Suite de mes essais de connexions sans box. Pour l’instant je suis sur une connexion PPPoE avec un modem Olitec.
J’ai réussi à mettre la main sur un Sagem fast 800 que j’aimerais configurer pour me connexter en PPPoA (afin d’éviter les désagréments liés à la limitation du MTU et l’obligation de passer en TCP pour mes tunnels VPN).
Et je dois dire que l’idée de me connecter en PPPoA m’amuse beaucoup.
Je sais que PascalHambourg connais parfaitement le problème, son aide serait la bienvenue.
Je suis tombé sur ce fil qui m’a aidé: modem-sagem-fast-800-usb-t37506.html
Mais sans succès…
dmesg (J’ai l’impression que c’est bon):
[ 266.399877] usb 3-4: new full-speed USB device number 3 using xhci_hcd
[ 266.416235] usb 3-4: New USB device found, idVendor=1110, idProduct=9022
[ 266.416237] usb 3-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 266.541787] NET: Registered protocol family 8
[ 266.541789] NET: Registered protocol family 20
[ 266.588852] usb 3-4: [ueagle-atm] ADSL device founded vid (0X1110) pid (0X9022) Rev (0X5000): Eagle II
[ 266.753449] usb 3-4: reset full-speed USB device number 3 using xhci_hcd
[ 266.772177] usb 3-4: [ueagle-atm] pre-firmware device, uploading firmware
[ 266.772181] usb 3-4: [ueagle-atm] loading firmware ueagle-atm/eagleII.fw
[ 266.772196] usbcore: registered new interface driver ueagle-atm
[ 266.815626] usb 3-4: [ueagle-atm] firmware uploaded
[ 266.850995] usb 3-4: USB disconnect, device number 3
[ 269.168530] usb 3-4: new full-speed USB device number 4 using xhci_hcd
[ 269.184403] usb 3-4: New USB device found, idVendor=1110, idProduct=9021
[ 269.184406] usb 3-4: New USB device strings: Mfr=0, Product=2, SerialNumber=3
[ 269.184407] usb 3-4: Product: ADSL-USB Modem
[ 269.184409] usb 3-4: SerialNumber: 00604C18F36A
[ 269.235850] usb 3-4: [ueagle-atm] ADSL device founded vid (0X1110) pid (0X9021) Rev (0X500B): Eagle II
[ 269.347448] usb 3-4: reset full-speed USB device number 4 using xhci_hcd
[ 269.363918] xhci_hcd 0000:00:14.0: xHCI xhci_drop_endpoint called with disabled ep ffff8801b6e31940
[ 269.363920] xhci_hcd 0000:00:14.0: xHCI xhci_drop_endpoint called with disabled ep ffff88018b082680
[ 269.363922] xhci_hcd 0000:00:14.0: xHCI xhci_drop_endpoint called with disabled ep ffff8801b6e31900
[ 269.363923] xhci_hcd 0000:00:14.0: xHCI xhci_drop_endpoint called with disabled ep ffff88019baaba00
[ 269.417706] usb 3-4: [ueagle-atm] using iso mode
[ 269.417910] usb 3-4: [ueagle-atm] (re)booting started
[ 271.046298] usb 3-4: [ueagle-atm] ATU-R firmware version : 44e2ea17
[ 271.047151] usb 3-4: [Ueagle-atm] requesting firmware ueagle-atm/CMVep.bin.v2 failed, try to get older cmvs
[ 271.057724] usb 3-4: [Ueagle-atm] use deprecated cmvs version, please update your firmware
[ 271.075290] usb 3-4: [ueagle-atm] modem started, waiting synchronization...
Les modules sont chargés:
# lsmod | grep ueagle
ueagle_atm 32959 0
usbatm 22792 1 ueagle_atm
atm 50872 2 ueagle_atm,usbatm
Mais quand je tente un pppd call ou un pon ça ne connecte pas…
May 7 09:44:18 laurent pppd[15206]: Plugin pppoatm.so loaded.
May 7 09:44:18 laurent pppd[15206]: pppd 2.4.5 started by root, uid 0
May 7 09:44:18 laurent pppd[15206]: Using interface ppp0
May 7 09:44:18 laurent pppd[15206]: Connect: ppp0 <--> 8.35
May 7 09:44:48 laurent pppd[15206]: LCP: timeout sending Config-Requests
May 7 09:44:48 laurent pppd[15206]: Connection terminated.
May 7 09:44:48 laurent pppd[15206]: Modem hangup
May 7 09:33:37 laurent pppd[14094]: LCP: timeout sending Config-Requests
May 7 09:33:37 laurent pppd[14094]: Connection terminated.
Voici le fichier peers que j’ai créé (le fichiers chap-secrets est bien configuré je pense)
# cat /etc/ppp/peers/pppoalinkname "ppp0"
user "adsl.user@moov.mg"
noauth
hide-password
noipdefault
persist
holdoff 4
maxfail 25
usepeerdns
defaultroute
updetach
plugin pppoatm.so
8.35
J’ai aussi récupéré le dsl-provider de ma connexion PPPoE en changeant juste le module, mais ça ne fonctionne pas non plus:
pon essai && tail -f /var/log/syslog | grep ppp
May 7 10:19:18 laurent pppd[9966]: Plugin pppoatm.so loaded.
May 7 10:19:18 laurent pppd[9970]: pppd 2.4.5 started by root, uid 0
May 7 10:19:18 laurent pppd[9970]: Using interface ppp0
May 7 10:19:18 laurent pppd[9970]: Connect: ppp0 <--> 8.35
May 7 10:19:48 laurent pppd[9970]: LCP: timeout sending Config-Requests
May 7 10:19:48 laurent pppd[9970]: Connection terminated.
May 7 10:19:48 laurent avahi-daemon[1286]: Withdrawing workstation service for ppp0.
May 7 10:19:48 laurent pppd[9970]: Modem hangup
Mon FAI ne supporterais pas le PPPoA ? ![]()
Comment en être certain (à part téléphoner au service client qui sera incapable de répondre à ma question) ?
