J’essaye désespérement de connecter mon serveur FTP à mon serveur LDAP… J’y suis pas très loin mais je n’arrive pas à réaliser l’authentification correctement…
J’ai tester toutes les possibilité du ldap.conf mais sans succès…
Si quelqu’un pouvait m’aider à trouver la solution ca serait merveilleux…
Voici ma config:
[code]debian:/etc/proftpd# cat ldap.conf
Proftpd sample configuration for LDAP authentication.
#AuthOrder mod_ldap.c LDAPDefaultAuthScheme clear LDAPAuthBinds on LDAPQueryTimeout 10 LDAPDoUIDLookups on "ou=people,dc=domaine,dc=eu" LDAPServer ldap://IP_SERVEUR:389 LDAPDNInfo "cn=admin,dc=domaine,dc=eu" "motdepasse" LDAPDoAuth on ou=people,dc=domaine,dc=eu "(&(uid=%u)(objectclass=posixAccount))" [/code] [code]debian:/etc/proftpd# cat modules.conf # # This file is used to manage DSO modules and features. #This is the directory where DSO modules reside
ModulePath /usr/lib/proftpd
Allow only user root to load and unload modules, but allow everyone
to see which modules have been loaded
ModuleControlsACLs insmod,rmmod allow user root
ModuleControlsACLs lsmod allow user *
LoadModule mod_ctrls_admin.c
LoadModule mod_tls.c
Install proftpd-mod-mysql or proftpd-mod-pgsql to use this
#LoadModule mod_sql.c
Install proftpd-mod-ldap to use this
LoadModule mod_ldap.c
‘SQLBackend mysql’ or ‘SQLBackend postgres’ directives are required
to have SQL authorization working. You can also comment out the
unused module here, in alternative.
Install proftpd-mod-mysql to use this
#LoadModule mod_sql_mysql.c
Install proftpd-mod-pgsql to use this
#LoadModule mod_sql_postgres.c
LoadModule mod_radius.c
LoadModule mod_quotatab.c
LoadModule mod_quotatab_file.c
#LoadModule mod_quotatab_ldap.c
Install proftpd-mod-pgsql or proftpd-mod-mysql to use this
#LoadModule mod_quotatab_sql.c
LoadModule mod_quotatab_radius.c
LoadModule mod_wrap.c
LoadModule mod_rewrite.c
LoadModule mod_load.c
LoadModule mod_ban.c
LoadModule mod_wrap2.c
LoadModule mod_wrap2_file.c
#LoadModule mod_wrap2_sql.c
LoadModule mod_dynmasq.c
keep this module the last one
LoadModule mod_ifsession.c[/code]
[code]debian:/etc/proftpd# cat proftpd.conf
/etc/proftpd/proftpd.conf – This is a basic ProFTPD configuration file.
To really apply changes reload proftpd after modifications.
Includes DSO modules
Include /etc/proftpd/modules.conf
Set off to disable IPv6 support which is annoying on IPv4 only boxes.
UseIPv6 off
If set on you can experience a longer connection delay in many cases.
IdentLookups off
ServerName "Debian"
ServerType standalone
DeferWelcome off
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutNoTransfer 600
TimeoutStalled 600
TimeoutIdle 1200
DisplayLogin welcome.msg
DisplayChdir .message true
ListOptions “-l”
DenyFilter *.*/
Use this to jail all users in their homes
DefaultRoot ~
Users require a valid shell listed in /etc/shells to login.
Use this directive to release that constrain.
RequireValidShell off
Port 21 is the standard FTP port.
Port 21
In some cases you have to specify passive ports range to by-pass
firewall limitations. Ephemeral ports can be used for that, but
feel free to use a more narrow range.
PassivePorts 49152 65534
If your host was NATted, this option is useful in order to
allow passive tranfers to work. You have to use your public
address and opening the passive ports used on your firewall as well.
MasqueradeAddress 1.2.3.4
This is useful for masquerading address with dynamic IPs:
refresh any configured MasqueradeAddress directives every 8 hours
# DynMasqRefresh 28800To prevent DoS attacks, set the maximum number of child processes
to 30. If you need to allow more than 30 concurrent connections
at once, simply increase this value. Note that this ONLY works
in standalone mode, in inetd mode you should use an inetd server
that allows you to limit maximum number of processes per service
(such as xinetd)
MaxInstances 30
Set the user and group that the server normally runs at.
