Problème de lecture CD audio
Bonsoir,
Suite au changement de boîtier de mon PC, je ne peux plus lire les CD audio ni avec mon lecteur de DVD, ni avec le lecteur/graveur de CD.
J’ai tout rebranché comme dans l’ancien boitier, je ne comprend donc pas pourquoi!
Je suis aussi passé de “Lenny” à “Squeeze” sur ce poste.
Voici la sortie de demsg avec un CD audio dans le lecteur/graveur CD:
[ 3.172115] hdc: HL-DT-ST GCE-8526B, ATAPI CD/DVD-ROM drive [ 4.012116] hdc: host max PIO5 wanted PIO255(auto-tune) selected PIO4 [ 4.012217] hdc: UDMA/33 mode selected [ 4.611610] ide-cd: hdc: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache [ 8.475515] hdc: command error: status=0x51 { DriveReady SeekComplete Error } [ 8.475743] hdc: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } [ 8.475960] hdc: possibly failed opcode: 0xa0 [ 8.476200] end_request: I/O error, dev hdc, sector 0 [ 8.476258] Buffer I/O error on device hdc, logical block 0 [ 8.476316] Buffer I/O error on device hdc, logical block 1 [ 8.476372] Buffer I/O error on device hdc, logical block 2 [ 8.476426] Buffer I/O error on device hdc, logical block 3 [ 8.476481] Buffer I/O error on device hdc, logical block 4 [ 8.476535] Buffer I/O error on device hdc, logical block 5 [ 8.476590] Buffer I/O error on device hdc, logical block 6 [ 8.476645] Buffer I/O error on device hdc, logical block 7 [ 8.476700] Buffer I/O error on device hdc, logical block 8 [ 8.476754] Buffer I/O error on device hdc, logical block 9 [ 8.477099] hdc: command error: status=0x51 { DriveReady SeekComplete Error } [ 8.477311] hdc: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } [ 8.477528] hdc: possibly failed opcode: 0xa0 [ 9.480307] end_request: I/O error, dev hdc, sector 0 [ 9.158522] hdc: command error: status=0x51 { DriveReady SeekComplete Error } [ 9.158745] hdc: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } [ 9.158962] hdc: possibly failed opcode: 0xa0 [ 9.160194] end_request: I/O error, dev hdc, sector 0 [ 9.160515] hdc: command error: status=0x51 { DriveReady SeekComplete Error } [ 9.160727] hdc: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } [ 9.160944] hdc: possibly failed opcode: 0xa0 [ 9.165682] end_request: I/O error, dev hdc, sector 0 [ 9.166065] hdc: command error: status=0x51 { DriveReady SeekComplete Error } [ 9.166280] hdc: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } [ 9.166496] hdc: possibly failed opcode: 0xa0 [ 9.168172] end_request: I/O error, dev hdc, sector 0
Et un CD audio le lecteur de DVD:
[ 4.072019] hdd: COMPAQ DVD-ROM GD-2500, ATAPI CD/DVD-ROM drive [ 4.554909] hdd: host max PIO5 wanted PIO255(auto-tune) selected PIO4 [ 4.555076] hdd: MWDMA2 mode selected [ 5.133942] ide-cd: hdd: ATAPI 24X DVD-ROM drive, 512kB Cache [ 9.352144] hdd: command error: status=0x51 { DriveReady SeekComplete Error } [ 9.352363] hdd: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } [ 9.352578] hdd: possibly failed opcode: 0xa0 [ 9.360323] end_request: I/O error, dev hdd, sector 0 [ 9.360777] hdd: command error: status=0x51 { DriveReady SeekComplete Error } [ 9.361015] hdd: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } [ 9.361231] hdd: possibly failed opcode: 0xa0 [ 9.364385] end_request: I/O error, dev hdd, sector 0 [ 10.420836] hdd: command error: status=0x51 { DriveReady SeekComplete Error } [ 10.421057] hdd: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } [ 10.421272] hdd: possibly failed opcode: 0xa0 [ 10.428321] end_request: I/O error, dev hdd, sector 0 [ 10.428718] hdd: command error: status=0x51 { DriveReady SeekComplete Error } [ 10.428933] hdd: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } [ 10.429148] hdd: possibly failed opcode: 0xa0 [ 10.445258] end_request: I/O error, dev hdd, sector 0 [ 10.445925] hdd: command error: status=0x51 { DriveReady SeekComplete Error } [ 10.446143] hdd: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 } [ 10.446359] hdd: possibly failed opcode: 0xa0 [ 10.448357] end_request: I/O error, dev hdd, sector 0
Que ce soit avec des CD pressés ou gravés (et quelque soit la musique).
Si quelqu’un à une idée?
Je ne réponds pas mais je remonte ce fil parce que j’ai un peu le même problème mais avec une Sid.
Ptet une histoire de paquets qui ne sont pas chargés ?
Que faut-il pour lire un CD audio sur un portable Dell studio 1737 avec le lecteur sur le côté sans panier qui sort, un bouffe-tout, quoi :wink:
Peut-être manque-t-il quelque chose alors?
Parce-que j’ai fait une réinstalle peut avant de changer le boîtier suite à une grosse bourde :frowning:
Quand je lance K3B je voit les piste, par contre rhytmbox ne voit rien du tout même en faisant analyser les médias et Grip me dit:
Sniff!
