[quote][root@~] $dmesg
Linux version 2.6.22-2-k7 (Debian 2.6.22-4) (waldi@debian.org) (gcc version 4.1.3 20070812 (prerelease) (Debian 4.1.2-15)) #1 SMP Fri Aug 31 01:02:37 UTC 2007
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001fffc000 (usable)
BIOS-e820: 000000001fffc000 - 000000001ffff000 (ACPI data)
BIOS-e820: 000000001ffff000 - 0000000020000000 (ACPI NVS)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
511MB LOWMEM available.
Entering add_active_range(0, 0, 131068) 0 entries of 256 used
Zone PFN ranges:
DMA 0 -> 4096
Normal 4096 -> 131068
HighMem 131068 -> 131068
early_node_map[1] active PFN ranges
0: 0 -> 131068
On node 0 totalpages: 131068
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 4064 pages, LIFO batch:0
Normal zone: 991 pages used for memmap
Normal zone: 125981 pages, LIFO batch:31
HighMem zone: 0 pages used for memmap
DMI 2.3 present.
ACPI: RSDP 000F5E30, 0014 (r0 ASUS )
ACPI: RSDT 1FFFC000, 0030 (r1 ASUS A7V600-X 42302E31 MSFT 31313031)
ACPI: FACP 1FFFC0B2, 0074 (r1 ASUS A7V600-X 42302E31 MSFT 31313031)
ACPI: DSDT 1FFFC126, 2D63 (r1 ASUS A7V600-X 1000 MSFT 100000B)
ACPI: FACS 1FFFF000, 0040
ACPI: BOOT 1FFFC030, 0028 (r1 ASUS A7V600-X 42302E31 MSFT 31313031)
ACPI: APIC 1FFFC058, 005A (r1 ASUS A7V600-X 42302E31 MSFT 31313031)
ACPI: PM-Timer IO Port: 0xe408
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 6:10 APIC version 16
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 3, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 30000000 (gap: 20000000:dec00000)
Built 1 zonelists. Total pages: 130045
Kernel command line: root=/dev/sda1 ro vga=791 splash=silent
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore… done.
Enabling unmasked SIMD FPU exception support… done.
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 8192 bytes)
Detected 2275.000 MHz processor.
Console: colour dummy device 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 510812k/524272k available (1702k kernel code, 12872k reserved, 663k data, 244k init, 0k highmem)
virtual kernel memory layout:
fixmap : 0xfff4e000 - 0xfffff000 ( 708 kB)
pkmap : 0xff800000 - 0xffc00000 (4096 kB)
vmalloc : 0xe0800000 - 0xff7fe000 ( 495 MB)
lowmem : 0xc0000000 - 0xdfffc000 ( 511 MB)
.init : 0xc0355000 - 0xc0392000 ( 244 kB)
.data : 0xc02a998f - 0xc034f784 ( 663 kB)
.text : 0xc0100000 - 0xc02a998f (1702 kB)
Checking if this processor honours the WP bit even in supervisor mode… Ok.
Calibrating delay using timer specific routine… 4553.73 BogoMIPS (lpj=9107474)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
CPU: After all inits, caps: 0383fbff c1c3fbff 00000000 00000420 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking ‘hlt’ instruction… OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 11k freed
ACPI: Core revision 20070126
CPU0: AMD Athlon™ XP stepping 00
Total of 1 processors activated (4553.73 BogoMIPS).
ENABLING IO-APIC IRQs
…TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Brought up 1 CPUs
Booting paravirtualized kernel on bare hardware
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xf1970, last bus=1
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: (supports S0 S1 S4 S5)
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
PCI: enabled onboard AC97/MC97 devices
ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.PCI1._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 *10 11 12)
ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 9 10 11 12)
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12)
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 10 11 12) *15, disabled.
Linux Plug and Play Support v0.97 © Adam Belay
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp: PnP ACPI: found 14 devices
ACPI: ACPI bus type pnp unregistered
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
NET: Registered protocol family 8
NET: Registered protocol family 20
ACPI: RTC can wake from S4
pnp: 00:00: iomem range 0x0-0x9ffff could not be reserved
pnp: 00:00: iomem range 0xf0000-0xfffff could not be reserved
pnp: 00:00: iomem range 0x100000-0x1fffffff could not be reserved
pnp: 00:00: iomem range 0xfec00000-0xfec000ff could not be reserved
pnp: 00:02: ioport range 0xe400-0xe47f has been reserved
pnp: 00:02: ioport range 0xe800-0xe81f has been reserved
pnp: 00:02: iomem range 0xfff80000-0xffffffff could not be reserved
pnp: 00:02: iomem range 0xffb80000-0xffbfffff has been reserved
pnp: 00:0d: ioport range 0x290-0x297 has been reserved
pnp: 00:0d: ioport range 0x370-0x375 has been reserved
Time: tsc clocksource has been installed.