User proftpd
Group nogroup
Umask 022 is a good standard umask to prevent new files and dirs
(second parm) from being group and world writable.
Umask 022 022
Normally, we want files to be overwriteable.
AllowOverwrite on
Uncomment this if you are using NIS or LDAP via NSS to retrieve passwords:
PersistentPasswd off
This is required to use both PAM-based authentication and local passwords
#AuthOrder mod_ldap.c mod_auth_pam.c* mod_auth_unix.c
Be warned: use of this directive impacts CPU average load!
Uncomment this if you like to see progress and transfer rate with ftpwho
in downloads. That is not needed for uploads rates.
UseSendFile off
TransferLog /var/log/proftpd/xferlog
SystemLog /var/log/proftpd/proftpd.log
Delay engine reduces impact of the so-called Timing Attack described in
http://security.lss.hr/index.php?page=details&ID=LSS-2004-10-02
It is on by default.
DelayEngine on ControlsEngine off ControlsMaxClients 2 ControlsLog /var/log/proftpd/controls.log ControlsInterval 5 ControlsSocket /var/run/proftpd/proftpd.sock AdminControlsEngine offAlternative authentication frameworks
Include /etc/proftpd/ldap.conf
#Include /etc/proftpd/sql.conf[/code]
Le NSS arrive bien à trouver les user LDAP (ici Damien & Guillaume) Mais ya le * qui me gène…
debian:/etc/proftpd# getent passwd
root:x:0:0:root:/root:/bin/bash
openldap:x:104:106:OpenLDAP Server Account,,,:/var/lib/ldap:/bin/false
proftpd:x:105:65534::/var/run/proftpd:/bin/false
ftp:x:106:65534::/home/ftp:/bin/false
guillaume:*:1000:1000:Guillaume FAMILLE:/home/guillaume:
damien:*:1000:1000:Damien FAMILLE:/home/damien:
Si je fais un ldapsearch, je trouve bien mon user (mais proftpd y arrive pas (voir après))
debian:/etc/proftpd# ldapsearch -x -b "dc=domaine,dc=eu" -H ldap://88.191.35.131:389 -D "cn=admin,dc=domaine,dc=eu" -W -LLL "(&(uid=damien)(objectclass=posixAccount))"
Enter LDAP Password:
dn: cn=Damien,ou=people,dc=domaine,dc=eu
objectClass: inetOrgPerson
objectClass: top
objectClass: posixAccount
sn: FAMILLE
cn: Damien FAMILLE
gidNumber: 1000
homeDirectory: /home/damien
uidNumber: 1000
givenName: damien
uid: damien
userPassword:: ZGFtaWVu
Voici la log debug de proftpd… Où on voit bien qu’il ne trouve pas la fiche mais pkoi… mystère…
[code]debian:/etc/proftpd# proftpd -nd12
- mod_tls/2.1.2: using OpenSSL 0.9.8g 19 Oct 2007
- disabling runtime support for IPv6 connections
- DenyFilter: compiling deny regex ‘*.*/’
- : using ‘mod_dynmasq.c’ section at line 54
- retrieved UID 105 for user ‘proftpd’
- retrieved GID 65534 for group ‘nogroup’
- : using ‘mod_quotatab.c’ section at line 91
- : skipping ‘mod_ratio.c’ section at line 95
- : using ‘mod_delay.c’ section at line 103
- : using ‘mod_ctrls.c’ section at line 107
- : using ‘mod_ctrls_admin.c’ section at line 115
- : using ‘mod_ldap.c’ section at line 7
serveur.domaine.org -
serveur.domaine.org - Config for Debian:
serveur.domaine.org - IdentLookups
serveur.domaine.org - DeferWelcome
serveur.domaine.org - DefaultServer
serveur.domaine.org - ShowSymlinks
serveur.domaine.org - TimeoutNoTransfer
serveur.domaine.org - TimeoutStalled
serveur.domaine.org - TimeoutIdle
serveur.domaine.org - DisplayLogin
