Je viens de faire une réinstall d’une debian Squeeze, et j’ai un problème avec nautilus, impossible d’accéder au préférences (Edition - Preferences). A chaque fois Nautilus plante et la fenêtre se ferme.
Même problème si je vais dans Système - Préférences - Gestion des fichiers.
J’ai essayer de lancer via un terminal ça ne marche pas également
[code]Mojo-Risin:/home/house# nautilus-file-management-properties
Initializing nautilus-image-converter extension
Initializing nautilus-open-terminal extension
(nautilus-file-management-properties:13290): Gtk-CRITICAL **: gtk_size_group_add_widget: assertion `GTK_IS_WIDGET (widget)’ failed
(nautilus-file-management-properties:13290): Gtk-CRITICAL **: gtk_combo_box_append_text: assertion `GTK_IS_COMBO_BOX (combo_box)’ failed
(nautilus-file-management-properties:13290): GLib-GObject-CRITICAL **: g_object_set_data_full: assertion `G_IS_OBJECT (object)’ failed
(nautilus-file-management-properties:13290): Eel-CRITICAL **: eel_preferences_add_callback_while_alive: assertion `G_IS_OBJECT (alive_object)’ failed
(nautilus-file-management-properties:13290): GLib-GObject-CRITICAL **: g_object_get_data: assertion `G_IS_OBJECT (object)’ failed
(nautilus-file-management-properties:13290): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(nautilus-file-management-properties:13290): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)’ failed
(nautilus-file-management-properties:13290): Eel-CRITICAL **: eel_preferences_get_boolean: assertion `name != NULL’ failed
(nautilus-file-management-properties:13290): GLib-GObject-CRITICAL **: g_signal_handlers_block_matched: assertion `G_TYPE_CHECK_INSTANCE (instance)’ failed
(nautilus-file-management-properties:13290): Gtk-CRITICAL **: gtk_toggle_button_set_active: assertion `GTK_IS_TOGGLE_BUTTON (toggle_button)’ failed
(nautilus-file-management-properties:13290): GLib-GObject-CRITICAL **: g_signal_handlers_unblock_matched: assertion `G_TYPE_CHECK_INSTANCE (instance)’ failed
(nautilus-file-management-properties:13290): GLib-GObject-CRITICAL **: g_object_set_data: assertion `G_IS_OBJECT (object)’ failed
(nautilus-file-management-properties:13290): Eel-CRITICAL **: eel_preferences_get: assertion `name != NULL’ failed
(nautilus-file-management-properties:13290): GLib-CRITICAL **: g_hash_table_lookup: assertion `hash_table != NULL’ failed
(nautilus-file-management-properties:13290): Gtk-CRITICAL **: gtk_combo_box_set_active: assertion `GTK_IS_COMBO_BOX (combo_box)’ failed
(nautilus-file-management-properties:13290): Eel-CRITICAL **: eel_preferences_get_integer: assertion `name != NULL’ failed
(nautilus-file-management-properties:13290): Gtk-CRITICAL **: gtk_widget_set_sensitive: assertion `GTK_IS_WIDGET (widget)’ failed
Erreur de segmentation
Voila j’espère que vous allez pouvoir m’aider.