PCI: Bridge: 0000:00:01.0
IO window: d000-dfff
MEM window: df000000-dfffffff
PREFETCH window: e0000000-f7ffffff
PCI: Setting latency timer of device 0000:00:01.0 to 64
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 196608 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
checking if image is initramfs… it is
Freeing initrd memory: 5358k freed
Simple Boot Flag at 0x3a set to 0x1
audit: initializing netlink socket (disabled)
audit(1193999902.180:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
PCI: VIA PCI bridge detected. Disabling DAC.
PCI: Bypassing VIA 8237 APIC De-Assert Message
Boot video device is 0000:01:00.0
vesafb: framebuffer at 0xf0000000, mapped to 0xe0880000, using 3072k, total 16384k
vesafb: mode is 1024x768x16, linelength=2048, pages=9
vesafb: protected mode interface info at c000:5516
vesafb: pmi: set display start = c00c55aa, set palette = c00c55f6
vesafb: pmi: ports = d810 d816 d854 d838 d83c d85c d800 d804 d8b0 d8b2 d8b4
vesafb: scrolling: redraw
vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
Console: switching to colour frame buffer device 128x48
Switched to high resolution mode on CPU 0
fb0: VESA VGA frame buffer device
isapnp: Scanning for PnP cards…
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
PNP: PS/2 controller doesn’t have AUX irq; using default 12
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
Using IPI No-Shortcut mode
Freeing unused kernel memory: 244k freed
input: AT Translated Set 2 keyboard as /class/input/input0
SCSI subsystem initialized
libata version 2.21 loaded.
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:0f.1
ACPI: PCI Interrupt 0000:00:0f.1[A] -> GSI 20 (level, low) -> IRQ 16
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
ide0: BM-DMA at 0x9800-0x9807, BIOS settings: hda:pio, hdb:pio
ide1: BM-DMA at 0x9808-0x980f, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0…
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
USB Universal Host Controller Interface driver v3.0
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
Probing IDE interface ide1…
hdc: HL-DT-ST DVDRAM GSA-4160B, ATAPI CD/DVD-ROM drive
hdd: HL-DT-ST GCE-8525B, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
sata_via 0000:00:0f.0: version 2.2
ACPI: PCI Interrupt 0000:00:0f.0[B] -> GSI 20 (level, low) -> IRQ 16
sata_via 0000:00:0f.0: routed to hard irq line 0
scsi0 : sata_via
scsi1 : sata_via
ata1: SATA max UDMA/133 cmd 0x0001b800 ctl 0x0001b402 bmdma 0x0001a400 irq 16
ata2: SATA max UDMA/133 cmd 0x0001b000 ctl 0x0001a802 bmdma 0x0001a408 irq 16
ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata1.00: ATA-6: ST3120026AS, 3.18, max UDMA/133
ata1.00: 234441648 sectors, multi 16: LBA48
ata1.00: configured for UDMA/133
ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
scsi 0:0:0:0: Direct-Access ATA ST3120026AS 3.18 PQ: 0 ANSI: 5
ACPI: PCI Interrupt 0000:00:12.0[A] -> GSI 23 (level, low) -> IRQ 17
eth0: VIA Rhine II at 0x18000, 00:0e:a6:38:d6:c9, IRQ 17.
eth0: MII PHY found at address 1, status 0x786d advertising 01e1 Link 45e1.
