Hello,
Voici les retours demandés :
$ /sbin/route -v
Table de routage IP du noyau
Destination Passerelle Genmask Indic Metric Ref Use Iface
default _gateway 0.0.0.0 UG 600 0 0 wlp0s20f3
10.4.0.0 0.0.0.0 255.255.255.0 U 50 0 0 tap0
10.100.100.100 10.4.0.1 255.255.255.255 UGH 50 0 0 tap0
172.17.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker0
172.99.0.0 0.0.0.0 255.255.255.0 U 0 0 0 br-b32cfc7951db
ns388937.ip-176 _gateway 255.255.255.255 UGH 50 0 0 wlp0s20f3
192.168.248.0 0.0.0.0 255.255.254.0 U 600 0 0 wlp0s20f3
_gateway 0.0.0.0 255.255.255.255 UH 50 0 0 wlp0s20f3
$ ping one.one.one.one
PING one.one.one.one (1.1.1.1) 56(84) bytes of data.
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=1 ttl=58 time=4.29 ms
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=2 ttl=58 time=5.83 ms
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=3 ttl=58 time=8.49 ms
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=4 ttl=58 time=5.12 ms
^C
--- one.one.one.one ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 4.285/5.932/8.493/1.576 ms
$ cat /etc/resolv.conf
# Generated by NetworkManager
nameserver 10.4.0.1
nameserver 149.62.156.10
nameserver 149.62.158.222
Et la dernière, sachant qu’il y a pas mal de services - Docker par exemple - qui tournent sur ma machine :
$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host noprefixroute
2: enp0s31f6: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 74:5d:22:6c:8f:5e brd ff:ff:ff:ff:ff:ff
3: wlp0s20f3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 04:e8:b9:af:8b:ec brd ff:ff:ff:ff:ff:ff
inet 192.168.248.117/23 brd 192.168.249.255 scope global dynamic noprefixroute wlp0s20f3
valid_lft 9343sec preferred_lft 9343sec
inet6 fe80::31dd:f785:e30b:8ff8/64 scope link noprefixroute
4: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:92:9c:1f:ba brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
5: br-b32cfc7951db: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
link/ether 02:42:25:80:46:cd brd ff:ff:ff:ff:ff:ff
inet 172.99.0.1/24 brd 172.99.0.255 scope global br-b32cfc7951db
inet6 fe80::42:25ff:fe80:46cd/64 scope link
7: vethb938ed4@if6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-b32cfc7951db state UP group default
link/ether 92:42:de:d4:74:a6 brd ff:ff:ff:ff:ff:ff link-netnsid 1
inet6 fe80::9042:deff:fed4:74a6/64 scope link
9: vethe82bf99@if8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-b32cfc7951db state UP group default
link/ether 96:8a:ff:2e:46:97 brd ff:ff:ff:ff:ff:ff link-netnsid 2
inet6 fe80::948a:ffff:fe2e:4697/64 scope link
11: veth3a6a00b@if10: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-b32cfc7951db state UP group default
link/ether 32:01:33:54:04:d9 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::3001:33ff:fe54:4d9/64 scope link
13: veth5855816@if12: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-b32cfc7951db state UP group default
link/ether 16:95:15:2a:9f:aa brd ff:ff:ff:ff:ff:ff link-netnsid 4
inet6 fe80::1495:15ff:fe2a:9faa/64 scope link
15: veth80cad9b@if14: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-b32cfc7951db state UP group default
link/ether ae:2c:d4:ab:4f:6e brd ff:ff:ff:ff:ff:ff link-netnsid 3
inet6 fe80::ac2c:d4ff:feab:4f6e/64 scope link
16: tap0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
link/ether a6:cf:bb:a2:c0:99 brd ff:ff:ff:ff:ff:ff
inet 10.4.0.172/24 brd 10.4.0.255 scope global noprefixroute tap0
inet6 fe80::a4cf:bbff:fea2:c099/64 scope link
Pour les log.*.gz, je cherche, je n’ai encore aucune idée d’où ils se trouvent.
EDIT : pas besoin de regarder dans les logs, voici le retour de apt effectué depuis mon réseau :
$ sudo apt install cowsay
[sudo] Mot de passe de — :
Paquets suggérés :
filters cowsay-off
cowsay
0 mis à jour, 1 nouvellement installés, 0 à enlever et 18 non mis à jour.
Il est nécessaire de prendre 21,4 ko dans les archives.
Après cette opération, 94,2 ko d’espace disque supplémentaires seront utilisés.
Ign :1 http://deb.debian.org/debian bookworm/main amd64 cowsay all 3.03+dfsg2-8
Err :1 http://deb.debian.org/debian bookworm/main amd64 cowsay all 3.03+dfsg2-8
Ne parvient pas à résoudre « guest.wojo.com?base_grant_url=https%3A%2F%2Feu.network-auth.com%2Fsplash%2FuYxjAaTc.2.173%2Fgrant&gateway_id=185021237006233&node_id=185021237006233&user_continue_url=http%3A%2F%2Fdeb.debian.org%2Fdebian%2Fpool%2Fmain%2Fc%2Fcowsay%2Fcowsay_3.03%2bdfsg2-8_all.deb&client_ip=10.147.87.226&client_mac=04:e8:b9:af:8b:ec&node_mac=a8:46:9d:1b:8f »
E: Impossible de récupérer https://[guest.wojo.com?base_grant_url=https%3A%2F%2Feu.network-auth.com%2Fsplash%2FuYxjAaTc.2.173%2Fgrant&gateway_id=185021237006233&node_id=185021237006233&user_continue_url=http%3A%2F%2Fdeb.debian.org%2Fdebian%2Fpool%2Fmain%2Fc%2Fcowsay%2Fcowsay_3.03%2bdfsg2-8_all.deb&client_ip=10.147.87.226&client_mac=04:e8:b9:af:8b:ec&node_mac=a8:46:9d:1b:8f]:99/ Ne parvient pas à résoudre « guest.wojo.com?base_grant_url=https%3A%2F%2Feu.network-auth.com%2Fsplash%2FuYxjAaTc.2.173%2Fgrant&gateway_id=185021237006233&node_id=185021237006233&user_continue_url=http%3A%2F%2Fdeb.debian.org%2Fdebian%2Fpool%2Fmain%2Fc%2Fcowsay%2Fcowsay_3.03%2bdfsg2-8_all.deb&client_ip=10.147.87.226&client_mac=04:e8:b9:af:8b:ec&node_mac=a8:46:9d:1b:8f »
E: Impossible de récupérer certaines archives, peut-être devrez-vous lancer apt-get update ou essayer avec --fix-missing ?
je précise que le réseau s’appelle WOJO-GUEST, et visiblement apt galère avec sa résolution car on dirait qu’il essaye de résoudre le mauvais nom de domaine, nom en lien avec le réseau Wifi.
