Depuis quelques jours, j’ai installé amule via Aptitude.
je l’ai configuré suivant un tuto dans un site…
quand c’est lancé le telechargement est correct.
Mais…
Amule s’arrete tout seul
je l’ai lancé une fois avec le terminal et je vois qu’il y a un crash d’amule…
[code]lavio@Debian:~$ amule
Initialising aMule
Checking if there is an instance already running…
No other instances are running.
Loading temp files from /home/lavio/.aMule/Temp.
Loading PartFile 7 of 7
All PartFiles Loaded.
ListenSocket: Ok.
External connections disabled in config file
*** Server UDP socket (TCP+3) at 0.0.0.0:5328
*** TCP socket (TCP) listening on 0.0.0.0:5325
*** Client UDP socket (extended eMule) at 0.0.0.0:5361
Adding file /home/lavio/.aMule/Temp/001.part.met to shares
Adding file /home/lavio/.aMule/Temp/002.part.met to shares
Adding file /home/lavio/.aMule/Temp/003.part.met to shares
Adding file /home/lavio/.aMule/Temp/004.part.met to shares
Adding file /home/lavio/.aMule/Temp/006.part.met to shares
Adding file /home/lavio/.aMule/Temp/007.part.met to shares
HTTP download thread started
Host: ovh.dl.sourceforge.net:80
URL: http://ovh.dl.sourceforge.net/sourceforge/emulepawcio/ipfilter.dat
Response: 200 (Error: 0)
Download size: 11793445
HTTP download cancelled
HTTP download thread ended
--------------------------------------------------------------------------------A fatal error has occurred and aMule has crashed.
Please assist us in fixing this problem by posting the backtrace below in our
’aMule Crashes’ forum and include as much information as possible regarding the
circumstances of this crash. The forum is located here:
http://forum.amule.org/board.php?boardid=67
If possible, please try to generate a real backtrace of this crash:
http://www.amule.org/wiki/index.php/Backtraces
----------------------------=| BACKTRACE FOLLOWS: |=----------------------------Current version is: aMule 2.1.3 using wxGTK2 v2.6.3 (Unicoded)
Running on: Linux 2.6.18-4-686 i686
[2] wxThreadHelperThread::~wxThreadHelperThread() in amule [0x80807af]
[3] wxFatalSignalHandler in /usr/lib/libwx_baseu-2.6.so.0[0xb7688b26]
[4] ?? in [0xb7f92420]
[5] ?? in [0xaf8fc48]
[6] ?? in /usr/lib/libgdk-x11-2.0.so.0 [0xb701f28e]
[7] ?? in /usr/lib/libglib-2.0.so.0 [0xb6dd0c7f]
[8] g_main_context_dispatch in /usr/lib/libglib-2.0.so.0[0xb6da7731]
[9] ?? in /usr/lib/libglib-2.0.so.0 [0xb6daa7a6]
[10] g_main_loop_run in /usr/lib/libglib-2.0.so.0[0xb6daab67]
[11] gtk_main in /usr/lib/libgtk-x11-2.0.so.0[0xb71af281]
[12] wxEventLoop::Run() in /usr/lib/libwx_gtk2u_core-2.6.so.0[0xb780baeb]
[13] wxAppBase::MainLoop() in /usr/lib/libwx_gtk2u_core-2.6.so.0[0xb78a34be]
[14] wxAppBase::OnRun() in /usr/lib/libwx_gtk2u_core-2.6.so.0[0xb78a2b61]
[15] wxEntry(int&, wchar_t**) in /usr/lib/libwx_baseu-2.6.so.0[0xb762c45a]
[16] wxEntry(int&, char**) in /usr/lib/libwx_baseu-2.6.so.0[0xb762c506]
[17] CryptoPP::IteratedHash<unsigned int, CryptoPP::EnumToType<CryptoPP::ByteOrder, 0>, 64u, CryptoPP::HashTransformation>::~IteratedHash() in amule [0x8127710][18] __libc_start_main in /lib/tls/i686/cmov/libc.so.6[0xb7388ea8]
[19] __gxx_personality_v0 in amule[0x807cd01]
--------------------------------------------------------------------------------Abandon
Je voudrais savoir si vous avez eu des problèmes et surtout que faire…
car là je ne pige rien…
j’ai un peu de mal avec le forum amule en anglais…
ah oui depuis, j’ai des problème d’extension d’écran quand je le ferme. (par moment ça marche et très souvent ça ne marche pas du tout)
merci d’avance