ACPI: PCI Interrupt 0000:00:10.0[A] -> GSI 21 (level, low) -> IRQ 18
uhci_hcd 0000:00:10.0: UHCI Host Controller
uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:10.0: irq 18, io base 0x00009400
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
sd 0:0:0:0: [sda] 234441648 512-byte hardware sectors (120034 MB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
sda:<6>ACPI: PCI Interrupt 0000:00:10.1[A] -> GSI 21 (level, low) -> IRQ 18
uhci_hcd 0000:00:10.1: UHCI Host Controller
uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:10.1: irq 18, io base 0x00009000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
sda1 sda2 sda3 sda4 < sda5 sda6 sda7 >
sd 0:0:0:0: [sda] Attached SCSI disk
ACPI: PCI Interrupt 0000:00:10.2[B] -> GSI 21 (level, low) -> IRQ 18
uhci_hcd 0000:00:10.2: UHCI Host Controller
uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:10.2: irq 18, io base 0x00008800
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.3[B] -> GSI 21 (level, low) -> IRQ 18
uhci_hcd 0000:00:10.3: UHCI Host Controller
uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:10.3: irq 18, io base 0x00008400
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.4[C] -> GSI 21 (level, low) -> IRQ 18
ehci_hcd 0000:00:10.4: EHCI Host Controller
ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
ehci_hcd 0000:00:10.4: irq 18, io mem 0xde800000
ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 8 ports detected
hdc: ATAPI 40X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, UDMA(66)
Uniform CD-ROM driver Revision: 3.20
hdd: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
usb 2-2: new low speed USB device using uhci_hcd and address 2
usb 2-2: configuration #1 chosen from 1 choice
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Linux agpgart interface v0.102 © Dave Jones
agpgart: Detected VIA KT400/KT400A/KT600 chipset
agpgart: AGP aperture is 64M @ 0xf8000000
parport_pc 00:09: reported by Plug and Play ACPI
parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
parport0: Printer, HEWLETT-PACKARD DESKJET 930C
Real Time Clock Driver v1.12ac
input: PC Speaker as /class/input/input1
usbcore: registered new interface driver hiddev
gameport: NS558 PnP Gameport is pnp00:0c/gameport0, io 0x200, speed 1169kHz
input: HID 1241:1111 as /class/input/input2
input: USB HID v1.00 Mouse [HID 1241:1111] on usb-0000:00:10.1-2
usbcore: registered new interface driver usbhid
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
ACPI: PCI Interrupt 0000:00:11.5[C] -> GSI 22 (level, low) -> IRQ 19
PCI: Setting latency timer of device 0000:00:11.5 to 64
codec_read: codec 0 is not valid [0xfe0000]
PCI: Enabling device 0000:00:11.6 (0000 -> 0001)
ACPI: PCI Interrupt 0000:00:11.6[C] -> GSI 22 (level, low) -> IRQ 19
PCI: Setting latency timer of device 0000:00:11.6 to 64
ACPI: PCI interrupt for device 0000:00:11.6 disabled
VIA 82xx Modem: probe of 0000:00:11.6 failed with error -13
Adding 779144k swap on /dev/sda2. Priority:-1 extents:1 across:779144k
EXT3 FS on sda1, internal journal
fuse init (API version 7.
device-mapper: ioctl: 4.11.0-ioctl (2006-10-12) initialised: dm-devel@redhat.com
EXT3 FS on sda3, internal journal
EXT3 FS on sda5, internal journal
EXT3 FS on sda6, internal journal
EXT3 FS on sda7, internal journal
NET: Registered protocol family 15
ip_tables: © 2000-2006 Netfilter Core Team
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (4095 buckets, 32760 max)
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
lp0: using parport0 (interrupt-driven).
ppdev: user-space parallel port driver
Installing knfsd (copyright © 1996 okir@monad.swb.de).
NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
NFSD: starting 90-second grace period
eth0: no IPv6 routers present
[drm] Initialized drm 1.1.0 20060810
ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 20
[drm] Initialized radeon 1.27.0 20060524 on minor 0
agpgart: Found an AGP 3.5 compliant device at 0000:00:00.0.
agpgart: Putting AGP V3 device at 0000:00:00.0 into 4x mode
agpgart: Putting AGP V3 device at 0000:01:00.0 into 4x mode
[drm] Setting GART location based on new memory map
[drm] Loading R200 Microcode
[drm] writeback test succeeded in 1 usecs
sd 0:0:0:0: Attached scsi generic sg0 type 0
input: Power Button (FF) as /class/input/input3
ACPI: Power Button (FF) [PWRF]
input: Power Button (CM) as /class/input/input4
ACPI: Power Button (CM) [PWRB]
usb 5-5: new high speed USB device using ehci_hcd and address 3
usb 5-5: configuration #1 chosen from 1 choice
Initializing USB Mass Storage driver…
scsi2 : SCSI emulation for USB Mass Storage devices
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 3
usb-storage: waiting for device to settle before scanning
usb-storage: device scan complete
scsi 2:0:0:0: Direct-Access VBTM Store ‘n’ Go 5.00 PQ: 0 ANSI: 0 CCS
sd 2:0:0:0: [sdb] 2013184 512-byte hardware sectors (1031 MB)
sd 2:0:0:0: [sdb] Write Protect is off
sd 2:0:0:0: [sdb] Mode Sense: 23 00 00 00
sd 2:0:0:0: [sdb] Assuming drive cache: write through
sdb: sdb1
sd 2:0:0:0: [sdb] Attached SCSI removable disk
sd 2:0:0:0: Attached scsi generic sg1 type 0
usb 5-5: USB disconnect, address 3
