[ 50.329] (II) Unloading fbdev
[ 50.329] (II) UnloadSubModule: “fbdevhw”
[ 50.329] (II) Unloading fbdevhw
[ 50.329] (II) UnloadModule: “vesa”
[ 50.329] (II) Unloading vesa
[ 50.329] (==) Depth 24 pixmap format is 32 bpp
[ 50.329] (II) intel(0): SNA initialized with Ivybridge (gen7, gt2) backend
[ 50.329] (==) intel(0): Backing store enabled
[ 50.329] (==) intel(0): Silken mouse enabled
[ 50.329] (II) intel(0): HW Cursor enabled
[ 50.329] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 50.329] (==) intel(0): DPMS enabled
[ 50.329] (==) intel(0): display hotplug detection enabled
[ 50.329] (II) intel(0): [DRI2] Setup complete
[ 50.329] (II) intel(0): [DRI2] DRI driver: i965
[ 50.329] (II) intel(0): [DRI2] VDPAU driver: i965
[ 50.329] (II) intel(0): direct rendering: DRI2 enabled
[ 50.329] (II) intel(0): hardware support for Present enabled
[ 50.329] (–) RandR disabled
[ 50.334] (II) SELinux: Disabled on system
[ 50.343] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 50.343] (II) AIGLX: enabled GLX_ARB_create_context
[ 50.343] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 50.343] (II) AIGLX: enabled GLX_EXT_create_context_es2_profile
[ 50.343] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 50.343] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 50.343] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 50.343] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 50.343] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 50.343] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[ 50.344] (II) AIGLX: Loaded and initialized i965
[ 50.344] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 50.346] (II) intel(0): switch to mode 1280x1024@60.0 on HDMI1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 50.347] (II) intel(0): Setting screen physical size to 338 x 270
[ 50.384] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[ 50.384] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 50.384] (II) LoadModule: “evdev”
[ 50.384] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 50.384] (II) Module evdev: vendor=“X.Org Foundation”
[ 50.384] compiled for 1.16.4, module version = 2.9.2
[ 50.384] Module class: X.Org XInput Driver
[ 50.384] ABI class: X.Org XInput driver, version 21.0
[ 50.385] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 16 paused 0
[ 50.385] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 50.385] () Power Button: always reports core events
[ 50.385] () evdev: Power Button: Device: “/dev/input/event4”
[ 50.385] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 50.385] (–) evdev: Power Button: Found keys
[ 50.385] (II) evdev: Power Button: Configuring as keyboard
[ 50.385] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input6/event4”
[ 50.385] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 50.385] () Option “xkb_rules” “evdev”
[ 50.385] () Option “xkb_model” “pc105”
[ 50.385] () Option “xkb_layout” “fr”
[ 50.385] () Option “xkb_variant” “latin9”
[ 50.403] (II) config/udev: Adding input device Video Bus (/dev/input/event13)
[ 50.403] () Video Bus: Applying InputClass “evdev keyboard catchall”
[ 50.403] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 17 paused 0
[ 50.403] (II) Using input driver ‘evdev’ for ‘Video Bus’
[ 50.403] () Video Bus: always reports core events
[ 50.403] () evdev: Video Bus: Device: “/dev/input/event13”
[ 50.404] (–) evdev: Video Bus: Vendor 0 Product 0x6
[ 50.404] (–) evdev: Video Bus: Found keys
[ 50.404] (II) evdev: Video Bus: Configuring as keyboard
[ 50.404] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input16/event13”
[ 50.404] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 7)
[ 50.404] () Option “xkb_rules” “evdev”
[ 50.404] () Option “xkb_model” “pc105”
[ 50.404] () Option “xkb_layout” “fr”
[ 50.404] () Option “xkb_variant” “latin9”
[ 50.404] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 50.404] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 50.405] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 18 paused 0
[ 50.405] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 50.405] () Power Button: always reports core events
[ 50.405] () evdev: Power Button: Device: “/dev/input/event3”
[ 50.405] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 50.405] (–) evdev: Power Button: Found keys
[ 50.405] (II) evdev: Power Button: Configuring as keyboard
[ 50.405] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5/event3”
[ 50.405] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id
[ 50.405] () Option “xkb_rules” “evdev”
[ 50.405] () Option “xkb_model” “pc105”
[ 50.405] () Option “xkb_layout” “fr”
[ 50.405] () Option “xkb_variant” “latin9”
[ 50.406] (II) config/udev: Adding input device CHESEN USB Keyboard (/dev/input/event0)
[ 50.406] () CHESEN USB Keyboard: Applying InputClass “evdev keyboard catchall”