serveur.domaine.org - DisplayChdir
serveur.domaine.org - ListOptions
serveur.domaine.org - DenyFilter
serveur.domaine.org - RequireValidShell
serveur.domaine.org - UserID
serveur.domaine.org - UserName
serveur.domaine.org - GroupID
serveur.domaine.org - GroupName
serveur.domaine.org - Umask
serveur.domaine.org - DirUmask
serveur.domaine.org - AllowOverwrite
serveur.domaine.org - TransferLog
serveur.domaine.org - QuotaEngine
serveur.domaine.org - DelayEngine
serveur.domaine.org - LDAPDefaultAuthScheme
serveur.domaine.org - LDAPAuthBinds
serveur.domaine.org - LDAPQueryTimeout
serveur.domaine.org - LDAPDoUIDLookups
serveur.domaine.org - LDAPServer
serveur.domaine.org - LDAPDNInfo
serveur.domaine.org - LDAPDoAuth
serveur.domaine.org - ROOT PRIVS at mod_delay.c:307
serveur.domaine.org - RELINQUISH PRIVS at mod_delay.c:309
serveur.domaine.org - ROOT PRIVS at mod_ctrls.c:1618
serveur.domaine.org - RELINQUISH PRIVS at mod_ctrls.c:1620
serveur.domaine.org - mod_lang/0.8: binding to text domain ‘proftpd’ using locale path '/usr/share/locale’
serveur.domaine.org - retrieved group ID: 65534
serveur.domaine.org - setting group ID: 65534
serveur.domaine.org - SETUP PRIVS at main.c:2869
serveur.domaine.org - ROOT PRIVS at main.c:1946
serveur.domaine.org - RELINQUISH PRIVS at main.c:1953
serveur.domaine.org - ROOT PRIVS at main.c:2277
serveur.domaine.org - opening scoreboard '/var/run/proftpd/proftpd.scoreboard’
serveur.domaine.org - RELINQUISH PRIVS at main.c:2303
serveur.domaine.org - ROOT PRIVS at mod_ctrls_admin.c:1092
serveur.domaine.org - RELINQUISH PRIVS at mod_ctrls_admin.c:1094
serveur.domaine.org - ROOT PRIVS at inet.c:343
serveur.domaine.org - RELINQUISH PRIVS at inet.c:406
serveur.domaine.org - ProFTPD 1.3.1 (stable) (built Fri Feb 27 21:34:04 UTC 2009) standalone mode STARTUP
serveur.domaine.org - ROOT PRIVS at pidfile.c:42
serveur.domaine.org - RELINQUISH PRIVS at pidfile.c:44
serveur.domaine.org - ROOT PRIVS at main.c:1070
serveur.domaine.org - RELINQUISH PRIVS at main.c:1074
serveur.domaine.org - no matching vhost found for 192.168.4.122#21, using DefaultServer 'Debian’
serveur.domaine.org (ordi[192.168.4.148]) - ROOT PRIVS at main.c:919
serveur.domaine.org (ordi[192.168.4.148]) - SETUP PRIVS at main.c:924
serveur.domaine.org (ordi[192.168.4.148]) - FTP session requested from unknown class
serveur.domaine.org (ordi[192.168.4.148]) - performing module session initializations
serveur.domaine.org (ordi[192.168.4.148]) - ROOT PRIVS at mod_delay.c:1240
serveur.domaine.org (ordi[192.168.4.148]) - RELINQUISH PRIVS at mod_delay.c:1242
serveur.domaine.org (ordi[192.168.4.148]) - ROOT PRIVS at mod_auth.c:151
serveur.domaine.org (ordi[192.168.4.148]) - opening scoreboard '/var/run/proftpd/proftpd.scoreboard’
serveur.domaine.org (ordi[192.168.4.148]) - RELINQUISH PRIVS at mod_auth.c:153
serveur.domaine.org (ordi[192.168.4.148]) - ident lookup disabled
serveur.domaine.org (ordi[192.168.4.148]) - connected - local : 192.168.4.122:21
serveur.domaine.org (ordi[192.168.4.148]) - connected - remote : 192.168.4.148:59163
serveur.domaine.org (ordi[192.168.4.148]) - FTP session opened.