[ 50.406] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 19 paused 0
[ 50.406] (II) Using input driver ‘evdev’ for ‘CHESEN USB Keyboard’
[ 50.406] () CHESEN USB Keyboard: always reports core events
[ 50.406] () evdev: CHESEN USB Keyboard: Device: “/dev/input/event0”
[ 50.406] (–) evdev: CHESEN USB Keyboard: Vendor 0xa81 Product 0x101
[ 50.406] (–) evdev: CHESEN USB Keyboard: Found keys
[ 50.406] (II) evdev: CHESEN USB Keyboard: Configuring as keyboard
[ 50.406] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:0A81:0101.0001/input/input2/event0”
[ 50.406] (II) XINPUT: Adding extended input device “CHESEN USB Keyboard” (type: KEYBOARD, id 9)
[ 50.406] () Option “xkb_rules” “evdev”
[ 50.406] () Option “xkb_model” “pc105”
[ 50.406] () Option “xkb_layout” “fr”
[ 50.406] () Option “xkb_variant” “latin9”
[ 50.407] (II) config/udev: Adding input device CHESEN USB Keyboard (/dev/input/event1)
[ 50.407] () CHESEN USB Keyboard: Applying InputClass “evdev keyboard catchall”
[ 50.408] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 20 paused 0
[ 50.408] (II) Using input driver ‘evdev’ for ‘CHESEN USB Keyboard’
[ 50.408] () CHESEN USB Keyboard: always reports core events
[ 50.408] () evdev: CHESEN USB Keyboard: Device: “/dev/input/event1”
[ 50.408] (–) evdev: CHESEN USB Keyboard: Vendor 0xa81 Product 0x101
[ 50.408] (–) evdev: CHESEN USB Keyboard: Found keys
[ 50.408] (II) evdev: CHESEN USB Keyboard: Configuring as keyboard
[ 50.408] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:0A81:0101.0002/input/input3/event1”
[ 50.408] (II) XINPUT: Adding extended input device “CHESEN USB Keyboard” (type: KEYBOARD, id 10)
[ 50.408] () Option “xkb_rules” “evdev”
[ 50.408] () Option “xkb_model” “pc105”
[ 50.408] () Option “xkb_layout” “fr”
[ 50.408] () Option “xkb_variant” “latin9”
[ 50.408] (II) config/udev: Adding input device Logitech Optical USB Mouse (/dev/input/event2)
[ 50.408] () Logitech Optical USB Mouse: Applying InputClass “evdev pointer catchall”
[ 50.464] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 21 paused 0
[ 50.464] (II) Using input driver ‘evdev’ for ‘Logitech Optical USB Mouse’
[ 50.464] () Logitech Optical USB Mouse: always reports core events
[ 50.464] () evdev: Logitech Optical USB Mouse: Device: “/dev/input/event2”
[ 50.464] (–) evdev: Logitech Optical USB Mouse: Vendor 0x46d Product 0xc016
[ 50.464] (–) evdev: Logitech Optical USB Mouse: Found 3 mouse buttons
[ 50.464] (–) evdev: Logitech Optical USB Mouse: Found scroll wheel(s)
[ 50.464] (–) evdev: Logitech Optical USB Mouse: Found relative axes
[ 50.464] (–) evdev: Logitech Optical USB Mouse: Found x and y relative axes
[ 50.464] (II) evdev: Logitech Optical USB Mouse: Configuring as mouse
[ 50.464] (II) evdev: Logitech Optical USB Mouse: Adding scrollwheel support
[ 50.464] () evdev: Logitech Optical USB Mouse: YAxisMapping: buttons 4 and 5
[ 50.464] () evdev: Logitech Optical USB Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 50.464] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C016.0003/input/input4/event2”
[ 50.464] (II) XINPUT: Adding extended input device “Logitech Optical USB Mouse” (type: MOUSE, id 11)
[ 50.464] (II) evdev: Logitech Optical USB Mouse: initialized for relative axes.
[ 50.464] () Logitech Optical USB Mouse: (accel) keeping acceleration scheme 1
[ 50.464] () Logitech Optical USB Mouse: (accel) acceleration profile 0
[ 50.464] () Logitech Optical USB Mouse: (accel) acceleration factor: 2.000
[ 50.464] () Logitech Optical USB Mouse: (accel) acceleration threshold: 4
[ 50.465] (II) config/udev: Adding input device Logitech Optical USB Mouse (/dev/input/mouse0)
[ 50.465] (II) No input driver specified, ignoring this device.
[ 50.465] (II) This device may have been added with another device file.
[ 50.465] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event7)
[ 50.465] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event8)
[ 50.466] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event9)
[ 50.466] (II) No input driver specified, ignoring this device.
[ 50.466] (II) This device may have been added with another device file.
[ 50.466] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event10)
[ 50.466] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event11)
[ 50.467] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event12)
[ 50.467] (II) No input driver specified, ignoring this device.
[ 50.467] (II) This device may have been added with another device file.
[ 50.467] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event6)
[ 50.467] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 50.467] (II) This device may have been added with another device file.[/quote]
(J’ai aussi Xorg.1.log, 2, 3 , 4 et 5)
Par contre je n’ai pas de dossier xorg dans le /.local/share/ de mon home utilisateur