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘USER damien’ to mod_rewrite
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘USER damien’ to mod_tls
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘USER damien’ to mod_core
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘USER damien’ to mod_delay
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘USER damien’ to mod_auth
serveur.domaine.org (ordi[192.168.4.148]) - mod_ldap/2.8.17: not unbinding to an already unbound connection.
serveur.domaine.org (ordi[192.168.4.148]) - dispatching CMD command ‘USER damien’ to mod_auth
serveur.domaine.org (ordi[192.168.4.148]) - retrieved group ID: 1000
serveur.domaine.org (ordi[192.168.4.148]) - retrieved group name: guillain
serveur.domaine.org (ordi[192.168.4.148]) - dispatching POST_CMD command ‘USER damien’ to mod_delay
serveur.domaine.org (ordi[192.168.4.148]) - dispatching LOG_CMD command ‘USER damien’ to mod_log
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘PASS (hidden)’ to mod_rewrite
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘PASS (hidden)’ to mod_tls
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘PASS (hidden)’ to mod_core
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘PASS (hidden)’ to mod_wrap2
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘PASS (hidden)’ to mod_ban
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘PASS (hidden)’ to mod_radius
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘PASS (hidden)’ to mod_delay
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘PASS (hidden)’ to mod_auth
serveur.domaine.org (ordi[192.168.4.148]) - dispatching CMD command ‘PASS (hidden)’ to mod_auth
serveur.domaine.org (ordi[192.168.4.148]) - mod_ldap/2.8.17: generated filter ou=people,dc=domaine,dc=eu from template ou=people,dc=domaine,dc=eu and value damien
serveur.domaine.org (ordi[192.168.4.148]) - mod_ldap/2.8.17: connected to 88.191.35.131:389
serveur.domaine.org (ordi[192.168.4.148]) - mod_ldap/2.8.17: set protocol version to 3
serveur.domaine.org (ordi[192.168.4.148]) - mod_ldap/2.8.17: successfully bound as cn=admin,dc=domaine,dc=eu with password motdepasse
serveur.domaine.org (ordi[192.168.4.148]) - mod_ldap/2.8.17: set dereferencing to 0
serveur.domaine.org (ordi[192.168.4.148]) - mod_ldap/2.8.17: set query timeout to 10s
serveur.domaine.org (ordi[192.168.4.148]) - mod_ldap/2.8.17: generated filter (&(uid=damien)(objectclass=posixAccount)) from template (&(uid=%u)(objectclass=posixAccount)) and value damien
serveur.domaine.org (ordi[192.168.4.148]) - mod_ldap/2.8.17: searched using filter (&(uid=damien)(objectclass=posixAccount))
serveur.domaine.org (ordi[192.168.4.148]) - mod_ldap/2.8.17: no entries for filter (&(uid=damien)(objectclass=posixAccount))
serveur.domaine.org (ordi[192.168.4.148]) - retrieved UID 1000 for user 'damien’
serveur.domaine.org (ordi[192.168.4.148]) - ROOT PRIVS at mod_auth_pam.c:289
serveur.domaine.org (ordi[192.168.4.148]) - RELINQUISH PRIVS at mod_auth_pam.c:464
serveur.domaine.org (ordi[192.168.4.148]) - ROOT PRIVS at mod_auth_unix.c:428
serveur.domaine.org (ordi[192.168.4.148]) - RELINQUISH PRIVS at mod_auth_unix.c:467
serveur.domaine.org (ordi[192.168.4.148]) - USER damien (Login failed): Incorrect password.
serveur.domaine.org (ordi[192.168.4.148]) - dispatching POST_CMD_ERR command ‘PASS (hidden)’ to mod_delay
serveur.domaine.org (ordi[192.168.4.148]) - dispatching LOG_CMD_ERR command ‘PASS (hidden)’ to mod_log
serveur.domaine.org (ordi[192.168.4.148]) - dispatching LOG_CMD_ERR command ‘PASS (hidden)’ to mod_auth
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘QUIT’ to mod_rewrite
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘QUIT’ to mod_tls
serveur.domaine.org (ordi[192.168.4.148]) - dispatching PRE_CMD command ‘QUIT’ to mod_core
serveur.domaine.org (ordi[192.168.4.148]) - dispatching CMD command ‘QUIT’ to mod_core
serveur.domaine.org (ordi[192.168.4.148]) - dispatching LOG_CMD command ‘QUIT’ to mod_log
serveur.domaine.org (ordi[192.168.4.148]) - dispatching LOG_CMD command ‘QUIT’ to mod_core
serveur.domaine.org (ordi[192.168.4.148]) - mod_ldap/2.8.17: successfully unbound
serveur.domaine.org (ordi[192.168.4.148]) - FTP session closed.[/code]
